Gutter Outlets- How Do You Make The Holes? - Roofing - Contractor Talk
Old 05-30-2016, 03:51 PM   #1
VT Roofs's Avatar
Trade: Roofing
Rewards Points: 26
I've for years used the Omni 3x3 with 5" gutters, I've always used 3"x4" pipe. Setting up a new trailer with 6" machine I need another tool. The descriptions I've found for the Omni say 5" only.
I do see a Malco 3x4 x punch/die that's new.
Thanks in advance!
VT Roofs is offline
Old 05-30-2016, 04:34 PM   #2
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 1,246
Re: Gutter Outlets- How Do You Make The Holes?
. 3 3/8 hole saw. Simple and can pop hole while up if need be. I have 3x4 oval and 3/38 punches if you want. Let me know I don't use them. The 3 3/8 pop ins are about .60 each at place I order from.
NYgutterguy is online now
Old 05-30-2016, 04:37 PM   #3
water re-locater
Have a bunch in the shop
Old 05-30-2016, 07:22 PM   #4
VT Roofs's Avatar
Trade: Roofing
Rewards Points: 26
It's not the .60 as much as ease. Thanks!
VT Roofs is offline
Old 05-30-2016, 07:30 PM   #5
water re-locater
The hole saw is real easy it's a no brainer. Those outlets are like $1.00 everywhere was just saying I know of a place where they're better and cheaper if you're interested.
Wasn't implying you're a cheap Bastid cause you won't fork over .60
The Following User Says Thank You to NYgutterguy For This Useful Post:
VT Roofs (05-30-2016)
Old 05-30-2016, 07:31 PM   #6
water re-locater
These are them
Old 05-30-2016, 07:40 PM   #7
VT Roofs's Avatar
Trade: Roofing
Rewards Points: 26
The man who taught me balked at the cost- he made his own elbows, cut his own miters (no strips and no boxes), cut his own straps and swore by the Omni.
VT Roofs is offline
Old 05-30-2016, 07:50 PM   #8
water re-locater
Every area is different. Most areas around me Guys use box mitres. When I go into NJ most guys use strips. Unless it's a funky angle very rarely see a hand cut mitre. Been years.
I'd love to get an elbow machine. I think crescent has one.
CrescentGutter (06-02-2016)
Old 06-02-2016, 07:38 AM   #9
Gutter Hanger
CrescentGutter's Avatar
Trade: Seamless gutters
Rewards Points: 671
I do. I've got a Knudson EL 2002. Not cheap by any means, but I'm sure it's paid for itself in the years I've had it.
Just a much nicer looking job to have the upper elbows in one sweeping piece instead of a pre made elbow/straight piece/pre made elbow. Which also eliminates a few downspout seams. Super nice for doing custom offsets.
As far as downspout holes, I've got 3 Malco punches. 2x3 & 3x4 rectangle and a 3x4 X. To me, outlets are inexpensive and much stronger than using the gutter tabs from an X punch. Buy them a couple hundred at a time and the cost is lower.
With miters, I started out with strips but generally use box miters now. Even though most guys slide a square end into the box miter, I still saw cut them to the correct angle before inserting into the box. Makes one nice tight caulk seam instead of 3. More often than I care to remember I find that corners on the building are not exactly square. Usually there's room to make it work, but a person who knows what they're looking at could see a gap behind the miter/fascia.
Last Labor Day I did a tower/turret type thing. Weird angles. One was 32, another was 35, etc. Those had to be hand fit. Took a little time because I don't do it every day but I'm satisfied with the result.
Time loves to be wasted. From that waste there is no salvage. - Henry Ford
CrescentGutter is offline
The Following 2 Users Say Thank You to CrescentGutter For This Useful Post:
NYgutterguy (06-02-2016), Rio (06-02-2016)
Weep holes in a picture window. RiverBG Windows, Siding and Doors 7 01-23-2015 11:41 AM
Hurd Windows, where are the weep holes Lettusbee Windows, Siding and Doors 13 07-18-2014 08:25 AM
Filling Holes in PT ? We Fix Houses Decks & Fencing 29 02-24-2013 01:59 PM
Seamless gutter questions Aaron5161 Roofing 9 07-26-2011 08:12 AM
