Patching Leaking Roof - Roofing - Contractor Talk
Old 02-13-2019, 01:40 PM   #1
jdfnnl's Avatar
Trade: carpenter
Rewards Points: 34
Being mostly a carpenter by trade, I do not usually take on roofing jobs, but the house where I currently stay has a failing roof that appears to have been incomplete from the outset. At this transition from ridge to gable there is sunlight visible from below and during a hard rain, water gets in and flows down the ceiling to the wall where the leak becomes noticeable. Clearly there has already been sealant applied over the years but with heat of the summer sun, this acts as little more than a temporary fix. I would like to know how additional flashing could be used to form a proper ridge to gable roof transition. Maybe the top few rows of shingles need to be replaced in order to expose the gable facia and conjoining plywood for a proper course of action? The sunlight is seen both to the side and under the gable facia board where it plunges into the shingles.
jdfnnl is offline
The Following 2 Users Say Thank You to jdfnnl For This Useful Post:
Lettusbee (03-12-2019), Sophie Elise (02-19-2019)
Old 02-13-2019, 08:09 PM   #2
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,840
Re: Patching Leaking Roof
The facia and drip edge should be cut short so that the shingle and cap run all the way to the gable wall. No caulk required.
Home Designer Series Software
B.Johnson is offline
The Following User Says Thank You to B.Johnson For This Useful Post:
TheConstruct (02-13-2019)
Old 02-13-2019, 09:24 PM   #3
avenge's Avatar
Rewards Points: 298
Only reason I could figure why you're seeing daylight is the sheathing is rotted.
avenge is offline
The Following User Says Thank You to avenge For This Useful Post:
Old 03-11-2019, 07:02 PM   #4
Bogie1kenobie's Avatar
Trade: Roofing
Rewards Points: 2
Canít tell from the pic, but since they used roof icing I would guess there is no step flashing under there.
Bogie1kenobie is offline
Old 03-12-2019, 08:20 AM   #5
Joasis's Avatar
Rewards Points: 1,754
And I will give you some free advice here: Do not chase roof leaks on any job you are on, or you will be paying to repair or replace the roof...you will own it when you screw with it.
You know it is leaking, you have told the client it is leaking, the client knows it is leaking.
You say "I am not insured or licensed for roofing", and then stay out of it, or quote them a replacement roof, complete with decking.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
Old 03-19-2019, 08:15 AM   #6
Been around
Mr Latone's Avatar
Trade: Roofing
Rewards Points: 1,650
Put some more caulk on it. The shingle is due for a replacement anyway.
Above all, a good roof
Mr Latone is offline
Metal roof deck to existing shingle roof interface ranmoo Roofing 9 10-16-2017 08:19 AM
flat roof wide open and building flooded madrina Roofing 43 05-29-2013 08:11 AM
Joe Fusco's roof framing calculator bookmdanno Roofing 2 07-18-2012 02:41 PM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
