Roofing W/ HVAC On The Roof - Roofing - Contractor Talk
Old 04-13-2019, 02:44 AM   #1
irving2907's Avatar
Rewards Points: 2
I am a general contractor and we are remodeling a house. The house has two roof mounted HVAC units on shingles. Do you reroof around the unit/base or do you remove the unit first and then reinstall? I guess it didn't occur until after the agreement was signed. I've read mixed reviews on how to proceed. Also, they have a wood fence around the HVAC unit on the roof to make it less noticeable. Thanks!
irving2907 is offline
Old 04-13-2019, 01:50 PM   #2
mkb's Avatar
Trade: Gen B
Rewards Points: 136
Re: Roofing W/ HVAC On The Roof
We have done both when doing re-roofs. The majority of the time, we lift the units and put them back, but that's a lot more work. As long as inspection passes, and customer doesn't mind, either way should work.
mkb is offline
Old 06-25-2019, 10:03 AM   #3
madrina's Avatar
Trade: roofing and other envied trades
Rewards Points: 1,278
I am a homeowner acting as my own general contractor and we are remodeling a house. The house has two roof mounted HVAC units on shingles. Do you reroof around the unit/base or do you remove the unit first and then reinstall? I guess it didn't occur until after the agreement was signed. I've read mixed reviews on how to proceed. Also, they have a wood fence around the HVAC unit on the roof to make it less noticeable. Thanks!
Fixed it for ya
madrina is offline
The Following User Says Thank You to madrina For This Useful Post:
A&E Exteriors (06-25-2019)
Residential Flat roof Nac Roofing 15 04-28-2018 08:46 AM
Working on my own roof red_cedar Roofing Picture Post 18 10-18-2013 06:47 PM
Flat roof - What roofing system should I use? acro Roofing 10 04-15-2013 04:47 PM
