Flat Roof Poor Drainage - Roofing - Contractor Talk
Old 09-28-2010, 07:55 PM   #1
sergeivlad's Avatar
Trade: Painter
Question
Hello,
I was wondering if there a concrete building code requirement for the flat rubber roofs to have an appropriate drainage. The situation with our building is such that the water doesn't drain at all, because the pitch isn't designed correctly. So I am looking for ways to put some pressure on the contractor to fix this. I am in Massachusetts and I found this section of code around roofs, but the language is too technical for me to make sense of it (see the attachment). Can please someone help?
Thanks,
Vlad.
sergeivlad is offline
Old 09-28-2010, 08:43 PM   #2
YUUUUP!
JWilliams's Avatar
Trade: Metal Roofing Mogul
Rewards Points: 916
Re: Flat Roof Poor Drainage
Hey there before we move on why don't you stop off in the intros section and introduce yourself. thanks
JWilliams is offline
Old 09-28-2010, 08:57 PM   #3
Anti-wingnut's Avatar
Rewards Points: 3,422
You may want to take this topic to DIY. It doesn't seem like your a GC, and I doubt that you are even a painting contractor
Anti-wingnut is offline
Old 09-29-2010, 03:06 PM   #4
Grumpy's Avatar
Rewards Points: 2,000
Roofs with no drainage are ok. Infact during WWII roofs were designed to hold water incase the Nazi's bombed us, from air all the standing water on the roofs would look like fish farms or water treatment facilities, not weapon making factories.
What type of roof membrane was installed? Some have no problem holding standing water, and have no invalidation in their warranty. However some do require positive drainage.
What makes you think you have improper drainage or that it's the contractor's fault? Maybe it's the architect's fault for improper design.
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline
Old 09-29-2010, 03:28 PM   #5
genecarp's Avatar
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
genecarp is offline
Tags
flat roof rubber drainage
flat roof vs. gable Iloveneworleans Roofing 17 02-10-2013 10:52 AM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 22 01-05-2013 06:42 PM
Flat roof patio AJAX Roofing 3 09-22-2009 08:13 AM
rubber roof over rolled asphalt ? ? btownpa Roofing 2 03-06-2009 03:03 PM
