Installing Shingles Without Any Underlayment - Roofing - Contractor Talk
Old 11-04-2016, 10:29 AM   #1
roofermann's Avatar
Trade: roofing, siding, windows
Rewards Points: 259
Have seen many many pics (in other forums) of Canadian roofers putting shingles on with no underlayment other than I+W on the eaves and valleys. They swear it's code compliant. But every set of manufacturers instructions I've seen seen shows underlayment is needed for the material warranty. Can any Canadians explain this please?
roofermann is offline
Old 11-04-2016, 10:41 AM   #2
CharlieDelta's Avatar
Trade: Carpentry/Building/Remodeling
Rewards Points: 1,662
Re: Installing Shingles Without Any Underlayment
Does IRC cover builders code in Canada?
IBC R905.1.1 has an entire table based on the roof covering and pitch as well as the correct underlayment.
CharlieDelta is offline
The Following User Says Thank You to CharlieDelta For This Useful Post:
roofermann (11-04-2016)
Old 11-04-2016, 02:39 PM   #3
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 196
We follow the National Building Code and each Province (State) has its own Building code as well.
Don't know if it is code or not, but I place some sort of membrane down under shingles or metal roof. At least black building paper if not the heavier felt.
jlhaslip is offline
Old 11-04-2016, 04:15 PM   #4
RossDesignBuild's Avatar
Trade: Builder/Designer/Carpenter
Rewards Points: 584
Very common when using zip sheathing.
RossDesignBuild is offline
Old 11-04-2016, 04:56 PM   #5
John the Builder
SmallTownGuy's Avatar
Rewards Points: 7,804
Does make one wonder what the "International" stands for in International Residential Code (IRC)/IBC.
SmallTownGuy is online now
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
CharlieDelta (11-08-2016), roofermann (11-04-2016)
Old 11-05-2016, 02:43 PM   #6
BucketofSteam's Avatar
Trade: renovations
Rewards Points: 7,631
In my experience trying to get a manufactures warranty is like herding cats.
As for it being code compliant you don't need it but any roofer worth his reputation uses it because it's a good idea.
BucketofSteam is offline
Old 11-05-2016, 04:55 PM   #7
jlhaslip's Avatar
Rewards Points: 196
It might be that the National Code we use is based on IRC, but I don't have any indication that it is so.
jlhaslip is offline
Old 11-05-2016, 08:41 PM   #8
PatChap's Avatar
Trade: Roofing, eaves
Rewards Points: 132
Not required in Ontario, sort of. We have to bring a minimum of #30 12" past the inside wall, but only below 8/12 pitch.
They make different wrappers for us, only recomending its use.
Pretty common to paper everything these days, except in new work where its still pretty rare.
New work pays very well here, but not well enough for me to paper em on my dime.
PatChap is offline
The Following User Says Thank You to PatChap For This Useful Post:
hdavis (11-30-2016)
Old 11-05-2016, 11:40 PM   #9
BamBamm5144's Avatar
Trade: Everything Exterior, Mostly Roofing.
Rewards Points: 2,786
I agree roofermann but then again I still know of guys who hand write their time cards
BamBamm5144 is offline
The Following User Says Thank You to BamBamm5144 For This Useful Post:
roofermann (11-09-2016)
Old 11-08-2016, 07:19 PM   #10
prolongroofcare's Avatar
Trade: roof cleaning
Rewards Points: 128
I know we all put on underlayment but you have to admit it is like wearing two pair of underpants or as they used to say suspenders and a belt. I tight roof is not going to leak and the underlayment is superfluous. When it does start leaking the underlayment is going to save you for a little while until the shingles just plain fail, I suppose.
I always put on underlayment 'cause I don't want to go commando.
Tony
Pro Long Roof Care & Gutter
prolongroofcare is offline
The Following User Says Thank You to prolongroofcare For This Useful Post:
Old 11-08-2016, 08:00 PM   #11
Lazy Millennial
Youngin''s Avatar
Rewards Points: 448
Always see underlayment put on here in Alberta.
Originally Posted by mnld View Post
Home Depot... you can glue it, we can help!
Youngin' is offline
Old 11-30-2016, 09:34 AM   #12
madmax718's Avatar
Trade: General
Rewards Points: 3,272
Underlayments are required as a moisture management as well. I guess you could technically get away with it, but when the shingle blows off, that underlayment is all that is saving the sheathing from getting wet.
madmax718 is offline
Old 12-07-2016, 10:58 AM   #13
http://homeevolution.net/
sandul21's Avatar
Trade: Roofing,Siding, and Window replacement
Rewards Points: 26
wow i can't believe they don't add an underlayment. We use synthetic for all of our roofs and im wondering how they manage in the winter with all the snow. Can't imagine the calls they probably get for leaks, maybe its a scheme to get more business lol.
sandul21 is offline
Installing grab bars in fiberglass tub shelf guy Kitchens & Baths 26 09-22-2015 01:42 AM
installing ice and water shield in winter manny123 Roofing 24 11-28-2012 06:31 PM
Paint on underside of shingles? climb.on Painting & Finish Work 31 08-28-2012 07:57 PM
Diamond shaped shingles Jason Whipple Roofing 15 08-25-2012 08:33 PM
best primer , and paint for cedar shingles Spike7 Painting & Finish Work 14 07-29-2012 10:36 AM
