New Roof - Roofing - Contractor Talk
New Roof
Old 09-04-2019, 05:51 PM   #1
Mason52's Avatar
Trade: Masonry
Rewards Points: 46
New Roof
Friend had a roof put on with a new ridge vent
They cut the existing deck from end to end
Then just put ridge caps over the opening for about 16 inches then started the ridge vent. Nothing below the shingles. After he caught that the roofer came back removed the ridge vent and scabbed some wood underneath and put the underpayment on top of the new wood and put new cap shingles on over that and put a new ridge vent on. Says it will be fine .. what do you think. It hasn’t leaked yet but do you think it will in the future.
I tried to post pictures but couldn’t get them to upload
Mason52 is offline
Old 09-04-2019, 06:26 PM   #2
hdavis's Avatar
Rewards Points: 4,984
Re: New Roof
How big of a gap was cut in originally and how big of a gap after it was redone?
hdavis is online now
Old 09-04-2019, 07:01 PM   #3
Mason52's Avatar
Trade: Masonry
Rewards Points: 46
Re: New Roof
There wasn’t a ridge vent originally, just regular roof vents. They cut about 2 or 3 inches out full length and just shingled over the hole down past where the ridge vent ended. When the cap shingles were removed you could see right into the attic. Then they came back and scabbed some wood on the first few feet. Then put the underlayment over that and onto the last row of shingles then the cap shingles then put the new ridge vent on.
No gap after they scabbed on the new wood scabbed on pieces were 1x4 stuff
Mason52 is offline
Old 09-04-2019, 09:12 PM   #4
TheConstruct's Avatar
Rewards Points: 1,110
Re: New Roof
I've heard its preferable not to have the sheathing right up to the peak, especially on steeper pitches because it forces the ridge caps to be bent sharply instead of curving over the peak. Roofer asked me to leave the sheathing down 2" from the peak for the entire roof, not just where the ridge vent would be. 3" down sounds like it is getting a bit big but shingles are pretty durable and ridge caps are effectively 3 layers thick. The overhang into the gutter doesn't have sheathing under it...
TheConstruct is offline
Old 09-04-2019, 09:29 PM   #5
hdavis's Avatar
Re: New Roof
The thing about ridge vents is if you can't see into the attic before you put the ridge vent in place, it isn't going to ventilate the attic.
From your description, I don't think it will be more leak prone.
Don't walk the ridge.
Old 09-04-2019, 10:04 PM   #6
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 13,832
Re: New Roof
It is fine...your friend really made him come back for that and scab in some 2" rips?
Consider him lucky the roofer came back and did that. Shingles cure and become quite stiff rather quickly...like a couple months of sunshine. They are easily capable of spanning a small gap and retaining the shape
A&E Exteriors is offline
The Following 4 Users Say Thank You to A&E Exteriors For This Useful Post:
Calidecks (09-07-2019), fourcornerhome (09-05-2019), hdavis (09-04-2019), Seven-Delta-FortyOne (09-04-2019)
Old 09-05-2019, 08:43 AM   #7
Mason52's Avatar
Trade: Masonry
Rewards Points: 46
Re: New Roof
https://i.imgur.com/No1nh2U_d.jpg?ma...idelity=medium
https://i.imgur.com/YMlZVex_d.jpg?ma...idelity=medium
https://i.imgur.com/ED6q0Hh_d.jpg?ma...idelity=medium
https://i.imgur.com/roRFMQYr.jpg
Here are some pics of what I’m talking about and the fix
Roof is about a 5-12 pitch
Last pic is before anything was removed. You can see how the shingles were dipping down into the attic
Mason52 is offline
Old 09-05-2019, 02:46 PM   #8
fourcornerhome's Avatar
Trade: home improvement contractor
Rewards Points: 1,794
Re: New Roof
Yikes !
There's no problem cutting end to end but that hole is way too big.
fourcornerhome is offline
The Following User Says Thank You to fourcornerhome For This Useful Post:
A&E Exteriors (09-05-2019)
Old 09-05-2019, 02:54 PM   #9
John the Builder
SmallTownGuy's Avatar
Rewards Points: 4,152
Re: New Roof
Here are some pics of what Im talking about and the fix
" They cut about 2 or 3 inches out"
Get your tape measure checked ASAP...
SmallTownGuy is offline
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
A&E Exteriors (09-05-2019), mrcat (09-05-2019)
Old 09-05-2019, 03:14 PM   #10
Mason52's Avatar
Trade: Masonry
Rewards Points: 46
Re: New Roof
To late for checking anything just looking for some input
Mason52 is offline
Old 09-05-2019, 04:31 PM   #11
Mordekyle's Avatar
Rewards Points: 4,964
Re: New Roof
Input on what?
The roofer scabbed the plywood and fix the problem. No more prone to leaking than anywhere else.
Mordekyle is online now
Old 09-05-2019, 07:36 PM   #12
Re: New Roof
I stand corrected.
If that gap (looks to be 5" wide) is that big, the top few rows need pulled and redone with a new rip of plywood across the top
Old 09-05-2019, 07:38 PM   #13
Re: New Roof
Has this guy been paid yet?
Old 09-05-2019, 08:55 PM   #14
Mason52's Avatar
Trade: Masonry
Rewards Points: 46
Re: New Roof
Yes he’s paid. Most of it anyway. If you look at the second picture it shows how it was “fixed” where the wood was scabbed in at the open end
The third pic shows the answer to no underlayment.
Mason52 is offline
The Following User Says Thank You to Mason52 For This Useful Post:
A&E Exteriors (09-06-2019)
Old 09-06-2019, 10:30 AM   #15
Re: New Roof
Yes hes paid. Most of it anyway. If you look at the second picture it shows how it was fixed where the wood was scabbed in at the open end
That stinks. I would not expect that roof to last its whole life. Sloppy drip edge and rake starters indicate they were blow and go
Old 09-06-2019, 11:10 AM   #16
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,585
Re: New Roof
If I can hijack off this thread...
Let's say a ridge vent was installed a few years ago, and it was recently discovered that the ridge ply wasn't ripped for ventilation. What's the easiest way to cut some vents from the underside?
This is for about 75', 12-12 over attic space. (family member) The soffit vents are there, as well, but air has nowhere to rise up and out....
Hole saw, again and again?
MarkJames is offline
Old 09-06-2019, 11:38 AM   #17
Re: New Roof
Never had to do this...I would try a multimaster.
Though I think pulling the ridgevent, cutting the slot, and putting on new vent would be the easiest
The Following 2 Users Say Thank You to A&E Exteriors For This Useful Post:
MarkJames (09-06-2019), Mordekyle (09-06-2019)
Old 09-06-2019, 12:20 PM   #18
VinylHanger's Avatar
Rewards Points: 10,858
Re: New Roof
How does that even happen. No decent person would do a job like that. Even a blow and go.
I know stuff happens, but that is just insane.
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
Old 09-06-2019, 12:28 PM   #19
Re: New Roof
I agree. No morals
Old 09-09-2019, 07:49 AM   #20
Mason52's Avatar
Trade: Masonry
Rewards Points: 46
Re: New Roof
I guess all that can be done now is to cross your fingers and hope it doesn’t fail. If it does, then hope the contractor will come back and fix it ..
Mason52 is offline
