Ridge Vent - Roofing - Contractor Talk
Ridge Vent
Old 10-24-2011, 08:00 AM   #1
enforcer's Avatar
Trade: windows-siding
Ridge Vent
i am having my roof done. Can a ridge vent cause my home to be colder in winter? Let's say I don't have a lot of insulation in my attic, will a ridge vent not only make my attic colder but the downstairs living area as well?
Final question... Obviously a ridge vent keeps the interior roof colder and prevents melting. Eventually it has to melt, will that cause damning or is the whole roof melting at the same time which prevents the ice damn?
enforcer is offline
Old 10-24-2011, 05:25 PM   #2
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,430
Re: Ridge Vent
If not having a ridge vent is keeping your house warmer , I do think you have problems, more insulation needed. I did a house with a steel roof a number of years ago and the guy swore up and down I made his house colder. Which in fact I probably did. After looking in the attic there was barely enough insulation to cover the 2x4 ceiling. Made me spray foam in the roof edges ribs before I could collect on the job.
He was the type that was over educated.
I do believe a proper vent and insulated roof will be cooler in the summer there by the shingles lasting longer and keep the heat away from the roof in the winter there by less ice damming.
IMO I would not leave the ridge vent off.
Randy Bush is online now
Old 10-24-2011, 05:41 PM   #3
GettingBy's Avatar
Rewards Points: 6,486
Re: Ridge Vent
Yes. Freezing at the roof edges and melting in the other areas due to attic heat causes ice dams.
I wired up my attic fan so I could turn it on in the winter to prevent ice dams. In principle it would work but practically it's hard to tell unless you run the fan all the time and everyone else is having dams and you aren't.
GettingBy is offline
Old 10-24-2011, 05:41 PM   #4
General Contractor
greg24k's Avatar
Rewards Points: 8,310
Re: Ridge Vent
What attic ventilation you have now? Do you have gable vents with a vented soffit, or just gable vents?
greg24k is offline
Old 10-24-2011, 08:04 PM   #5
enforcer's Avatar
Re: Ridge Vent
I have gable vents and soffits. My roofer will close up the gable vents, make sure the soffits are functioning, and then install the ridge vent.
What I am still confused about is this.. The ridge vent will make the roof cooler thereby reducing melting from the ridge. However, the snow has to eventually melt right? Won't that in itself cause damning? Or is it that the whole roof melts together with a ridge vent including the eaves so there is no snow at the edges to damn?
enforcer is offline
Old 10-24-2011, 08:33 PM   #6
General Contractor
greg24k's Avatar
Re: Ridge Vent
You will be fine, ridge and soffit is the best attic ventilation you can get... To avoid ice dam, make sure no warm air or humidity escapes from the house into the attic. Make sure you have good ceiling insulation that will reduce heat loss by conduction.
greg24k is offline
Old 10-24-2011, 08:46 PM   #7
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
Rewards Points: 1,772
Re: Ridge Vent
No matter what you do, there will be heat loss into the attic from the conditioned space below.
There is a possibility of the warm air melting the snow on top of the ridge vent, and the water flowing under the snow and creating an ice dam. The snow will act like an insulator and there could be water under it turning into ice when it cools.
This is usually only when it is a year with high snow totals and low temps. Make sure to keep the venting clear, especially if you notice it covered in snow or has formation of ice.
I have seen this on many houses and it rarely causes problems because it only happens for a short length of time. Last year, we had plenty of snow and did a lot of snow removal. Skylights, bathroom and range vents can and will do the same in these deep snow, low temp winters.
Never hurts to add insulation and save some of your heat and cooling.
Make sure those gable vents are closed and the soffit vents are functional.
MJW is offline
Old 10-24-2011, 11:53 PM   #8
Splinter hands's Avatar
Re: Ridge Vent
The idea of venting is to keep the attic space at the same temp as the outside. How an ice dam usually forms is the attic space is above freezing which melts snow from the underside and when it gets to the eave it will freeze because the 1' or 2' that is on the outside of the interior wall is below freezing. When it freezes it gets bigger and bigger due to blocking the snow that is continually melting over the surface of the roof. At some point it will work it's way under the shingles melt again when it come in contact with the warmer sheathing and end up on your kitchen table. In short you NEED the vent.
Splinter hands is offline
Old 10-25-2011, 07:04 AM   #9
Carbon Dioxide Producer
DuMass's Avatar
Trade: EC
Re: Ridge Vent
I thought all the asphalt shingle manufacturers were requiring ridge and soffit venting to be installed in order for their 30 and 40-year architectural grade shingle "warranties" to be in effect?
