Soffit Vents...open Vs. Closed - Roofing - Contractor Talk
Old 01-14-2010, 10:38 AM   #1
BlackHatch's Avatar
Trade: Exterior Construction
I know that people in the know have said that the soffit vent argument and the basis for roof ventilation was invented by asphalt manufactures.
Does anyone have any information that they can link me too?
Thanks.
BlackHatch is offline
Old 01-14-2010, 11:43 AM   #2
mics_54's Avatar
Trade: contractor
Re: Soffit Vents...open Vs. Closed
I think Jesse Ventura is doing some research on this theory.
mics_54 is offline
Old 01-14-2010, 01:29 PM   #3
BlackHatch's Avatar
That guy is a class A nutjob.
Old 01-14-2010, 04:37 PM   #4
Ed the Roofer's Avatar
Trade: Roofing Contractor
Rewards Points: 2,062
What type of information are you looking for?
Why soffit ventilation is necessary?
How much soffit ventilation is required?
What happens if their is no Intake Ventilation?
Can soffit vents leak?
Can soffit ventilation short-circuit the ventilation system?
Please be more specific for an accurate answer.
Otherwise, check out AirVents website or research Joe Lstirubek regarding his ventilation theories.
Ed
Ed the Roofer is offline
The Following User Says Thank You to Ed the Roofer For This Useful Post:
BlackHatch (01-15-2010)
Old 01-15-2010, 12:00 AM   #5
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
what do the asphalt manufacturers care about venting?
Tom Struble is offline
Old 01-15-2010, 03:32 AM   #6
Teetorbilt's Avatar
Rewards Points: 2,000
Hit the archives, this topic gets batted around at least once a year.
You are wrong about the asphalt shingle manufacturers being the blame for venting. I've worked on many homes that were built before asphalt shingles were made, they vented more aggressively back then. Down here I think that it was more for heat dissipation.
Albert Einstein
Teetorbilt is offline
The Following 3 Users Say Thank You to Teetorbilt For This Useful Post:
BlackHatch (01-15-2010), English Roofer (01-15-2010), seeyou (01-15-2010)
Old 01-15-2010, 09:01 AM   #7
BlackHatch's Avatar
That is why I was asking. I read a bunch of those archives from that building science Phd. Very good stuff.
Thanks for the links guys.
Eric
seal gable vents after ridge vent installed? tacoma5050 Roofing 41 06-07-2012 07:32 PM
Soffit vents and insects? brint Carpentry 10 12-15-2009 05:44 AM
THrown-in insulation: No soffit vents... Ted W Insulation 19 08-15-2009 11:35 AM
open or closed system C.C.R. Plumbing 3 03-15-2007 11:13 PM
