Do You Think This Will Leak???? - Roofing - Contractor Talk
Old 01-11-2013, 08:04 PM   #1
stombaugh85's Avatar
Trade: Roofing
Rewards Points: 284
This is a brand new steel roof a so called roofing contractor installed.
If it wasn't for hacks I'd be out of work!
The brown reglet cut counter flashing is the original for the shingles. The black is the new if you couldn't tell
Do you think this will leak????-hack-work.jpg   Do you think this will leak????-hack-work-1.jpg
stombaugh85 is offline
Old 01-11-2013, 08:14 PM   #2
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Re: Do You Think This Will Leak????
Ribbed tin roofs are junk anyways
jlsconstruction is offline
Old 01-11-2013, 08:30 PM   #3
skillman's Avatar
Rewards Points: 1,968
Do your best and caulk the rest .
skillman is offline
Old 01-11-2013, 08:32 PM   #4
Trade: Roofing
Rewards Points: 284
At least caulk the whole thing , not just 3/4
Heck, cant see it from my house.
Old 01-11-2013, 09:36 PM   #5
smeagol's Avatar
Trade: new construction and remodeling
Rewards Points: 638
the original brickies were impressive
smeagol is offline
The Following User Says Thank You to smeagol For This Useful Post:
Tom M (01-11-2013)
Old 01-12-2013, 12:19 AM   #6
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 970
See this a lot and worse. Thats is the problem when shingle roofers try and be metal roofers.
Randy Bush is offline
Old 01-12-2013, 12:21 AM   #7
stacker of sticks
Rewards Points: 590
No roofer should be a roofer if he doesn't know what gravity does to water
Old 01-12-2013, 12:23 AM   #8
Randy Bush's Avatar
Rewards Points: 970
Guess that is your opinion which you are entitled too. Around here a metal roof will way outlast a shingle roof when done right.
Old 01-12-2013, 12:31 AM   #9
stacker of sticks
Rewards Points: 590
If you get 7 years out of the screw gaskets you're doing good here. Standing seams good chit, pain to install. Don't see it on houses to often.
Old 01-12-2013, 12:37 AM   #10
Randy Bush's Avatar
Rewards Points: 970
I don't know maybe it is the type of weather we have . Have put a lot on with no call backs of leaks , 15-20 years so far and have seen other building lots older still ok. I agree standing seam is good just hard to get people to spend the extra for it, but there is getting to be more and more around all the time.
Old 01-12-2013, 12:46 AM   #11
Donohue Const's Avatar
Rewards Points: 1,504
I agree with Randy, a properly installed metal roof will outlast a shingle roof. It goes back to being installed the right way, most people over tighten the screws which makes the washers fail prematurely.
Ryan
www.ryandonohueconstruction.com
Donohue Const is online now
Old 01-12-2013, 05:24 AM   #12
die hard's Avatar
Trade: jack of all rades
It won't leak today .how is the flashing attached to the wall ? If it just silicone when it heats and cool it is going to buckle away from wall .
die hard is offline
Old 01-12-2013, 08:21 AM   #13
Trade: Roofing
Rewards Points: 284
The flashings just pushed next to the original flashing ( which is taller). A thin bead of caulk on the top , but looks like they ran out midway through the process. The flashing on the brick is just pushed against it also,. Cheap walmart silicone used. I garantee it leaks today, the only thing saving the roof is the old existing roof. This is a seasoned local roofer , "been doing it this way for 20 years" he says, "never had a problem, ".
How can you argue with an old experienced idiot?
Old 01-12-2013, 08:35 AM   #14
Ryan
Old 01-12-2013, 08:38 AM   #15
Thats how i like to do the flashing when its on a brick building, cut the new flashing into the brick at an angle. Some people just don't care enough to do it.
Ryan
leak in pex go do it Plumbing 41 10-13-2013 10:22 PM
Under slab leak?? 220/221 Plumbing 9 03-20-2010 11:45 AM
Refrigerant Leak Detection Articles MechAcc HVAC 7 10-09-2009 04:42 AM
Pex tube leak under cement floor jonbjornstad Plumbing 22 12-23-2008 09:44 PM
