New Construction Question - Roof Venting - Roofing - Contractor Talk
Old 05-24-2016, 01:35 PM   #1
Design Build
wallmaxx's Avatar
Trade: well....that was unpleasant
Rewards Points: 3,692
I used to be a framer so forgive my ignorance if such arises.
In new construction I'm seeing a lot of roof hawk vents (like 13 on the back side of the new homes) and very little continuous ridge venting. What are some of the reasons why so many homes do not use continuous ridge venting?
Life - Liberty - Pursuit of Happiness
Freedom is a God-given right
2A is my personal guarantee
wallmaxx is online now
Old 05-24-2016, 02:48 PM   #2
apkole's Avatar
Trade: Residential roofing contractor
Rewards Points: 186
Re: New Construction Question - Roof Venting
I have no answer . . . however I've been seeing the same thing here in West Michigan. Looks terrible. I can't imagine there's any kind of significant savings using the roof vents.
apkole is offline
Old 05-24-2016, 06:34 PM   #3
Tom M's Avatar
Rewards Points: 12,694
I don't see a good reason, it's a math thing. Maybe builder has had a bad experience with blow off ridge caps.
Tom M is online now
Old 05-24-2016, 06:38 PM   #4
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 504
Pods are cheaper and vent better, and some of the older ridge vents were prone to leaking.
Warren is offline
The Following User Says Thank You to Warren For This Useful Post:
wallmaxx (05-24-2016)
Old 05-24-2016, 07:04 PM   #5
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,562
i was gonna say a ridge vent is probably more likely to leak
Airdrie AB Renovation Contractor | Kitchen Renovations | Basement Developments | Facebook
JT Wood Construction Serves Airdrie, Cochrane, Olds, Mountainview, Rockyview and Crossfield, Alberta.
JT Wood is offline
Old 05-24-2016, 09:23 PM   #6
windowsonwashington.net
WindowsonWash's Avatar
Trade: Exterior Construction
Rewards Points: 1,178
Its ugly as sin if you ask me and while the pods do probably provide more NFA in that comparison, I have also seen those things leak if the rain is right.
Windows on Washington
WindowsonWash is offline
Old 05-25-2016, 08:00 PM   #7
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Decks, Siding, & Additions
Rewards Points: 15,472
They are cheaper.
A&E Exteriors is offline
Old 05-25-2016, 08:02 PM   #8
I have only ever once seen ridge vent leak. No cap was run under the edge. Fixed probably literally 1000+ leaky pot vents though
The Following User Says Thank You to A&E Exteriors For This Useful Post:
WindowsonWash (05-26-2016)
Old 05-25-2016, 09:29 PM   #9
pizalm's Avatar
Rewards Points: 834
I've never seen a ridge vent leak, we never use the pods. The only issue I've seen is guys using to short a nail through the ridge cap.
Sent from my iPad using Tapatalk
pizalm is online now
Old 05-28-2016, 08:00 AM   #10
DFW Roofing's Avatar
Trade: Roofing
Rewards Points: 187
Nothing wrong with ridge vent. Leaks = poor installation in most cases.
Low bid gets the job in new construction and ventilation is often not well thought out. Most common on new construction is a square low profile vent (aka turtle). One of these turtles is only enough for about 150 sq ft of attic and most houses have around half of what they need.
We also see larger and larger houses being built on smaller lots. When this happens house tend to be more square in shape and thus have a more pyramid shaped roof. Plenty of hips but few ridge for vents.
Bert Roofing Inc
10021 Cayuga Dr
Dallas TX 75228
214-321-9341
DFW Roofing is offline
The Following User Says Thank You to DFW Roofing For This Useful Post:
madrina (05-30-2016)
Old 05-29-2016, 07:28 AM   #11
Joasis's Avatar
Rewards Points: 2,012
And just think, we are doing roof decks with spray foam underside, and no vents.
The trend nationally seems to be the MacMansion style high pitch roofs will go away, especially since the insurance costs will kill them off eventually.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is online now
The Following User Says Thank You to Joasis For This Useful Post:
WindowsonWash (05-30-2016)
Old 05-30-2016, 08:27 AM   #12
Nothing wrong with unvented assemblies. At the higher pitch, that thing is cooling off really well to outside and with the SPF on them, no moisture is migrating to the sheathing.
Old 05-30-2016, 08:36 AM   #13
Joasis's Avatar
Nothing gives me greater pleasure then killing traditional thinking that there is but one way to build anything.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
My Facebook Page
Old 05-30-2016, 08:48 AM   #14
I wish you were closer to me to build my ICF dream house.
Old 05-30-2016, 02:32 PM   #15
madrina's Avatar
Trade: roofing and other envied trades
Rewards Points: 1,280
I second that. Leaks are few and far between in ridge vent and pods suck. And they are ugly and it looks like crap. I'm going to go with D it's cheaper and E very few builders/roofers/construction people know anything about proper attic ventilation. They don't even think twice about it.
madrina is offline
Old 05-30-2016, 02:33 PM   #16
madrina's Avatar
Dfw roofing is your office in garland on walnut or forest?
madrina is offline
Old 05-31-2016, 06:09 PM   #17
Design Build
wallmaxx's Avatar
Puyallup, WA
Old 05-31-2016, 07:39 PM   #18
At least they got them equidistantly spaced. Most I see aren't spaced properly.
The Following User Says Thank You to WindowsonWash For This Useful Post:
A&E Exteriors (06-01-2016)
Roof question today at work? Dave in Pa Roofing 23 04-26-2014 10:33 AM
Roof gone Bad! Round Dormers, Anyone have experience with them? stombaugh85 Roofing 10 01-03-2013 09:42 AM
Patio roof venting BoulderBuilder Roofing 9 01-01-2013 01:52 PM
Need Help with Ridge Venting Unusual Pitched Roof MSBOY Roofing 2 03-23-2010 09:50 PM
