Drip Edge Problem. Advice Would Be Appreciated. - Roofing - Contractor Talk
Old 07-28-2014, 10:21 PM   #1
ellisd1986's Avatar
Trade: framing
Rewards Points: 4
I recently installed a roof on a house I'm building with my father. When we put down the drip edge it looked straight and seemed to be laying well. Fast forward a year and were siding the gable ends. Now I have noticeable waves in the drip edge and I'm not sure how it happened because I damn sure know it didn't look like that when we first installed it or else I would have replaced the wavy pieces before shingling. Has anyone had this problem before and if so is there any way of correcting it besides tearing out everything and re shingling. Any advice from a seasoned vet would be much appreciated
ellisd1986 is offline
Old 07-28-2014, 10:32 PM   #2
LeeFowler's Avatar
Rewards Points: 886
Re: Drip Edge Problem. Advice Would Be Appreciated.
Was it really cold when you installed the drip edge?
LeeFowler is offline
Old 07-28-2014, 10:33 PM   #3
hack of all trades
dielectricunion's Avatar
Trade: Electrician
Rewards Points: 2,112
I imagine once the roof heated up and the metal expanded, it got pinched and wavy
dielectricunion is offline
The Following User Says Thank You to dielectricunion For This Useful Post:
LeeFowler (07-28-2014)
Old 07-29-2014, 06:40 AM   #4
ellisd1986's Avatar
Trade: framing
Rewards Points: 4
It was springtime in southern pa when i installed the drip edge. So no it wasn't cold.
Old 07-29-2014, 07:06 AM   #5
FrankSmith's Avatar
Rewards Points: 5,124
My best guess is that it did look that bad last year but you where on the roof side so it was much less obvious. Get back on the roof and peak your head over. I bet the state of the drip edge will be as it was last time you looked at it from up there. Besides that, the top unseen part of the drip egde can look great and the side can be all over the place.
FrankSmith is offline
Old 07-29-2014, 07:10 AM   #6
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
the ''fly'' or gable rafter will move during the season
a) there is no way to fix it
b) it will probably happen again
you could try using shorter pieces of drip which would allow for more movement
Tom Struble is offline
Tinstaafl (07-29-2014)
Old 07-29-2014, 05:35 PM   #7
Trade: siding
Rewards Points: 20
thinking about it a heavier guage would also help
Old 07-29-2014, 07:21 PM   #8
owattabuilder's Avatar
Trade: general
Rewards Points: 278
Spring install vs summer now could be 40 or 50 degrees of temperature difference. That could cause a lot of expansion.
owattabuilder is offline
Old 07-29-2014, 09:32 PM   #9
Red Adobe's Avatar
Trade: Metal Roofs, Sparky , Remodels and beer specialist
Rewards Points: 92
Drip is the one place I like staples used alot of them......perpendicular and only 1 tang thru it....allows for the expansion and no nail head to distort.
Red Adobe is offline
Old 07-29-2014, 10:37 PM   #10
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
Rewards Points: 1,772
Aluminum?
MJW is offline
The Following 2 Users Say Thank You to MJW For This Useful Post:
kubie (08-16-2014), roof-lover (07-30-2014)
Old 07-30-2014, 06:51 PM   #11
Been around
Mr Latone's Avatar
Trade: Roofing
Rewards Points: 1,594
I don't recall ever having an issue with drip or rake unless the surface was not flat or straight.
Pulling nails and replacing rake edge doesn't require pulling off shingles.
How about snapping a picture of this situation?
Above all, a good roof
Mr Latone is offline
Old 08-08-2014, 09:05 AM   #12
Designed2Fail's Avatar
Trade: residential construction
Rewards Points: 306
And you best notch your drip then or it will look like crap. I always notch drip or any metal. I never butt mine it looks more professional.
Designed2Fail is offline
Old 08-08-2014, 01:03 PM   #13
madmax718's Avatar
Trade: General
Rewards Points: 3,272
Nailed too tight?The metal and wood expand at different rates, could have buckled the metal a bit.
madmax718 is offline
Old 08-08-2014, 03:37 PM   #14
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
This right here..... A few years ago we did a roof out of town. Ran short on a few sticks. So I ran to hd for enough to do the dormers ( to keep the slightly different profiles away from each other)
That was the worst crap I've ever used. I usually tap it into place with the top of my gun lightly. The first one completely bent.
But on top of that. I see drip over nailed almost always. I put 4 nails in a 10' stick. Non of this every foot I see all the times, and keep your shingle nails out of it. Just let it float
jlsconstruction is offline
Old 08-08-2014, 03:52 PM   #15
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,576
I think he may have fallen off the roof as he has not returned in quite a while.
Andy.
ScipioAfricanus is online now
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
Tom Struble (08-08-2014)
Old 08-12-2014, 08:22 PM   #16
madrina's Avatar
Trade: roofing and other envied trades
Rewards Points: 1,266
Tear the entire roof off and start over. The ct way.
madrina is offline
Old 08-13-2014, 08:30 PM   #17
stacker of sticks
Rewards Points: 590
A lot better than knocking the house down the mike Holmes way
The Following User Says Thank You to jlsconstruction For This Useful Post:
jb4211 (08-14-2014)
Old 08-13-2014, 09:33 PM   #18
Oldtinman's Avatar
Trade: Manufacturer Sales
IS the drip Edge Aluminum? WHat Gauge? Have you noticed a changed in the buckling with temp changes? Could be nailing? Is it face nailed?
Oldtinman is offline
Old 08-14-2014, 06:30 AM   #19
Rookie roofer's Avatar
Trade: Roofing
Rewards Points: 26
Code requires drip edge to be nailed with a max spacing of 12 inches
Rookie roofer is offline
The Following User Says Thank You to Rookie roofer For This Useful Post:
LeeFowler (08-18-2014)
Old 08-14-2014, 06:38 AM   #20
stacker of sticks
Rewards Points: 590
Not where I come from, and I'd like you to prove that.
And it's going to be hard to do seeing the UFC doesn't even require drip edge
Chimney Advice Appreciated ClosetsNY Masonry Picture Post 3 03-19-2014 12:44 PM
Chimney Advice Appreciated ClosetsNY Masonry 47 03-16-2014 05:05 PM
? about custom bent drip edge in upstate NY woodchuck2 Roofing 8 05-09-2011 09:29 AM
Drip edge...over or under... Jambruins Roofing 17 08-13-2010 03:07 PM
Roofers Briefcase displaying vented drip edge Roofman20033 Roofing 6 06-06-2010 09:44 PM
