No Paper Under Shingles? - Page 2 - Roofing - Contractor Talk
Old 12-21-2014, 09:34 PM   #21
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,100
Re: No Paper Under Shingles?
I also just read that is required to meet UL fire rating.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 12-21-2014, 09:39 PM   #22
YUUUUP!
JWilliams's Avatar
Trade: Metal Roofing Mogul
Rewards Points: 916
I've seen shingles stick to plywood and lap sheathing. Hell I've seen the shingles stick to the felt and the felt and shingles literally tear off in sheets
JWilliams is offline
Old 12-21-2014, 09:40 PM   #23
PatChap's Avatar
Trade: Roofing, eaves
Rewards Points: 132
That it is,but it wasn't when the roofs i tear off were installed. Fibreglass shingles require it for a fire rating, but the old organics didn't.
I'm not arguing for the practice. The only time we don't use an underlay is the very odd new construction roof we do. Simply because its not code required and most builders wont pay for it.
PatChap is offline
Old 12-21-2014, 09:49 PM   #24
mako1's Avatar
Rewards Points: 1,094
I won't lay a roof these days wihout #30 felt.Not roofer just a remodeler who does some roofing and looking to cover my ass..The 15# is like newspaper.I&W is a must too in this area if I'm doing it.Most don't to beat my price.
mako1 is offline
Old 12-21-2014, 09:51 PM   #25
Robs660's Avatar
Trade: Commercial modular
Rewards Points: 81
Yes - the development is in Southern Ontario. I have never seen it and it was unusual for me. It was also weird to see them roofing on a very windy day where the temp was around 29 degrees.
I am use to seeing a job with paper and everything.
Robs660 is offline
Old 12-21-2014, 09:54 PM   #26
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
What are you paying for 30 pound?
If you don't mind me asking
jlsconstruction is offline
Old 12-21-2014, 09:55 PM   #27
mako1's Avatar
I think around $18 a roll.I don't do a lot of roofs but that is close to the last I paid.
mako1 is offline
Old 12-21-2014, 09:57 PM   #28
stacker of sticks
Rewards Points: 590
Check out titanium. It's about $100 for a 10 sq role. So slightly more. It lays flat, and you can walk a 10/12 on it perfectly fine.
The Following 6 Users Say Thank You to jlsconstruction For This Useful Post:
dkillianjr (12-23-2014), jhark123 (01-23-2015), JWilliams (12-21-2014), roofermann (12-22-2014), TNTRenovate (12-21-2014), Tom Struble (12-21-2014)
Old 12-21-2014, 11:23 PM   #29
mako1's Avatar
I'll have to check that out!
mako1 is offline
Old 12-22-2014, 01:01 AM   #30
hdavis's Avatar
Rewards Points: 3,144
Asphalt roofing will lose their lighter fractions i.to wood. That makes them become brittle more quickly. I've seen it both ways, and getting it dried in fast is a major benefit when I'm working alone. Big crews can knock out a good sized roof in a day, so I'm not sure there is a big benefit for them.
Sealed seam roll roofing doesn't have a good way for backside condensation to get out of the structure if you don't use u.derlay.
hdavis is online now
Old 12-22-2014, 06:13 AM   #31
VinylHanger's Avatar
Rewards Points: 10,328
Who still uses felt?
VinylHanger is offline
Old 12-22-2014, 09:17 AM   #32
hdavis's Avatar
I'll use it, but probably not for anything major any more.
Old 12-22-2014, 11:40 AM   #33
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
u.l. listing?..who cares about that?
Tom Struble is offline
Old 12-22-2014, 12:17 PM   #34
Hair Splitter
Trade: General
I don't in particular, just sayin it's something a read.
Old 12-22-2014, 01:57 PM   #35
hdavis's Avatar
Most of the "30#" doesn't weigh close to 30#, Same with "15#". Depends on the ASTM specs they're made to.
Old 12-22-2014, 01:58 PM   #36
hdavis's Avatar
Required egress over a roof - Lifesafety 101.
Old 12-22-2014, 02:21 PM   #37
mako1's Avatar
I know.Actually the main reason I use 30 is because the guys just tear right thru the 15 working on it and then have to patch it.30# is safer to work on and more efficient.
mako1 is offline
The Following User Says Thank You to mako1 For This Useful Post:
hdavis (12-22-2014)
Old 12-22-2014, 02:56 PM   #38
hdavis's Avatar
I haven't picked a synthetic underlay yet, but it seems the way to go to me. Better footing, doesn't tear easily, doesn't wrinkle when it gets wet.
Old 12-22-2014, 04:35 PM   #39
Trade: siding
Rewards Points: 20
well..who cares about that?
you do realize it's because it's tested as an assembly..not necessarily the paper does anything special
Old 12-22-2014, 04:37 PM   #40
BamBamm5144's Avatar
Trade: Everything Exterior, Mostly Roofing.
Rewards Points: 2,786
Just to chime in, I've never had a problem installing or working with 15# felt. In fact, seems like its been used for decades without issues.
Issues will occur with tear offs in the future between the massive amounts of IW people use and the synthetics, which will mark tear offs difficult.
BamBamm5144 is offline
The Following User Says Thank You to BamBamm5144 For This Useful Post:
TNTRenovate (12-22-2014)
metal roofing over shingles Brian Peters Roofing 33 06-15-2016 11:05 AM
Is it ok to see the paper? BCConstruction Drywall 7 11-06-2013 06:54 AM
Whether or not to strip a paper ceiling Ohio painter Painting & Finish Work 23 10-12-2013 07:56 AM
no more 40-year shingles? VAviaCo Roofing 16 07-01-2012 11:30 AM
How to flatten out Curling Dura-Slate shingles? wdcbuilder Roofing 2 09-26-2011 09:45 AM
