Roof Magnets - Roofing - Contractor Talk
Roof Magnets
Old 05-12-2013, 08:36 AM   #1
MattK's Avatar
Trade: Framing, Roofing, Siding
Rewards Points: 1,096
Roof Magnets
I'm looking for a stronger portable 3' magnet. I've tried different locally sold brands and versions of the 3' roll magnet for roof nails in lawns. I tarp every ground to catch debris but nails still make it through. Recently, a homeowner had a thick lawn and my magnet couldn't handle the uncut grass length, approx 5-6" in height, nothing extreme. The magnet would pick the nails up and the grass would knock them off so it forced us to stop after every "ping" and remove nails one at a time. Usually, I request HOs cut their lawns before we arrive just for this reason.
I would like to upgrade to a stronger magnet that has some serious holding power. I looked through the previous threads and found a few decent links to some better magnets for serious prices, some in the high hundreds, low thousands. What do you guys like to use? What works best in this situation?
--MATT
Add your Facebook Business Site to "THE LIST"
http://www.contractortalk.com/f12/if...-should-79504/
Page 77 has the updated, complete list.
MattK is offline
Old 05-12-2013, 09:19 AM   #2
BamBamm5144's Avatar
Trade: Everything Exterior, Mostly Roofing.
Rewards Points: 2,786
Re: Roof Magnets
I don't think any magnet can get through 6" grass. The HO needs to cut the lawn.
BamBamm5144 is offline
The Following User Says Thank You to BamBamm5144 For This Useful Post:
A&E Exteriors (10-08-2015)
Old 05-12-2013, 09:22 AM   #3
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: Roof Magnets
Call a landscape co with a yard vac. Then bill them for a grass cut...
ohiohomedoctor is offline
Old 05-12-2013, 09:28 AM   #4
MattK's Avatar
Re: Roof Magnets
Last half hour I've been reading about making my own electromagnet. Anyone done this in the past for construction usage?
It looks like a 2' iron rod wrapped in copper insulated wiring tightly in one direction will create the current flow. Strip the wire ends and connect it to a power pack with a built in switch to control the on/off function. Also appears the strength can be adjusted by controlling the gauge of the copper as well as the amount of wraps(all in same direction) and the core size, for example a piece of 3/4" 3' rebar will conduct better than a 12" iron spike. The larger the magnet the more juice it will require, hence the need for a switch to kill the connections when done. It appears a heavy duty electromagnet will have no problem with nails in heavy grass and won't release until power source is turned off.
Off course with every experiment there is risk and in this case it's the heat this will produce. These can get very hot, 2 copper wraps produce 4x the heat, 3 wraps produce 9x the heat and so on...
--MATT
MattK is offline
Old 05-12-2013, 09:32 AM   #5
MattK's Avatar
Re: Roof Magnets
This error is on me. HO asked if I wanted landscapers to do spring cleanup/initial cut before or after my roof after I mentioned cutting the lawn before we start. I choose after as they're planting all new flowers and reshaping mulch beds. Nothing like 5-6 tons of debris to ruin all their work.
Not upset about the grass length just need a better solution for next time. Took 90 minutes magneting one nail at a time, roll over magneted area 3 minutes later and another nail leaps up. Frustrating and funny at the same time.
--MATT
MattK is offline
Old 05-12-2013, 10:15 AM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 680
Re: Roof Magnets
Check these out:
http://www.globalindustrial.com/c/ja...FSjZQgodF1YAag
http://www.amazon.com/Magnetic-Rolle.../dp/B0096DNRBQ
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
MattK (05-12-2013), Tom Struble (05-12-2013)
Old 05-12-2013, 10:40 AM   #7
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Roof Magnets
clean up sucks..
