PVC Coated Aluminum And Copper - Roofing - Contractor Talk
Old 06-08-2019, 04:59 PM   #1
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 1,276
Landed a huge copper gutter job that has pvc coated aluminum fascia. Think the pvc coating is thick enough to prevent the galvanic reaction? Other options are covering the fascia with I&W or applying it directly to the back of the gutter before putting them up.
NYgutterguy is offline
Old 06-08-2019, 05:13 PM   #2
Tom M's Avatar
Rewards Points: 11,308
Re: PVC Coated Aluminum And Copper
Always wondered about this too. Other than cut edges, I have never seen corrosive reaction. If I didn't get a comfortable technical support answer from the aluminum company I would wrap the back of the gutter
Tom M is offline
NYgutterguy (06-08-2019)
Old 06-08-2019, 05:22 PM   #3
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 406
Would be pretty easy to stick some zip tape or something like that to the back of the gutter I would think....how many feet of gutter?
mrcat is offline
Old 06-08-2019, 05:24 PM   #4
water re-locater
I took down a few aluminum gutters a couple of years ago that were only a few years old and there were tons of holes in the bottom. Wooden fascia too.House had copper valleys.
This has me thinking now that since itís the water that essentially creates the reaction that maybe it would work against the pvc aluminum since it would be the back of the gutter. Or maybe just enough moisture could create the problem. ?
Old 06-08-2019, 05:44 PM   #5
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,586
Normally the PVC coating is pretty thick on the fascia or coil. I have seen where coil is completely eat up on treated lumber ,but the coating is still complete, eats away from the back side. Am sure the aluminum company is going to tell you to cover it , just to cover their back side.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
Old 06-08-2019, 06:00 PM   #6
water re-locater
350. Only a roll and bit of a second one of i&w if I cut it up. How many feet in those zip tape rolls I was kinda more just curious about if there would be a reaction
The Following User Says Thank You to NYgutterguy For This Useful Post:
mrcat (06-08-2019)
Old 06-08-2019, 06:26 PM   #7
Randy Bush's Avatar
Why don't you just one of the 4" rolls of flashing tape.
Old 06-08-2019, 06:32 PM   #8
water re-locater
Yea just looked and I actually have a roll here. Back of gutter is 5Ē though Iím sure the 4Ē would keep it away enough from fascia to work.
Randy Bush (06-08-2019)
Old 06-08-2019, 06:43 PM   #9
Randy Bush's Avatar
No drip edge I take it.
Old 06-08-2019, 06:52 PM   #10
water re-locater
Think just on the rakes. Shingles are long enough where wouldnít matter anyway
Old 06-08-2019, 06:54 PM   #11
Randy Bush's Avatar
that will it easier for you with the added tape.
Old 06-09-2019, 06:58 AM   #12
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,204
I wonder if there’s ever been an issue of the copper granules used to prevent mold breaking loose of the shingles and eating away at aluminum gutters?
Big Johnson is offline
NYgutterguy (06-09-2019)
Old 06-09-2019, 08:12 AM   #13
water re-locater
Originally Posted by Big Johnson View Post
I wonder if thereís ever been an issue of the copper granules used to prevent mold breaking loose of the shingles and eating away at aluminum gutters?
When they first came out I thought there would be. Havenít seen any signs at all. Maybe not enough granules to create the reaction?
Old 06-09-2019, 08:46 AM   #14
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 845
Also makes me wonder if a strip of copper at the ridge to prevent algae on the shingles would eventually eat at the gutter. Hmmm? I was just thinking about doing this to my own roof.
nicko
"Quality work for those who know the difference"
nickko is offline
Old 06-09-2019, 12:22 PM   #15
water re-locater
nicko
Not sure if it something over time that can cause an issue or not but Iíve never seen or heard of the regular aluminum gutters we all install developing an issue from that strip or the shingles.
Between all the houses we install where we remove old gutters and all the ones I just look at year after year itís something I think I would have definitely come across. .
032 gauge aluminum might deal with it better than say a piece of trim coil. Other option is I could have no idea what Iím talking about
Old 06-13-2019, 08:18 AM   #16
Gutter Hanger
CrescentGutter's Avatar
Trade: Seamless gutters
Rewards Points: 671
nicko
I stripped and shingled my own garage last weekend. I used a zinc strip as algae prevention.
I tore my old gutters down and will replace them as soon as I get a minute away from putting gutters on other people's homes. Time will tell how things react.
Time loves to be wasted. From that waste there is no salvage. - Henry Ford
CrescentGutter is offline
Old 06-14-2019, 04:34 PM   #17
builditguy's Avatar
Rewards Points: 2,078
Keep in mind, PVC coated coil stock is no different than regular coil stock. They just apply the paint, really thick, to get the wood grain look.
The paint is the same.
builditguy is offline
Old 06-14-2019, 05:17 PM   #18
Randy Bush's Avatar
I don't think I have ever seen a case where it was corroded front to back through the PVC painted coating , always back to front as in the case of being putting over PT with a flashing or warp barrier.
Old 06-15-2019, 10:00 AM   #19
builditguy's Avatar
Same here.
Old 06-15-2019, 10:26 AM   #20
water re-locater
Maybe Iím Overthinking this.
