Best System For Waterproofing A Balcony? - Roofing - Contractor Talk
Old 02-26-2015, 07:24 PM   #1
Dbower's Avatar
Rewards Points: 12
What is the absolute best system to apply to a balcony and covered foyer to keep it waterproof? Currently the 2 areas are plywood with a fiberglass coating that has failed and is leaking. 1 area is covered with tile and the other pavers.
Dbower is offline
Old 02-26-2015, 09:24 PM   #2
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 350
Re: Best System For Waterproofing A Balcony?
Is this outside? The foyer thing is throwing me off. Check out Schluter. They have stuff for exterior tile installation.
Xtrememtnbiker is offline
Old 02-26-2015, 09:46 PM   #3
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Plywood, fiberglass, tile, and you got a problem?, one word MEMBRANE, Lots of types out there pick your poisen
sunkist is offline
Old 02-26-2015, 11:11 PM   #4
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 2,078
Flashing, membrane, layer of concrete with lava rock as aggregate. Built lots of em, never a problem.
illbuildit.dd is offline
Old 02-27-2015, 09:05 AM   #5
Newb
roofny's Avatar
Trade: Roofing and Siding Contractor
Rewards Points: 99
Mechanically fastened EPDM or TPO. If you need to have a walk surface there are TPO's rated for foot traffic. Or you can do EPDM with drainage mat and pavers or walk pads.
roofny is offline
Old 02-27-2015, 11:27 AM   #6
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
Absolutely stay away from mechanically attached roof systems if they are going to be covered up. Go with fully adhered.
EPDM makes a far better walking surface then TPO or PVC in the winter or any frosty wet conditions.
The system can be sloped for drainage then pedestals installed to put pavers over. Sticking tiles to any of these membrane systems I do not believe would work.
IF there is insulation you are putting down to slope the roof install densdeck or secure rock as a coverboard. The pavers can crush the ISO leaving you with an uneven surface. We always use 6" seam tape on anything that is going to be covered up. And of course 60 mil EPDM, if you have the extra money 90 mil.
This one will get pedestals and 2'x2' concrete pavers. 1/4" per foot tapered 1/2" dens deck 60 mill EPDM with 6" seams. There is two levels of these decks.
1985gt is offline
Old 02-27-2015, 04:45 PM   #7
Newb
roofny's Avatar
Rewards Points: 99
Why not mechanically attached? Risk of movement? I say MA for the reinforced membrane and you will have something holding it down.
roofny is offline
Old 02-27-2015, 07:29 PM   #8
General Contractor
greg24k's Avatar
Rewards Points: 8,882
My balcony is covered with fiberglass, going on 12 years now and it exposed to the sun for most of the day, still looks like it was done yesterday
greg24k is online now
Old 02-27-2015, 07:49 PM   #9
calmod's Avatar
Trade: general contractor
Rewards Points: 188
dex o tex is big here in los angeles. It's all in the flashings with the huge amount of stucco that is used here. i think they're called Diato flashings,run up the wall and incorporate a stucco screed. Fiberglass seems like the sun beats it up pretty well here
calmod is offline
The Following 2 Users Say Thank You to calmod For This Useful Post:
Calidecks (02-27-2015), Rio (03-20-2015)
Old 02-27-2015, 08:22 PM   #10
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
No worry about movement. Mostly risk management. Pulling up deck boards and pavers get expensive. I prefer to have as few penitrations ass possible.
1985gt is offline
Old 03-19-2015, 08:46 AM   #11
tnt specialty's Avatar
Trade: General & Roofing contractor
Rewards Points: 516
There are several good fluid-applied systems on the market - I would not recommend utilizing any type of sheet membrane system on a balcony.
tnt specialty is offline
Old 03-19-2015, 09:32 AM   #12
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
But yet you recommend a coating? Sure why use something that has been proven for decades just throw a bucket of *** over it and call it good.
1985gt is offline
The Following User Says Thank You to 1985gt For This Useful Post:
JWilliams (03-21-2015)
Old 03-20-2015, 10:13 PM   #13
Rewards Points: 516
Problem is, nuckleheads think that bucket 'o "coating" is a "system": Just roll'r' on and yer ready to go!...When typically, due to their ignorance, they may have a component or two of a complete system, which, of course fails miserably......
Old 03-20-2015, 11:39 PM   #14
Designer/Contractor
Rio's Avatar
Rewards Points: 1,588
We were just doing some stuff on a dex o tex roof deck that was built in 1992, looked great but no freeze cycle to consider here.
Rio is offline
Old 03-21-2015, 01:52 AM   #15
Brownchickenbrowncow
elementbldrs's Avatar
Trade: General Building
Rewards Points: 1,376
Agreed, typical traffic coating. Multi part process, starting with GSM flashing all the way through finish coat. Near impossible to damage unless by mechanical means. Last job we used endurokote. Best system for waterproofing a balcony?-imageuploadedbycontractortalk1426920735.447510.jpg
Phil
elementbldrs is offline
Old 03-21-2015, 08:03 AM   #16
YUUUUP!
JWilliams's Avatar
Trade: Metal Roofing Mogul
Rewards Points: 916
I've installed seal-o-flex on many balconies and never had a problem
JWilliams is offline
Why is wood rotting ? SKC Construction 47 05-27-2018 04:50 PM
Xiom system still available Betterblast Contractor Swap 3 01-30-2013 08:04 AM
dewalt tough system storage solution Rich D. Tools & Equipment 39 08-01-2012 01:11 PM
clemco easy load system and closed circuit blasting system goosesgarage Sandblasting 9 11-23-2010 12:41 AM
Unique project - mobile CCTV system mobilecam Low Voltage 14 10-19-2009 07:22 PM