Tom Struble is offline
CompleteW&D (09-05-2015)
Old 05-12-2013, 02:08 PM   #8
Jeff
jkfox624's Avatar
Trade: master turd burglar
Rewards Points: 502
Re: Roof Magnets
Originally Posted by Tom Struble View Post
clean up sucks..
yes it does...
jkfox624 is offline
Old 05-12-2013, 02:10 PM   #9
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,048
Re: Roof Magnets
clean up sucks..
Only if you are the one having to do it.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
Old 05-12-2013, 04:09 PM   #10
PatChap's Avatar
Trade: Roofing, eaves
Rewards Points: 132
Re: Roof Magnets
I have a expensive 24" rollmag, similar to the amazon one linked and a $30 24" from princess auto. Neither would handle grass that tall, but in standard grass I find no difference between the two other than the fancy one is much lighter.
PatChap is offline
Old 05-13-2013, 01:54 AM   #11
madrina's Avatar
Trade: roofing and other envied trades
Rewards Points: 1,278
Re: Roof Magnets
i just use a mexican. it works pretty good.
madrina is offline
Old 05-13-2013, 06:27 AM   #12
Trade: siding
Rewards Points: 20
Re: Roof Magnets
my magnet has an optional rake attachment,never used it tho..
Old 05-13-2013, 02:47 PM   #13
YUUUUP!
JWilliams's Avatar
Trade: Metal Roofing Mogul
Rewards Points: 916
Re: Roof Magnets
I have a laborer. Have him roll the magnet around and even have an older magnet where the wheels broke off and i will have him drag that one thru the grass. It actually picks up what the rolling one missed.
JWilliams is offline
Old 05-13-2013, 05:18 PM   #14
MattK's Avatar
Re: Roof Magnets
Never minded cleaning debris. I turn up the tunes and shut off the brain for a change.
--MATT
MattK is offline
Old 05-13-2013, 05:47 PM   #15
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: Roof Magnets
Buy 6 of them beefcake rare earth magnets and mount them to a bar with wheels. Them things should be able to pick up nails from about 2ft away be careful though as the larger ones are strong enough to crush your hands or fingers. I use the 1" ones and they are powerful let alone the 5" ones.
Here's some 3" ones with mounts http://www.magnet4less.com/product_i...roducts_id=806
www.bcconstructionllc.com
BCConstruction is offline
Old 05-16-2013, 07:42 AM   #16
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
Re: Roof Magnets
I have the PA one...works like a dream.
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 06-08-2013, 06:30 AM   #17
roofermann's Avatar
Trade: roofing, siding, windows
Rewards Points: 259
Re: Roof Magnets
We put a clause in our contracts to deal with this issue. Almost all the houses have freshly mown lawns for us now.
roofermann is offline
Old 08-29-2015, 08:38 AM   #18
nqc2k's Avatar
Trade: general
Rewards Points: 12
Re: Roof Magnets
Any updates on your magnet search? What did you end up doing? I want to purchase the best one for nails in grass that I can buy.
I found these two which were made for grass and not a warehouse setting.
http://www.van-mark.com/Roofing/NailHawg/NailHawg.html
http://www.bluestreakequipment.com/s...s/ecko-series/
nqc2k is offline
Old 08-29-2015, 08:48 AM   #19
hdavis's Avatar
Rewards Points: 2,370
Re: Roof Magnets
Not a bad idea.
hdavis is online now
Old 08-29-2015, 08:55 AM   #20
hdavis's Avatar
Re: Roof Magnets
For tall grass, I have a magnet possibly from a large magnetron. It's about 20 lbs or so. I just drag it on a rope. Got it as surplus.
Dormer Shed Roof, Barrel Roof, CutIn Dormer, Eyebrow Dormer sbebuilders Framing 33 04-18-2013 05:29 PM
You only have 2 days and $2k to redo a roof. What do you do John12341234 Roofing 14 03-02-2013 06:06 PM
Roof repair, what to do? offshorehs Roofing 15 02-19-2012 11:25 PM
porch roof nailed to facia boman47k Framing 1 09-02-2010 11:04 PM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 09:54 PM
