Old Asbestos Roof Ice Dam - Roofing - Contractor Talk
Old 11-07-2014, 10:00 AM   #1
rservices's Avatar
Rewards Points: 376
I have a customer how has a very old roof, he claims is the original roof 90+ years and it's a very ridged asbestos roof.
He gets ice dams every year and last year water came in threw the attic.
He was wondering if he installed the heated wires over the roof where the ice builds up if it would stop the problem.
I'm not a roofer I work for him in his restaurant doing basic building repairs (tile, drywall painting)
I thought the heated wire would work but with the roof having solid tiles that the normal way of installing the wouldn't work
It looks lie the wires attached to the shingles and with them being hard and smooth, it may require a different type of repair.
Any suggestions would be helpful
Thanks
rservices is offline
Old 11-07-2014, 01:36 PM   #2
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
Re: Old Asbestos Roof Ice Dam
A heat tape would work, weave it up and down the roof 2' from the eve and through the valleys, then in the gutter and down the down spouts. The question is has he had ice damns all along? Did he put in extra insulation and cover the intake vents?
1985gt is offline
Old 11-08-2014, 12:49 PM   #3
muskoka guy's Avatar
Trade: framer/builder
Rewards Points: 558
Is this roof on his house or on his restaurant. Restaurants create very high amounts of heat, which need to be properly ventilated to stop the creation of ice. Even if it is his house, it is most likely a lack of ventilation as well as poor insulation causing the problem. Can you get in the attic or through the soffits to see what kind of insulation and ventilation is present. Adding proper ventilation will usually stop ice build up . Many older homes built without raised heel roof trusses have very little insulation or ventilation above the outside wall due to lack of height in the truss heel. One solution if this is the case is to add an insulated crown moulding on the inside of the wall and ceiling corner. This will allow for additional ventilation to be added above in the roof cavity without losing the insulation. Most buildings lose heat at the corner of the wall and ceiling and that's where the ice builds up when the melted water runs beyond the wall onto the overhang where it refreezes and builds ice.
muskoka guy is offline
Old 11-09-2014, 02:17 PM   #4
Been around
Mr Latone's Avatar
Trade: Roofing
Rewards Points: 1,608
Heat cables can be an effective means to reducing ice dams.
The inexpensive cables from the likes of "Frost King" come with metal clips that slide on to the roof shingles. They may have small prongs which help the clips from coming back off. They are typically designed for asphalt shingle thickness, but asbestos cement tiles aren't much thicker and I would think the clips should work out.
As mentioned, looking at what's causing the problem in the first place, might be a place to start.
Ice cables of this variety are a little awkward to install, but they can work fairly well. They do have a limited life span. You might expect 5 years of service and consider yourself fortunate if they last longer.
Above all, a good roof
Mr Latone is offline
The Following User Says Thank You to Mr Latone For This Useful Post:
Tom Struble (11-09-2014)
Old 12-10-2014, 02:52 PM   #5
arizonaroofresc's Avatar
Trade: Roofing Contractor
Rewards Points: 6
He could try the heating cables, or maybe a heated gutter. Make sure that the roof/attic is also checked for ventilation problems, as they can often cause ice dams as well. Best of luck!
Alan Monzon
Arizona Roof Rescue
arizonaroofresc is offline
Old 12-10-2014, 03:11 PM   #6
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
2 reasons for ice dams.
1) not enough ventilation.
2) not enough insulation.
jlsconstruction is offline
The Following User Says Thank You to jlsconstruction For This Useful Post:
NYgutterguy (12-10-2014)
Old 12-10-2014, 04:13 PM   #7
BamBamm5144's Avatar
Trade: Everything Exterior, Mostly Roofing.
Rewards Points: 2,786
And winter time
BamBamm5144 is offline
Old 12-10-2014, 04:17 PM   #8
stacker of sticks
Rewards Points: 590
Originally Posted by BamBamm5144 View Post
And winter time
Or any other time it gets below freezing
Flat roof drain to municipal sewer - winter freeze? bob_cntrctr Plumbing 10 05-17-2013 02:28 PM
can I add a drip edge to this rubber roof edge? tersh Roofing 3 04-17-2013 02:58 PM
Intersecting Roof On Flat Roof Conversion FullerFramer Framing 5 11-11-2011 11:58 AM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
