Epdm Flashing Questions - Roofing - Contractor Talk
Old 04-03-2019, 08:23 AM   #1
moodybox's Avatar
Trade: carpenter
Rewards Points: 54
Hi: I'm building a second floor deck above a first floor porch, it has an epdm rubber membrane already installed, the decking will end up sitting on pt sleepers. The pt rail posts come up through the rubber and the outside corners of the rail posts still need to be flashed properly. Is it better to use standard epdm membrane material for the outside corners and apply my own adhesive, or better to buy pressure sensitive material that already has adhesive? Do I need to apply 'primer' in either case? I'm reading about 'membrane cleaner', 'primer', 'adhesive'(both solvent and water based). I'm a retired carpenter, no experience with rubber, wondered how a roofer would approach this? This is a small deck with only four rail posts, so don't need much as far as materials. There's no place nearby that sells roofing products, anyone recommend an online store that might sell smaller quantities of things? Thanks
moodybox is offline
Old 04-04-2019, 11:34 PM   #2
finisher65's Avatar
Trade: Drywall/carpentry
Rewards Points: 78
Re: Epdm Flashing Questions
I've been looking at EPDM accessories for a roof I'm about to replace.
Try flatroofsolutions.com
finisher65 is online now
Old 04-05-2019, 10:42 AM   #3
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,264
They make preformed EPDM "boots" for this sort of situation.
Fishindude is offline
Old 04-07-2019, 12:04 AM   #4
GC/carpenter
Calidecks's Avatar
Rewards Points: 8,686
https://www.homedepot.com/p/Trex-Rai...B&gclsrc=aw.ds
Mike.
_______________
Calidecks is online now
Old 04-07-2019, 12:15 AM   #5
GC/carpenter
Calidecks's Avatar
Mike.
_______________
Old 05-20-2019, 07:56 AM   #6
GoodStuff's Avatar
Trade: Roofing & General Contractor
Rewards Points: 102
Seriously?
buy a roll of cover tape and a gallon of primer. Prime the surface with a 4" (cheap, throwaway) brush and cut strips of cover tape to seal the protrusion. See youtube for EPDM roofing - the firestone ones are the best.
Good Stuff Enterprises
www.bestkentuckyroofing.com
"We Worry... So you don't have to!"
GoodStuff is offline
EPDM Joint Seal - What Would You Do? Catldavis Roofing 0 10-07-2018 04:47 AM
New block construction question(s) TLHWindows Construction 2 01-31-2014 01:42 AM
Porch/Deck Hybrid Design Questions... Spencer Decks & Fencing 7 04-27-2013 06:38 PM
step flashing question. Pennyroyal's Roofing 3 04-08-2009 05:56 PM
Flashing, step/pan/wall Burby General Discussion 19 12-24-2008 05:41 PM
