Chimney Counter Flashing - Page 2 - Roofing - Contractor Talk
Old 04-24-2014, 06:15 PM   #21
Jhinton's Avatar
Trade: Tradesman
Rewards Points: 126
Re: Chimney Counter Flashing
Thanks for the replys guys. I was beginning to question whether or not I was crazy for insisting that we always cut a reglet and counter flash.
I am not kidding when I say I think I am the only one in the area. Even roofer whom I have respect for tell me I should just be using "5X5" and if they counter at all they use some out of the box garbage with a huge gap at the top to "caulk"...
I think I am going to just make multiple passes with the grinder until the reglet is as wide as I want. I tried using an air chisel and the noise and time make that an impractical option in my opinion.
Jhinton is offline
Old 04-24-2014, 07:20 PM   #22
Renaissance Man
superseal's Avatar
Rewards Points: 5,816
I still think Peter Scholey from Just lead takes the cake on traditional old school techniques using highly appropriate malleable lead flashings all starting with the DPC tray (damp proof course)
Without a tray in place (set by the mason) all chimneys will still have a propensity for leakage throughout the ages no matter how well stepped and countered it is.
Shame there aren't many customers who will pay the price to retro-ft a pan, but no doubt, this is a case of having it done right the first time around.
Cheers to you Peter!
https://www.youtube.com/watch?v=AAdcYazFIio
supersealconstruction.com
superseal is offline
The Following 3 Users Say Thank You to superseal For This Useful Post:
seeyou (09-20-2014), Tom M (04-24-2014), Tom Struble (04-25-2014)
Old 04-25-2014, 11:31 AM   #23
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
Some times surface mount counter flashing is the proper way to do things. Around a shingle chimney it's not.
1985gt is offline
Old 04-25-2014, 01:38 PM   #24
Framing Contractor
FullerFramer's Avatar
Trade: Framing
Rewards Points: 576
This is what I like to do. Best of both methods; one piece of aluminum because it is definitely quicker than dealing with individual pieces, however the aluminum is still bent into a reglet. These pictures were taken prior to tuckpointing the crumbly mortar that was removed. 100 year old house.
Chimney Counter flashing-image-2567255921.jpg   Chimney Counter flashing-image-1041472238.jpg
FullerFramer is offline
The Following 3 Users Say Thank You to FullerFramer For This Useful Post:
Mr Latone (04-26-2014), overanalyze (04-25-2014), QCCI (08-30-2014)
Old 04-25-2014, 09:31 PM   #25
Jhinton's Avatar
Trade: Tradesman
Rewards Points: 126
When would you use a surface mount counter flashing? We very rarely do anything but shingled chimneys and the few that we have done that were not were still cut into the brick.
Jhinton is offline
Old 04-26-2014, 09:48 AM   #26
Been around
Mr Latone's Avatar
Trade: Roofing
Rewards Points: 1,606
If grinding into the mortar for a stepped counter flashing, use the 0.25" wide diamond tuck pointing grinder blade. It will hog out the joint in short order. This leaves plenty of room for turning up the inside edge of the the tucked flashing to get that "spring-lock" grab into the joint. Lead wedges or wool driven with a cold chisel FTW.
Looks great. I think the reason you don't see it often is most shinglers just don't know how.
A lot of stepped flashing, both where the flashing is tucked into the joint and where a separate counter flashing is applied, have the 'peaks' of the step out of line. This can leave the steps looking awkward and I have heard a lot of people comment about not liking the look.
If the steps are more uniform and in line they look great.
Not a chimney, but same idea, I think straight cuts through the brick would be out of character here:
Above all, a good roof
Mr Latone is offline
The Following User Says Thank You to Mr Latone For This Useful Post:
FullerFramer (04-26-2014)
Old 04-28-2014, 12:43 PM   #27
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
Commercial flat work.
1985gt is offline
Old 04-28-2014, 03:38 PM   #28
Stephen H's Avatar
Trade: Slate& Tile Roofing/Exterior Carpentry
Rewards Points: 2,848
Mr. Latone,
thanks for posting the 2 pictures of the small copper roofs.
I have actually been collecting some pictures over the past week of swept hip copper standing seam roofs- not too different from your picture on the left.
Once the customers deposit arrives we will start pre-fabbing a small swept roof for over a doorway.
I was originally thinking a hip roof-- but on further thought I think an adjacent wall is going to interfere with the look of the hip--and so I am most likely going to make it a swept pent roof-still in copper standing seam.
stephen
Stephen H is offline
Old 05-05-2014, 03:48 AM   #29
madrina's Avatar
Trade: roofing and other envied trades
Rewards Points: 1,278
you guys put flashing on the chimney?
madrina is offline
Old 05-05-2014, 07:57 AM   #30
Working
Cole82's Avatar
Rewards Points: 2,276
My mason has told me to never grind a straight line. Always step it, he said he has seen two chimneys break off in high winds and both were straight cut. I would rather be safe than sorry so I step mine.
Cole
Chimney Counter flashing-forumrunner_20140505_075725.jpg   Chimney Counter flashing-forumrunner_20140505_075744.jpg
The boss of awesome
Cole82 is offline
Old 08-30-2014, 03:54 PM   #31
Framing Contractor
Trade: Framing
Rewards Points: 576
30' of flashing I did today using same method as my previous post
Chimney Counter flashing-image-4177272875.jpg   Chimney Counter flashing-image-1418498769.jpg   Chimney Counter flashing-image-1458575869.jpg   Chimney Counter flashing-image-2205877931.jpg
Old 08-30-2014, 04:04 PM   #32
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 704
Now that is some text book looking brick flashing! Nice job!
overanalyze is offline
FullerFramer (08-30-2014)
Old 08-30-2014, 04:26 PM   #33
BamBamm5144's Avatar
Trade: Everything Exterior, Mostly Roofing.
Rewards Points: 2,786
Awesome.
BamBamm5144 is offline
The Following User Says Thank You to BamBamm5144 For This Useful Post:
FullerFramer (08-31-2014)
Old 08-30-2014, 09:18 PM   #34
hack of all trades
dielectricunion's Avatar
Trade: Electrician
Rewards Points: 2,154
Looks really nice! You need to come out here and fix 92% of the houses that have this mess of tar and plastic crap tapcon'd and caulked to the masonry!
dielectricunion is offline
The Following 2 Users Say Thank You to dielectricunion For This Useful Post:
FullerFramer (08-31-2014), LeeFowler (09-07-2014)
Flashing a stone veneer chimney. PatChap Roofing 7 04-02-2013 12:19 PM
whats your ledger board flashing detail? Rich D. Decks & Fencing 77 10-24-2012 07:08 PM
Best Caulk For Chimney Counter Flashing? WNYcarpenter Roofing 16 03-22-2012 07:30 AM
Counter flashing chimney ? enforcer Roofing 22 11-09-2011 02:55 AM
Chimney Counter Flashing... Mason or Roofer? NormW Roofing 38 10-14-2009 08:15 AM
