Which Is The Proper Roofing Felt To Use? - Page 2 - Roofing - Contractor Talk
Old 04-10-2012, 09:51 PM   #21
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 322
Re: Which Is The Proper Roofing Felt To Use?
Many of the synthetics actually offer far more traction when wet than felt, and are tear-resistant as well. The only downside is that they do tend to be more expensive, so a lot of builders elect to save a kopeck or two.
Tinstaafl is online now
Splinter hands (04-13-2012)
Old 04-11-2012, 06:10 AM   #22
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Originally Posted by CSinMa View Post
not quite sure what that means Tom, what IS why?
why is what you want an underlayment to do,whether wind resistance, walkabiliy,exposed durability, air infiltration etc.. then choose it accordingly
Tom Struble is offline
CSinMa (04-11-2012)
Old 04-11-2012, 06:41 AM   #23
CSinMa's Avatar
Trade: more Pro than Con
Rewards Points: 75
isn't felt paper of any kind just for expansion and contraction of different materials, to make sure nothing buckles, binds or gets snagged?
I've seen it done once from a distance !
CSinMa is offline
Old 04-11-2012, 12:15 PM   #24
Trade: siding
Rewards Points: 20
if thats what you need to do then any paper will do,even rosin
but lets think about this for awhile..what else would be important on a roof?
Old 04-11-2012, 05:57 PM   #25
jmiller's Avatar
Trade: Roofing
Rewards Points: 1,002
The most important job (on shingle roofs) of the [underlayment] is being a secondary drainage plane- in case of blow offs, or an ice dam backs up under the shingles, or the roofers didn't do the valley right, etc.
jmiller is offline
Old 04-11-2012, 06:04 PM   #26
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Unfortunately tar paper of any kind was considered optional around here for years. Going to be tons and tons of roofs to do in a few more years.
ohiohomedoctor is offline
Old 04-11-2012, 08:54 PM   #27
Groutface
Groutface's Avatar
Trade: flooring installer
Rewards Points: 524
Not a roofer at all but I do my own and it doesn't leek. I used tar paper under the whole install.....good or bad..
Groutface is offline
Old 04-11-2012, 08:57 PM   #28
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
That's good.
katoman is offline
The Following User Says Thank You to katoman For This Useful Post:
Groutface (04-11-2012)
Old 04-11-2012, 09:07 PM   #29
Gary H's Avatar
Rewards Points: 2,342
back in the 80's builders found a loop hole to not use felt. I always wondered what those plywood sheets look like now?
Gary H is offline
Old 04-13-2012, 06:04 PM   #30
Splinter hands's Avatar
For me personally I never use 15# 30# is min. and prefer synthetic if the H.O will go for the extra cost. TNT mentioned it being slick and it is slicker than felt if it is wet, real slick, but when it is dry most of it is nice and grippy to walk on and it wont tear out on you. The extra cost is worth the grip on a steep roof. Another thing to remember is to not be a cheap a** and cover up the Ice shield with felt or the syn. felt also, otherwise if it's a hot day when you go to tear off the old shingles those last few rows sometimes stick to the I&W like superglue.
Splinter hands is offline
Old 04-13-2012, 06:05 PM   #31
What was the loophole? Curious what the excuse was.
Old 04-14-2012, 02:28 PM   #32
CSinMa's Avatar
Rewards Points: 75
Here's the real purpose of the felt paper under shingles.
As warm moist air rises, it passes through the sheetrock ceiling in your home and up through the attic.
The felt paper allows the moist air to pass through, but if some of the moisture condenses on the underside of the shingle, the felt paper keeps that condensed moisture from touching the wood.
If the condensed moisture were to be in contact with the wood, over time the wood would be damaged.
The other reason for the felt underlay is to provide a simple barrier between the asphalt in the shingles and the wood sheathing. The sap in the wood isn't good for the shingles.
On the low pitch roofs, under 4:12 but over 2:12, a double underlayment is required.
not double thickness, like going from 15 lb to 30 lb. But two actual layers.
It also doesn't mean a complete covering of one layer of underlayment, and then another layer of underlayment over the first one.
It means that after one row of felt paper is layed down, the next row needs to start at the halfway point on that first row, not at the top edge of the first row.
CSinMa is offline
Old 04-14-2012, 05:22 PM   #33
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,244
http://arrowheadroofing.com/news/roo...-real-purpose/
Hmmmm? Google search much?
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following 2 Users Say Thank You to TNTRenovate For This Useful Post:
jmiller (04-14-2012), Splinter hands (04-16-2012)
Old 04-14-2012, 05:26 PM   #34
Trade: siding
Rewards Points: 20
i don't buy that condensation won't form under the felt
most synthetics are actually vapor barriers
Old 04-14-2012, 08:05 PM   #35
jmiller's Avatar
Trade: Roofing
The felt paper allows the moist air to pass through, but if some of the moisture condenses on the underside of the shingle, the felt paper keeps that condensed moisture from touching the wood...
Warm air passing through the drywall will condense on the underside of the sheathing, NOT on the shingle side (cold side/top) of the sheathing.
jmiller is offline
The Following 2 Users Say Thank You to jmiller For This Useful Post:
Splinter hands (04-16-2012), TNTRenovate (04-14-2012)
Old 04-14-2012, 08:28 PM   #36
Handyman3970's Avatar
Trade: Renovations and home maintenance
Rewards Points: 75
Hmmm, if these guys are worried about condensation I think they should be adding some ventilation not more layers of felt.
Am I wrong?
Handyman3970 is offline
The Following 3 Users Say Thank You to Handyman3970 For This Useful Post:
SC sawdaddy (04-15-2012), Splinter hands (04-16-2012), TNTRenovate (04-14-2012)
Old 04-14-2012, 10:35 PM   #37
Hair Splitter
Trade: General
Am I wrong?
If their is adequate ventilation, then more won't do anything to prevent the moisture. You really need to address the heat loss at the source. Sealing all areas of penetration would be the first step.
But even at that. Am I supposed to believe that the moisture is going to penetrate the sheathing and tar paper before resting on the underside of the shingles?
Old 04-14-2012, 11:04 PM   #38
Holder of hands
skcolo's Avatar
Trade: Custom builder/remodeler
Almost every attic is under ventilated. Code is 1sf of ventilation for every 150sf of space. Note: A 8" hole for a 1 sf vent doesn't count as 1 sf.
skcolo is offline
Old 04-14-2012, 11:15 PM   #39
Hair Splitter
Trade: General
It would if it were 8x18
Old 04-14-2012, 11:16 PM   #40
Holder of hands
skcolo's Avatar
Then it wouldn't be an 8" hole.
skcolo is offline
Leveling with roofing felt and leveling compound DIA-jp Flooring 29 01-22-2013 09:19 PM
Skyline Roofing USA Launches RoofScamHelp.com Grumpy Roofing 0 04-27-2011 10:02 PM
Aluminum roofing... Jason-F Roofing 5 04-01-2011 09:38 PM
Approval/denial of roofing materials - questions jmasters Roofing 29 11-16-2007 08:09 PM
Production Manager - Roofing (Seeattle WA) raynproof Help Wanted or Looking For Work 0 10-12-2007 04:31 PM
