Downspout Making Formula - Roofing - Contractor Talk
Old 12-24-2007, 12:43 AM   #1
stlgutters's Avatar
Trade: home exteriors
Hi I've own a seamless gutter company and have been in business since 2001. I went out and bought a machine after working for a guy for one day and have turned into a successful busness. While I would consider myself an excellent gutter installer there a few things that I would like to learn.
First of all how to do a downspout making calculation. I have always measured from a ladder making the fascia to wall piece first and then the bottom length. I can make and hang a single story downspout in 5-10 minutes, but I had a guy working for me for about a week who who had a formula for making the downspouts by taking a fascia to wall measurement and then a fascia to ground measurement. He would then make all the downspouts on the ground at once and then go hang them. His system was about twice as fast as mine. I am much to set in my ways to change but I would like to learn this formula to teach to employees. If anyone knows the formula I would appreciate it.
Another thing I have never learned it how to hand tab a 45 miter. I have always used strip miters. Personally I prefer the looks of them to hand tabbing but It would be a good thing to know if I get stuck on a job far away from a supply house and I end up short on parts or paint.
Thanks
stlgutters is offline
Old 12-24-2007, 10:23 AM   #2
tinner666's Avatar
Rewards Points: 1,000
Re: Downspout Making Formula
Hand-made miters are easy. wall to outside of outlet inches, add 5". If you're right handed, use the right (green) snips to remove 5/8" from bottom half, about 1/2" from top half. When you start cutting feet, cut 3/4" out and use the left (red) snips.
Snip color is important, because it and the cuts make it nearly impossible to fold the miter the wrong way.
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 12-24-2007, 10:52 AM   #3
Tom R's Avatar
Rewards Points: 2,036
Maybe it's just me, - - but I call red snips 'right-handed', and green snips 'left-handed' . . .
Tom R is offline
Old 12-24-2007, 11:04 AM   #4
jmic's Avatar
Rewards Points: 2,000
Thats what I thought.
Joe
jmic is offline
Old 12-24-2007, 11:05 AM   #5
tinner666's Avatar
Try cutting to the right then, with the Left cutting, red snips.
Old 12-24-2007, 11:08 AM   #6
tinner666's Avatar
Blue, BTW are for stainless, but I never found a right cutting blue pair.
https://www.ductcleanersupply.com/sh...products_id=63
Old 12-24-2007, 11:09 AM   #7
Tom R's Avatar
Good 'snippet', but I still say you're standing on your head . . . J/K
Reds cut to the left, - - but would generally be used with your right hand.
Greens cut to the right, - - but would generally be used with left hand.
Therefore, - - I call red 'right', - - and green 'left, - - because that's the hand I'm going to use them with . . .
Tom R is offline
Old 12-24-2007, 04:39 PM   #8
tinner666's Avatar
I cut with the right hand all the time.
Old 12-25-2007, 01:18 AM   #9
Expert Roofer
theroofinggod's Avatar
Trade: ROOFING/HOME IMPROVEMENTS-WINDOWS/SIDING/GUTTERING/COPPER WORK,ETC
Rewards Points: 250
so do I,AND MOST GUYS I`VE EVER WORKED WITH ALSO
"If it`s worth doing.It`s worth doing right!!!
www.ADVANCEDROOFINGNEWYORK.com
theroofinggod is offline
Old 12-25-2007, 09:18 AM   #10
RooferJim's Avatar
Trade: roofing
I will cut with my left sometimes but then again I also write with my left sometimes .
RooferJim is offline
Old 01-01-2008, 01:47 AM   #11
Expert Roofer
Rewards Points: 250
I kind of meant to say that one hand worked all the snips-lol
Old 01-08-2008, 11:15 PM   #12
fogbutt's Avatar
just get used to doing it and it becomes easy
fogbutt is offline
Thinking of making a big change.. ruskent General Discussion 60 10-26-2007 12:09 PM
Soffit Backing Formula RadiusFramer Framing 4 03-28-2007 07:31 PM
What should i be making an hour, i feel way underpaid Little Excavation & Site Work 10 10-08-2006 09:01 AM
wood working/ crafts/ furniture making i_plant_art Carpentry 8 06-13-2006 08:44 AM
What should I be making? Maderan Business 10 05-31-2006 12:07 AM
