Reasons To Build Roofs Over 4/12 Pitch? (more Dangerous) - Page 3 - Roofing - Contractor Talk
Old 12-23-2018, 12:23 PM   #41
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,136
Re: Reasons To Build Roofs Over 4/12 Pitch? (more Dangerous)
" However, in general terms, low slope roofs (commercial roofs) are those below 2/12 or 3/12 while steep slope roofing would consists of roof pitches above either 2/12 or 3/12 and higher."
Flat Roof: 2:12
Low Slope: 2:12-4:12
Conventional Slope Roof: 4:12-9:12
Higher Slopes: 9:12 - 20:12
Steep Slope: 21:12 and higher
"Steep slope roofing also generally lasts longer than low slope roofing because the systems shed water much more efficiently and generally are subject to less direct U/V activity." - Certainteed
SmallTownGuy is online now
The Following User Says Thank You to SmallTownGuy For This Useful Post:
hdavis (12-23-2018)
Old 12-23-2018, 01:04 PM   #42
ksc1's Avatar
Rewards Points: 132
Originally Posted by hdavis View Post
See installation instructions for steep pitches, you have to add nails and roofing cement.
I thought that was so they don't sag down due to gravity (asphalt/fiberglass). Cedar shingles last far longer on sidewall than on a roof.
ksc1 is offline
The Following User Says Thank You to ksc1 For This Useful Post:
hdavis (12-23-2018)
Old 12-23-2018, 01:36 PM   #43
hdavis's Avatar
Rewards Points: 7,516
Walls are completely different, there are houses aroung here that still have stuff that looks like msr roll roofing with a pattern on the walls. It was put up at least 60 years ago. The houses have probably 12 inch eave overhangs. I'm not saying it's in great condition, but it's still on the wall and still has granules.
hdavis is online now
Old 12-23-2018, 02:08 PM   #44
hdavis's Avatar
Landmark installation, goo the edges down.
STEEP SLOPE
Use six nails and four spots of asphalt roofing cement for every full
laminated shingle. See below. Asphalt roofing cement should meet
ASTM D 4586 Type II. Apply 1" spots of asphalt roofing cement under
each corner and at about 12" to 13" in from each edg
Old 12-23-2018, 03:43 PM   #45
John the Builder
I was gonna get around to mentioning Insul-Brick eventually.
hdavis (12-23-2018)
Old 12-23-2018, 04:29 PM   #46
hdavis's Avatar
Lasts forever, but the downside is it looks like something or other.
Old 12-23-2018, 06:25 PM   #47
GC/carpenter
Calidecks's Avatar
Rewards Points: 15,450
Many homes out here just have a 1/4" to the foot fall. They usually get TPO. very common in areas where ocean veiws are important.
Mike.
_______________
Calidecks is offline
hdavis (12-23-2018)
Old 12-23-2018, 10:21 PM   #48
hdavis's Avatar
Mike.
_______________
I've seen that with height restrictions.
Calidecks (12-24-2018), Rio (12-24-2018)
Old 12-24-2018, 05:02 AM   #49
John the Builder
the mobile home look
hdavis (12-24-2018)
Old 12-24-2018, 08:19 AM   #50
Tom M's Avatar
Rewards Points: 12,718
We have a mean hieght of 35 ft so every cape they add a level to needs a lower pitch roof to maximize the second floor ceiling hieght
Tom M is online now
The Following 2 Users Say Thank You to Tom M For This Useful Post:
hdavis (12-24-2018), Rio (12-24-2018)
Old 12-24-2018, 09:24 AM   #51
hdavis's Avatar
I suppose they could add style by going with a mansard roof...
That wouldn't really look right on a lot of buildings.
Old 12-24-2018, 09:29 AM   #52
hdavis's Avatar
Funkiest roof I know is on a trapezoidal building. The roof eas built by a boat builder, so the ridge is level, and the pitche changes end to end.
You can't snap a line on it....
Old 12-24-2018, 12:28 PM   #53
John the Builder
like Noah's Ark - but capsized?
interesting
Old 12-24-2018, 01:05 PM   #54
hdavis's Avatar
interesting
Exactly.
Old 12-24-2018, 01:50 PM   #55
GC/carpenter
Calidecks's Avatar
Multi million dollar homes on the ocean look. In fact there's many glass and beam homes in those areas.
Mike.
_______________
Seven-Delta-FortyOne (12-24-2018)
Old 12-24-2018, 02:04 PM   #56
Tom M's Avatar
Mike.
_______________
Im picturing Mel Gibson in a dually pulling the stilts of the glass house on Lethal Weapon
Tom M is online now
Old 12-24-2018, 02:35 PM   #57
META's Avatar
Trade: General and Trades
Rewards Points: 2,960
The storage building complex I am presently building has 1/4:12 pitch on the buildings. Being these buildings are "plug and play" kits, there isn't room for sloppy concrete work. We've needed to fur out whole roof structures in order to eliminate the pond that got transferred to the roof from a poor concrete pour.
META is offline
The Following User Says Thank You to META For This Useful Post:
hdavis (12-24-2018)
Old 12-24-2018, 03:32 PM   #58
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 13,390
6/12 is not steep.
A&E Exteriors is online now
The Following User Says Thank You to A&E Exteriors For This Useful Post:
hdavis (12-24-2018)
Old 12-24-2018, 03:38 PM   #59
Originally Posted by NYgutterguy View Post
I consider my 4/12 the Ford Fiesta of the world. I hold my head in shame every time I pull up.
Need a couple dormers up there
Old 12-24-2018, 03:40 PM   #60
Thats for the weight
Flat Roofing is not my Trade! THE BEST Book on Flat Roofs. AlabamaSummers Roofing 30 07-27-2018 08:48 AM
Curious how you'd design & build this pinwheel Finish Carpentry 13 02-02-2014 02:42 PM
Kitchen Cabinet Build CITY DECKS INC Finish Carpentry 70 01-03-2013 07:51 PM
