Built In Gutter - Changing Slope - Roofing - Contractor Talk
Old 07-10-2012, 08:33 AM   #1
zeppyroof's Avatar
Trade: roof contractor
have a built in gutter system extending across a roof.
how can the slope be changed to go to the other side (ie. can fittings be installed within gutter to allow water to flow to the roof's other side)
as seen below in pic, there is water accumulation mostly due to flow from scupper/elbow gutter
also want to remove a scupper and block off the flow exit point.
thanks
built in gutter - changing slope-dscn1400.jpg   built in gutter - changing slope-dscn1397.jpg
zeppyroof is offline
Old 07-10-2012, 02:57 PM   #2
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
Re: Built In Gutter - Changing Slope
Tapered ISO or fab a new metal liner.
1985gt is offline
Old 07-10-2012, 05:27 PM   #3
zeppyroof's Avatar
a taper metal liner would be good
how would you seal it to exist walls of builtin gutter
thanks
Old 07-11-2012, 11:49 AM   #4
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
You should remove all of the material in the surrounding area, but One could just drop in a new liner that had a flange on each side and seal to that.
1985gt is offline
Old 07-12-2012, 10:43 AM   #5
zeppyroof's Avatar
seems this is a minor project. true?
also, worth doing to eliminate lots of water that is ponding on a flat roof?
Old 07-12-2012, 03:21 PM   #6
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
minor?..looks like a real mess to me
Tom Struble is offline
The Following 3 Users Say Thank You to Tom Struble For This Useful Post:
dkillianjr (07-16-2012), Guttersmiths (07-29-2012), WindowsonWash (07-14-2012)
Old 07-12-2012, 03:52 PM   #7
zeppyroof's Avatar
a better picture of the built in gutter system include above
suggestions on approach to eliminate scupper and reroute gutter?
need to reflow water to the other side of built in (which requires resloping); other end of built in turns to right and then to down spout
thanks
Old 07-12-2012, 04:19 PM   #8
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
That is not a simple fix. Best case scenario is to tear it off to the decking and start over. Looks like compressed layers created areas of sag. Shimming off the trusses, putting down new corrugated metal decking, and properly sloping the new rubber is your best bet.
ohiohomedoctor is offline
Old 07-12-2012, 06:13 PM   #9
zeppyroof's Avatar
thanks,
problem is that all this water is going onto a flat roof area with several ac units. the current roof layer is middle aged and there is lots of pooling that sticks around for awhile and drainage off area is poor. its in a winter climate
is it worth addressing this by redoing the gutter work? if left as is and because this roof area has had leak issues in the past for unknown reasons, it may create future problems.
is it worth addressing long term?
Old 07-12-2012, 06:25 PM   #10
Tom M's Avatar
Rewards Points: 11,320
Could surface piping be used to relocate the excess water? Not ideal but until it can be redesigned and replaced it is a cheap out.
Tom M is offline
Old 07-13-2012, 08:39 AM   #11
zeppyroof's Avatar
i guess the basic question is, should it be fixed? and will the excess water accumulation hurt an older roof over time?
thanks
Old 07-17-2012, 12:02 PM   #12
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
thanks
Yes and no, it really looks like a mess and should be fixed at some point in time or another. But honstly the best way would be to redo the whole areas.
Ponding water while not great isn't as bad as everyone thinks it is, on a very old roof yes, newer roof should be able to hold up for awhile.
1985gt is offline
Old 07-17-2012, 12:12 PM   #13
zeppyroof's Avatar
its a roof that presents a major challenge because there are about 6 large AC units that when a new roof is needed will make the effort very challenging (curbs, lifting units, etc).
seems avoidance of drainoff into this area from other roof areas would be very desirable for purposes of extending roof life
Gutter Hangers in Stucco Wall go_hercules Construction 8 05-23-2012 12:37 AM
Used K Style Gutter Machines johnbemyname Contractor Swap 0 04-04-2012 09:15 AM
Conventional built vs. Modular built D.A.S.Anthony General Discussion 23 07-18-2010 09:26 PM
Slope a deck or a level deck? wallmaxx Decks & Fencing 28 08-13-2009 12:36 AM
ice shield at gutter line? Grumpy Roofing 38 09-08-2008 07:22 PM
