Man Made Shingles - Roofing - Contractor Talk
Man Made Shingles
Old 11-07-2019, 10:38 AM   #1
Joe Wood's Avatar
Rewards Points: 784
Man Made Shingles
I've been looking for some man made shingles that have a little flex to them, to roof these draped roof azumaya designs. The roof has a compound curve and I always use cedar shingles which will bend a little to the curves.
I've only handled one type of M M shingle and it was pretty stiff. Are there any out there that can flex, a little anyway??
Joe Wood is online now
Old 11-07-2019, 10:41 AM   #2
Willin's Avatar
Trade: Retired
Rewards Points: 498
Re: Man Made Shingles
Steel might work.
Willin is offline
Old 11-07-2019, 10:43 AM   #3
Joe Wood's Avatar
Rewards Points: 784
steel shingles? Wouldn't they buckle when bent?
Old 11-07-2019, 01:10 PM   #4
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 72
Aren't all shingles man made?
Do you mean like plastic or composite shingles?
Andy.
ScipioAfricanus is online now
Old 11-07-2019, 01:14 PM   #5
Radical Basement Dweller
Robie's Avatar
Rewards Points: 1,340
https://www.customshingles.com/
When the debate is lost, slander becomes the tool of the losers.
Robie is online now
Old 11-07-2019, 01:35 PM   #6
Joe Wood's Avatar
Rewards Points: 784
I mean a composite shingle of some sort, not cedar or another wood species but they need to have a little flex to bend down a bit in to those curves.
thanks for that link Robie I'll give them a call!
The Following User Says Thank You to Joe Wood For This Useful Post:
Robie (11-07-2019)
Old 11-07-2019, 10:05 PM   #7
Mordekyle's Avatar
Rewards Points: 5,120
Can you use ridge cap? 10 at a time would take a while, but certainly no longer than cedar.
I cut some ice and water shield into 10 x 10 shingles to wrap around the Doug Fir sticking up through the middle of my treehouse.
Mordekyle is online now
Old 11-07-2019, 11:15 PM   #8
Joe Wood's Avatar
Rewards Points: 784
I think you misunderstand. I need a faux shingle, instead of cedar shingles, that is slightly flexible and can be installed over skip sheathing.
Old 11-08-2019, 12:38 AM   #9
Mordekyle's Avatar
When I read composite, I think asphalt.
Old 11-08-2019, 08:42 AM   #10
Joe Wood's Avatar
Rewards Points: 784
yeah me too, what's the proper name then?
Old 11-08-2019, 10:58 AM   #11
John the Builder
SmallTownGuy's Avatar
Rewards Points: 5,322
composite cedar shakes
https://www.google.com/search?q=comp...hrome&ie=UTF-8
SmallTownGuy is online now
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Mordekyle (11-08-2019)
Old 11-09-2019, 07:20 PM   #12
META's Avatar
Trade: General and Trades
Rewards Points: 5,032
https://www.cedur.com/
META is offline
The Following User Says Thank You to META For This Useful Post:
Calidecks (11-09-2019)
Old Today, 10:22 AM   #13
Joe Wood's Avatar
Rewards Points: 784
Yeah those Cedur are probably what we'll go with. Most all of the others have a grid pattern on the back for support which will look awful from underneath like this first pic. The next two are the Cedur, then the view from underneath which needs to look nice also.
Man Made Shingles-1.jpg   Man Made Shingles-a1.jpg   Man Made Shingles-b1.jpg   Man Made Shingles-img_5433.jpg
