Drip Edge Problem. Advice Would Be Appreciated. - Page 2 - Roofing - Contractor Talk
Old 08-14-2014, 07:49 AM   #21
Rookie roofer's Avatar
Trade: Roofing
Rewards Points: 26
Re: Drip Edge Problem. Advice Would Be Appreciated.
R905.2.8.5 Drip edge.
A drip edge shall be provided at eaves and gables of shingle roofs. Adjacent pieces of drip edge shall be overlapped a minimum of 2 inches (51 mm). Drip edges shall extend a minimum of 0.25 inch (6.4 mm) below the roof sheathing and extend up the roof deck a minimum of 2 inches (51 mm). Drip edges shall be mechanically fastened to the roof deck at a maximum of 12 inches (305 mm) o.c. with fasteners as specified in Section R905.2.5. Underlayment shall be installed over the drip edge along eaves and under the underlayment on gables. Unless specified differently by the shingle manufacturer, shingles are permitted to be flush with the drip edge.
Rookie roofer is offline
Old 08-14-2014, 08:41 AM   #22
jb4211's Avatar
Rewards Points: 2,306
Jon
jb4211 is offline
Old 08-14-2014, 11:57 AM   #23
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Not once does the irc does it ever say drip edge.
This is all it says on the matter.
jlsconstruction is offline
Old 08-14-2014, 12:20 PM   #24
jb4211's Avatar
What year is that quoted from? I have a book from 2009 and I can't find your reference. My book numbers go from R905.2.8.4 to R905.3
Jon
jb4211 is offline
Old 08-14-2014, 12:24 PM   #25
jb4211's Avatar
Drip edge problem. Advice would be appreciated.-forumrunner_20140814_132833.jpg
Jon
jb4211 is offline
Old 08-14-2014, 12:28 PM   #26
Trade: Roofing
Rewards Points: 26
It's from 2012. You can see it online
The Following User Says Thank You to Rookie roofer For This Useful Post:
jb4211 (08-14-2014)
Old 08-14-2014, 12:34 PM   #27
stacker of sticks
Rewards Points: 590
What code book? Icc?
Old 08-14-2014, 02:40 PM   #28
jb4211's Avatar
IRC
International Residential Code
Jon
jb4211 is offline
Old 08-14-2014, 02:44 PM   #29
jb4211's Avatar
ICC is an organization that publishes the IRC
Jon
jb4211 is offline
Old 08-14-2014, 02:56 PM   #30
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 1,512
Never knew drip edge was code. Learn something new everyday. Id say half of the new work i do even has drip edge.
NYgutterguy is offline
Old 08-14-2014, 04:56 PM   #31
stacker of sticks
Rewards Points: 590
Oups I ment ibc
Old 08-14-2014, 05:05 PM   #32
stacker of sticks
Rewards Points: 590
We always use it.
And I was getting a framing inspection at 4 today. So I asked the inspector about it. New York revised it to say "flashing is to be installed to manufactured specifications" 2 months after switching to the 2012 book (along with several other states) because there are too many problems with how they wrote it. It also doesn't say anything about nailing.
On top of that, who ever wrote that in the first place clearly has never torn a roof off and got the the last nail in a stick of drip. Because if they had they would be ok with 3 nails, because it's clearly not going anywhere.
The Following User Says Thank You to jlsconstruction For This Useful Post:
NYgutterguy (08-14-2014)
Old 08-14-2014, 05:31 PM   #33
water re-locater
We always use it.
I install for a few hackish roofers as well as some really decent GC's that put out a nice product and all of their roofers just staple the ice and water to the fascia before i put gutter over it. Some will cover the and ice and water with a 2x2 metal but very rarely do i see drip edge. The rakes they just bend a 3/4 reverse bend at top to act as drip edge along rake. My friend is the local building inspector going to have to pick his brain and see what the deal is. Also ive never heard him ever mention doing roof inspections as far as checking for drip edhe
The Following User Says Thank You to NYgutterguy For This Useful Post:
jlsconstruction (08-14-2014)
Old 08-14-2014, 06:31 PM   #34
Tom M's Avatar
Rewards Points: 168
Im picturing a flying gable rafter with no solid blocking or ladder framing up the slope. I can see that sucker twisting like crazy a year later.
Tom M is online now
Old 08-16-2014, 09:53 AM   #35
kubie's Avatar
Trade: general contractor
Rewards Points: 278
im guessing alumn drip edge. that junk looks like an ocean if nailed too tight.
whenever we have to use it, we install it like vinyl siding. we have a punch that
makes a slot and allows the drip edge to move.
we use steel whenever we can though.
kubie is offline
Old 08-22-2014, 10:34 AM   #36
roof-lover's Avatar
Trade: Roofing contractor
Rewards Points: 302
Yep, use steel and not aluminum.
It's not strong enough to stay straight.
roof-lover is offline
Chimney Advice Appreciated ClosetsNY Masonry Picture Post 3 03-19-2014 12:44 PM
Chimney Advice Appreciated ClosetsNY Masonry 47 03-16-2014 05:05 PM
? about custom bent drip edge in upstate NY woodchuck2 Roofing 8 05-09-2011 09:29 AM
Drip edge...over or under... Jambruins Roofing 17 08-13-2010 03:07 PM
Roofers Briefcase displaying vented drip edge Roofman20033 Roofing 6 06-06-2010 09:44 PM
