Adapting 2x3 Aluminum To Raingo - Roofing - Contractor Talk
Old 06-07-2012, 04:01 AM   #1
Gutter Hanger
CrescentGutter's Avatar
Trade: Seamless gutters
Rewards Points: 665
Just picked up a small job where I'll be removing some vinyl gutter and replacing with seamless.
However, where the current square vinyl downspout goes into a drain in the ground, the customer has poured a concrete patio all around it and basically cemented the square downspout in.
I'm not about to cut and bust out concrete, not knowing what's under it for a drain anyway. Anyone have an idea for adapting 2x3 aluminum spout to this square Raingo crap at the concrete? I've been searching the net but coming up with nothing yet.
I'm thinking of maybe somehow inverting a Raingo 4" tile adapter, inserting a piece of 4' PVC and then using a 2x3x4 tile adapter on top of that.
Why do people make simple stuff so difficult?
CrescentGutter is offline
Old 06-07-2012, 03:56 PM   #2
YUUUUP!
JWilliams's Avatar
Trade: Metal Roofing Mogul
Rewards Points: 916
Re: Adapting 2x3 Aluminum To Raingo
sounds like that just might work
JWilliams is offline
Old 06-09-2012, 06:15 PM   #3
A.C.E.
allcityexterior's Avatar
Trade: roofer sider
Rewards Points: 75
Sounds like you have a good strategy. You could also make your own custome funnel from a piece of gutter coil.
Roofing Madison Siding Madison
allcityexterior is offline
The Following User Says Thank You to allcityexterior For This Useful Post:
kage (06-11-2012)
Old 06-09-2012, 06:24 PM   #4
Gutter Hanger
Rewards Points: 665
Madison Roofing
Madison Siding
Going to try the inverted Raingo tile adapter idea first. If it's a no go, may do just as you suggest.
The Following User Says Thank You to CrescentGutter For This Useful Post:
JWilliams (06-10-2012)
Old 06-11-2012, 04:39 AM   #5
Gutter Hanger
Rewards Points: 665
Madison Roofing
Madison Siding
I do actually have some manufactured gutter funnels laying around. Worst case scenario I could cut one lengthwise, make it the proper diameter and rivet it back together.
In the meantime, no Raingo tile adapters available locally, so I had to order a couple online.
Old 06-11-2012, 05:17 PM   #6
A.C.E.
Trade: roofer sider
Rewards Points: 75
There you go. That should work very well.
wanting set of 24' aluminum pump jacks, buy or rent. close to western Pa vaughn59 Contractor Swap 0 06-03-2012 09:18 PM
aluminum windows contractorjay Windows, Siding and Doors 6 11-23-2010 01:34 AM
Scrap aluminum prices vs. aluminum soffit prices Jer Windows, Siding and Doors 8 01-20-2010 07:33 AM
Aluminum Siding Removal Lefty H Insulation 8 08-21-2009 12:28 PM
