1 - 20 of 41 Posts
My gutter company offers a brand that is supposed to guarrantee to keep gutters clean but they cost 3 times the cost of the gutter themselves. I will look for that info and brand then post it. Other than that I tell people not do any cause whatever gets in doesnt get out. Then the maintence creates a problem by people lifting and breaking fragile shingle edges trying to clear them out of ice or leaves.
From my web site www.midmoguttercleaning.com
Gutter Guards
All gutter guards stop large leaves from entering gutters, but they also allow small organic debris to sit on top and slowly deteriorate into the gutter system. If this organic debris that enters the gutter is not cleaned out on a regular basis, you end up with a layer of thick goo and muck in your gutters. On steep roofs gutter guards also may keep water from entering the gutters by skipping over the top, essentially negating the effectiveness of your drainage system.
If you must install gutter guards, then absolutely make sure you buy ones that allow you to easily see through them to the bottom of the entire gutter. DO NOT BUY PLASTIC GUTTER GUARDS which are not suitable for use in our hot Missouri Summers. We have removed and disposed of thousands of feet of gutter guards and the cheap plastic variety are by far the worst. They actually sag into the gutters during the hot summer months and become a leaf and debris trap rather than a barrier.
Avoid gutter guards that have solid tops and small slits near the front edge. Look for gutter guards that have a larger mesh-type open structure that resembles a fishnet or even a chain link fence. These systems allow you to aim a garden hose nozzle through the guard so that water can flush away the thick organic goo that will collect in the gutter. This will make a mess on the front of your gutters – but your gutter system must be cleaned regularly to operate properly.
Remember, even with gutter guards you will still have to clean and more importantly inspect your gutters regularly.
It all depends on the types of leaves that you have or pine needles or flowering buds or whirlybirds.
Read some of these gutter guard related testing articles and see what this man's opinion is.
None work for all situations.
Cheaper vinyl with small punch outs and a mesh screen laminated work just as well as the ones that cost 4 times as much as the actual gutters themselves.
A larger 3" x 4" downspout will remove the congeastion quicker and will not clog at the orifice asa readily as the smaller 2" x 3" drop outlets and downspouts.
Ed
Gutter Guards
By this comment, I presume you mean the roll out versions, right?
I have had very good experiences with the ones I described above,.
Ed
I do not know about improper installations, but when the 3 footers with the diamond or circular punch outs with the screen mesh laminated to it are properly clipped to the front hem of the gutter trough and properly inserted under the bottom row of shingles, they have not sunken down.
I have seen the same brands and styles installed without being properly clipped or inserted under the bottom row of shingle sag quite significantly though.
They work very well for the cost and I am not one to usually push for the cheaper product if the better one offer a greateer long term value.
Just my personal experiences.
Ed
I think that if the water in the guttters are freezing, it already is going to happen anyways.
Ice dams really occur where the divide between the heated section of the house and the unheated soffit overhang begins.
Better cooler air ventilation assists in reducing that effect.
Ed
I know the theory, but in In we get wide variation in temps, day to night? And it seems that with dark roofs even well ventilated (which most are not) a little sun makes a lot of run off and...
I'm not arguing, just know what I see, and I wouldn't have them. Maybe Chevys and Fords.
I don't have them on my house either, but some consumers feel they MUST have them, or else, God Forbid, they may have to clean out their gutters ocassionally.
Ed
You want to go with the metal ones your roofing supply house offers. Also wait until winter time they will put them on sale. Thats the time to buy. When i had my exterior redone the GC sub out the gutters. He said the leaf guards are to expensive at the moment. But he would keep a eye on his roofing supply this winter. The minute that went on sale he came back and got the money from me to buy them. Stored in his garage then came back in the summer to install them. So i got them for half price.
Gutter guards are rubbish in my opinion. I've seen more residential roofs that have been destroyed at the point where the screen/guard meets the first corse of shingles then I care to remember. They make the home owner think they no longer need to maintain their gutters becuase there's no need to clean the gutters out.
But what happens is the debris gets stuck right at the point where the screens/guards meet the shingles. After two or three years the organic material begins to decay and breaks down the roofing material. In some cases I've seen it completely destory the exposed shingle, the starter, and begin to rot the decking and fascia boards.
For Ed the Roofer
Ed
Ed,
About the vinyl with the diamonds. I have them on my own house and have done well now for 7 yrs. Just cleaned the gutters out 1 time of some minimal debris last year.
Question ? The ones I have do not have the screen mesh over the diamond punch out. I thought the screen would eventually clog up with debris / cause water to run over top of them, not into the gutter.
I'm replacing some wood trim / rot on the exterior of a house in a couple of weeks. They also accepted my bid to install 90 LF the vinyl diamond leaf protectors.
Use them with or without the screening ? Your thoughts ?
Thanks
Greensboro, NC
What do you guys recommend for gutter guards? Are they all pretty much the same or are there some that perform much better than others? Thanks
Not all guards work for everything but For a basic screen, we like EZ lock or Diamond Back. Leaf Relief is OK if you are installing it on straight runs..There is a tendency for rain to overshoot the gutters in the valleys.
We have had a lot of great feedback from Homeowners on Leaf Shelter made by US Aluminum.
Ed,
Thanks
Greensboro, NC
Even if leaves or flowering buds remained on the top of the mesh screen laminated to the plastic gutter guard pieces, the water will still drain through. I know this for a fact, because I did a water test with a garden hose to prove it to an elderly woman. Unsightly for a while, yest, but still funtional.
When the leaves get dry, a moderate wind will blow them away. The guards without the mesh will allow a portion of the debris to get trapped in the punch outs, especially whirlybirds from maple trees. Eventually, they too will slowly decay, enter the gutter and get washed out.
Ed
1 - 20 of 41 Posts
