IKO Shingle Stair Step Pattern - Roofing - Contractor Talk
Old 01-31-2019, 09:39 AM   #1
Flashpoint's Avatar
Trade: General
Rewards Points: 20
Hello group.
I'm having trouble running down a technical reason for an aesthetic issue with Cambridge shingles whereas when doing offset/diagonal installation, you end up with diagonal patterns or stair-stepping of colors, often going in the opposite direction of the way the shingles were laid.
I see this on multiple jobs/homes now that I'm aware of it. On some jobs it looks terrible. Seems to always happen with architectural singles with alternating shades/colors.
On this job, shingles were laid in proper offset by crew, and installed diagonally up and to the left. Shingles were pulled from a single bundle at a time. Multiple diagonal patterns can now be seen going up and to the right. IKO rep had no explanation. No one seems to know. But this effect is unpleasing to the customer.
Note the photo attached. I'm talking about the alternating light/dark colored patches that go up and to the right. The patterning stops about 2/3 of the way through the job, this after I made a point of it.
Anyone know how to avoid this?
Is it solved by laying shingle side by side? Or is it necessary to mix bundles? Thanks for any technical insight
IKO Shingle Stair Step Pattern-20181110_135710-crop-1.jpg   IKO Shingle Stair Step Pattern-20181110_135710-crop2.jpg
Flashpoint is offline
Old 01-31-2019, 09:34 PM   #2
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 320
Re: IKO Shingle Stair Step Pattern
Don’t lay IKO shingles. Problem solved. They are junk, and their warranty is junk. IMO
I can't compete with hacks.
donerightwyo is offline
The Following 2 Users Say Thank You to donerightwyo For This Useful Post:
A&E Exteriors (02-02-2019), Lady Dreamer (01-31-2019)
Old 01-31-2019, 09:46 PM   #3
Lady Dreamer's Avatar
Trade: Roofing and General Contracting
Rewards Points: 778
Originally Posted by donerightwyo View Post
Donít lay IKO shingles. Problem solved. They are junk, and their warranty is junk. IMO
I think A&E would say the same thing!
Lady Dreamer is offline
The Following 3 Users Say Thank You to Lady Dreamer For This Useful Post:
A&E Exteriors (02-02-2019), donerightwyo (01-31-2019), Flashpoint (02-01-2019)
Old 01-31-2019, 10:30 PM   #4
Texas Wax's Avatar
Rewards Points: 1,728
IKO is IKO, always been a 'lesser' brand, imo. Required some extra effort for early architectural style shingles, especially, to get an even look.
OP's Issue, Where the directions followed here steps 11 and 12 specifically. Not designed to be stair stepped the entire roof. 4 row step starting with full, then that repeated above it. Even following the directions that often happens. Been that way since the early to mid 80's.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
The Following 3 Users Say Thank You to Texas Wax For This Useful Post:
Flashpoint (02-01-2019), Lady Dreamer (01-31-2019), TheConstruct (02-01-2019)
Old 02-01-2019, 09:48 AM   #5
Flashpoint's Avatar
Trade: General
Rewards Points: 20
Tank you for the replies!
I should have mentioned that half the roof on this one job is already done in IKO.
So I'm hearing a couple of answers: One is that with IKO, it's very difficult to lay a 'pattern free' roof, correct?
I've read IKO's guidance before, including steps 11 and 12, and as far as I know, that offset method was followed (I asked and witnessed) but it appears that even with that routine (4 or 5 courses offset properly) the 'patterning' can still occur.
If IKO is used, and you want a truly random looking application, can this be achieved by mixing bundles? I've read about as many as four bundles being mixed at a time.
Without mixing bundles, can this effect be avoided by looking at and picking different shingles?
Or is it that IKO has shingles with repeating patterns and it is a lost cause with that line.
Any shingle lines better to avoid this? What about Certainteed Moire Black?
Thanks!
Old 02-01-2019, 08:01 PM   #6
Mordekyle's Avatar
Rewards Points: 4,824
Thanks!
CT Moire Black is pretty uniform
Mordekyle is online now
The Following User Says Thank You to Mordekyle For This Useful Post:
Flashpoint (02-04-2019)
Old 02-01-2019, 08:02 PM   #7
Mordekyle's Avatar
Old 02-02-2019, 11:07 AM   #8
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 13,650
Don't buy IKO's. Problem solved
A&E Exteriors is online now
The Following 3 Users Say Thank You to A&E Exteriors For This Useful Post:
donerightwyo (02-02-2019), Lady Dreamer (02-02-2019), SouthonBeach (02-02-2019)
Old 02-02-2019, 11:09 AM   #9
Thanks!
Malarkey, Certainteed, OC Durations
The Following User Says Thank You to A&E Exteriors For This Useful Post:
Old 02-02-2019, 12:39 PM   #10
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 628
Where you been? Was starting to wonder if the lady had offed you so she could get back on here lol.
mrcat is offline
The Following User Says Thank You to mrcat For This Useful Post:
Old 02-02-2019, 04:47 PM   #11
Rewards Points: 778
OMG I can't stop laughing!!!!
The Following User Says Thank You to Lady Dreamer For This Useful Post:
mrcat (02-02-2019)
Old 02-02-2019, 04:52 PM   #12
Rewards Points: 778
Someone else said almost the same thing yesterday. I am starting to wonder what all he has told y'all about me!!! Lol
Old 02-02-2019, 10:05 PM   #13
mrcat's Avatar
Rewards Points: 628
Only good things, I promise
mrcat is offline
The Following 2 Users Say Thank You to mrcat For This Useful Post:
A&E Exteriors (02-03-2019), Lady Dreamer (02-02-2019)
Old 02-04-2019, 11:13 AM   #14
Flashpoint's Avatar
Trade: General
Rewards Points: 20
Mordekyle Thanks for the pics. A neighbor has the CT Moire Black with no visible patterns. Contractor for that job swears they mix bundles on all jobs, so perhaps it is needed for CT also, not just IKO Camb.
Old 02-04-2019, 11:27 AM   #15
Mordekyle's Avatar
Fwiw, I never mix bundles intentionally and donít see any patterns. The Moire Black seems especially uniform.
Iíve even used a leftover bundle of granite or Georgetown gray on a different roof and have not seen a discernible difference.
Happy with CT shingles. A couple bucks more/sq. than Malarkey but I have no reason to switch.
Old 03-30-2019, 03:38 PM   #16
Advancedroofing's Avatar
Trade: Roofing
Iko is well known for this. Use a different manufacturer. We like Certainteed very reliable and stand behind their product. Iko and bp are about the worst you can use.
Justin
Http://advanced-roofing.ca
Advancedroofing is offline
Water Proofing an exterior stair case Trafly Carpentry 9 06-22-2014 10:12 AM
Certainteed Horizon Shingle Castle Roofing Roofing 14 11-21-2013 05:45 PM
Spiral stair set up questions festerized Welding & Steel Trades 18 01-19-2012 10:51 PM
Modify an old winding stair?? builditright Carpentry 5 01-24-2011 11:03 PM
Joining shingle roofs on connected structures. . . UALocal1Plumber Roofing 8 07-16-2010 04:06 PM
