High Water Table = Shorter Roof Life? - Roofing - Contractor Talk
Old 12-17-2007, 11:48 PM   #1
Pavola's Avatar
Rewards Points: 75
There's a few subdivisions built in the 70's around here with high water tables so all the homes are built on slabs. An experianced roofer (36 yrs) working for me has speculated that the roofs and the plywood are failing quicker because of this. He has seen these homes re-roofed on average 10-12yrs. The ventilation and insulation have been improved, at least on the ones he's worked on, so it does have me wondering. I could see were subpar vapor barriers in these old slabs or the humid air drawn into the attic would contribute to the problem. Have any of you noticed this and is there any data or studies done on these conditions?
Pavola is offline
Old 12-18-2007, 07:11 AM   #2
tinner666's Avatar
Rewards Points: 1,000
Re: High Water Table = Shorter Roof Life?
No clue. But I've seen so many early failures, I only expect, and tell my clients, to only expect 1/2 the life spec'd on the bundles. Some roofs do make it, but a lot don't.
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 12-26-2007, 02:09 PM   #3
armawichita's Avatar
All depends on each home. Could have an issue where the air leaving the home and coming in the home is increasing the humidy levels causing the roofs to decay. If you can solve or decrease the amount of air coming and leaving the home you should eliminate the roof related issues you see in these homes.
Sincerely yours
Zerodraft Solutions
[email protected]
armawichita is offline
Old 12-26-2007, 05:31 PM   #4
Pavola's Avatar
Rewards Points: 75
What do you mean by stack pressures? Explain further if you could.
Pavola is offline
Old 12-26-2007, 08:18 PM   #5
Tom M's Avatar
Rewards Points: 11,138
Stack pressure is the natural effect of warm air rising and cold air falling. The only real reason any roof should fail is lack of ventilation from extreme cooling, drying and temperatures difference on opposite sides of the plywood surface. However no one holds a receipt for 20yrs on a roof for one thing and it will look like hell by then anyhow. I can say I have seen asphalt shingles last beyond 20yr on occassion too. The shoddy work pumped out in developments at any time in history is no help. Even today many framers continue to leave no space for plywood seams as the dimensional lumber shrinks the plywood buckles and breaks the shingles.
Tom M is offline
Sloping a mansard roof but not distorting trim personalt Framing 2 10-07-2007 09:38 PM
#&*@! Water Hammer! Mike Finley Plumbing 19 02-22-2007 11:47 PM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Metal Roof tied to a Shingle Roof? JackOfAllTrades Roofing 2 11-15-2005 12:00 PM
Pricing question for Baltimore rowhome roof AmateursGuide Roofing 11 11-10-2005 03:15 PM