Maybe not.
DuMass is offline
Old 10-25-2011, 07:52 AM   #10
BamBamm5144's Avatar
Trade: Everything Exterior, Mostly Roofing.
Rewards Points: 2,786
Re: Ridge Vent
Maybe not.
Nope. You just need the proper amount of exhaust and intake. Majority of roofs don't have that and that's why 9 out of 10 roof warranties invalid.
BamBamm5144 is offline
The Following User Says Thank You to BamBamm5144 For This Useful Post:
DuMass (10-25-2011)
Old 10-25-2011, 09:00 AM   #11
GettingBy's Avatar
Re: Ridge Vent
It can go directly from solid to vapor.
http://www.google.com/search?client=...UTF-8&oe=UTF-8
Old 10-25-2011, 02:23 PM   #12
welterweight's Avatar
Trade: sales
Re: Ridge Vent
By installing a ridge vent, you will decrease ice damns because as you said, the ridge won't melt before the eaves and there will be no snow at the eaves to damn..The temp will be the same throughout opposed to the eaves being much colder than the ridge.
welterweight is offline
Old 10-26-2011, 01:18 AM   #13
Re: Ridge Vent
Originally Posted by welterweight View Post
By installing a ridge vent, you will decrease ice dams because as you said, the ridge won't melt before the eaves and there will be no snow at the eaves to damn..The temp will be the same throughout opposed to the eaves being much colder than the ridge.
Kinda. The idea is to try to keep the entire attic area the same temp as the eaves, not just at the ridge. There is still going to be snow at the eaves if there is snow on the roof.
Old 10-26-2011, 01:20 AM   #14
Re: Ridge Vent
Freeze dry.
Old 10-26-2011, 06:28 AM   #15
enforcer's Avatar
Re: Ridge Vent
Ok..so keep the whole roof the same temp as eaves.. if there can stll be snow on the eaves, there will be snow everywhere else? Or just not neatly as much therefore reducingnthe amount of meltbat the ridge?
enforcer is offline
Old 10-26-2011, 07:04 AM   #16
jmiller's Avatar
Trade: Roofing
Rewards Points: 1,002
Re: Ridge Vent
Via ventilation AND insulation. You haven't mentioned how well the attic is insulated. Pay special attention to the area over the top plate on exterior walls, which is especially hard to insulate if you have a ranch. You need baffles there, at least at the soffit vents*, so you can get the most insulation possible without restricting air flow.
Most ice dams we looked at last year were due to poor insulation near recessed lights, at uninsulated attic hatches, bathroom exhausts vented into the attic, etc.
*Ideally you'd have continuous soffit vents if you're switching to ridge vent. An imbalance exhaust/intake can pull conditioned air from the living space, so technically yes- it could make the house colder in winter.
jmiller is offline
Old 10-27-2011, 06:35 PM   #17
Lavezzo Const's Avatar
Re: Ridge Vent
Adding a ridge vent will make the attic colder in the winter, especially on a metal roof. But with proper insulation, there should be no problems. Its better to add the ridge vent then have none at all. Cuts down on humidity
http://www.lavezzoconstruction.com
Lavezzo Const is offline
Old 10-27-2011, 06:58 PM   #18
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Ridge Vent
colder in the winter? whoda thunk
Tom Struble is offline
Old 10-27-2011, 11:24 PM   #19
Re: Ridge Vent
Yes that is what you are trying to do. Keep the entire roof the same temp. Also in the summer you want to be able to cool off the attic space, soffit vents and a ridge vent let cooler air in through the soffitt and the hot air out through the ridge.
Old 10-28-2011, 11:46 AM   #20
larryb's Avatar
Trade: Retail and insurance repair claims consultant
Rewards Points: 258
Re: Ridge Vent
Proper soffit ventilation with chutes and ridge vent - then make sure your insulation is sufficient.
3RSystems, LLC - Storm Damage Contractor Insurance Claim Sales and Process Training, Hail Reports, and loss report analysis.
larryb is offline
seal gable vents after ridge vent installed? tacoma5050 Roofing 41 06-07-2012 07:32 PM
Ridge Vent issue--- enforcer Roofing 5 04-27-2011 10:16 AM
Ridge Vent for Steep Roof MSBOY General Discussion 4 03-24-2010 09:30 AM
Ridge vent code for fire break? goneelkn Roofing 1 02-14-2010 05:41 PM
ridge vent boman47k Roofing 15 05-12-2009 08:06 AM
