You Know That You're A Framer When... - Page 18 - Framing - Contractor Talk
Old 06-28-2013, 08:44 PM   #341
pro
413Sean's Avatar
Trade: residential/framer
Rewards Points: 326
Re: You Know That You're A Framer When...
LOL yup been there done that! I think my crew has fine tuned that problem, cause now in the chalk department of the trailer its clearly labeled blue or red with sharpie arrows pointing to the extra chalk lines.
413Sean is offline
Old 06-28-2013, 09:31 PM   #342
PROcrastinator
onthelevel's Avatar
Trade: Residential Renovation
Rewards Points: 158
YNYAF when blade guards on circular saws are removed
onthelevel is offline
Old 06-28-2013, 09:34 PM   #343
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 362
Not here, not ever. Compromising safety that way is just plain stupid.
Easy Gibson
Warren is online now
The Following 5 Users Say Thank You to Warren For This Useful Post:
Brutus (06-29-2013), Dirtywhiteboy (06-28-2013), knucklehead (06-29-2013), overanalyze (06-29-2013), tenon0774 (06-28-2013)
Old 06-28-2013, 09:36 PM   #344
pro
413Sean's Avatar
Rewards Points: 326
It's on there for a reason.....at least my thoughts
413Sean is offline
Old 06-28-2013, 09:44 PM   #345
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
do you hold the saw till the blade stops spinning every time you use it?
jlsconstruction is offline
Old 06-28-2013, 09:55 PM   #346
fourcornerhome's Avatar
Trade: home improvement contractor
Rewards Points: 520
YNYAF when you know how to cut with a worm drive with the blade guard still on.
or
you still have a splinter in your gut from 30 years ago.
fourcornerhome is online now
Old 06-28-2013, 10:00 PM   #347
Wood O-K's Avatar
Trade: carpentry
Rewards Points: 25
ynyafw you go to the porta with two blocks of wood for your own personal toilet seat.
ynyafw- the term HDAU is your life
Wood O-K is offline
Old 06-28-2013, 10:03 PM   #348
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Decks, Additions
Rewards Points: 15,178
No...I've never removed them but we used to wedge them up....you either hang them on a nail in your horses or set them upside down.
I still put my saw upside down...keeps the plate square. No longer wedge the gaurd though
A&E Exteriors is offline
Old 06-28-2013, 10:14 PM   #349
stacker of sticks
Rewards Points: 590
I've wedged and wired them for a spacific reason. But never left it like that
Old 06-28-2013, 10:26 PM   #350
pro
413Sean's Avatar
Rewards Points: 326
I remember a sidewinder I had with a sticky blade guard....forget the circumstances why I was using it on a house I framed which was near move in condition. Hardwood floors installed, but not sanded yet, gc told me to go back and add another closet in a bedroom per clients change order. Well I was cutting studs, went to set it down and guess what!??? Yup big ol zipper across the new floor, [email protected]#& double @#$%, costly mistake on my part and lesson learned. Always cut outside in this type of situation, and make sure blade guards work properly on EVERY SAW
413Sean is offline
Old 06-28-2013, 10:59 PM   #351
Ill still wedge if a specefic situation calls for it.
Back then...my first framing job in indianapolis all the saws were always wedged up...same as when I moved to Memphis a year later..ALL The crews kept their blades wedged.
In hindsight I believe its because all our roofs were compex cut up rafter framed monsters. 4-8, 000 sq ft customs with 4, 5, and 6 stall garages. Multiple bays and coffered celings galore.
To this day , 13 years into construction....the best 2 framers I ever worked for were the first 2.
Old 06-28-2013, 11:01 PM   #352
Lol...I'm sorry .
I've did it once...on the slab though.
Old 06-28-2013, 11:28 PM   #353
pro
413Sean's Avatar
Rewards Points: 326
Simple two hour job, cost me mucho bucks. But I learned how to tooth in hardwood strip flooring after my dumbazz did this
413Sean is offline
Old 06-29-2013, 09:17 AM   #354
Fine Handcrafted Opinions
Bearded Wonder's Avatar
Trade: General
Rewards Points: 2,670
Yep. I'll use a pencil to wedge it if I need to, but it's pretty rare. On the crew I worked on we pinned them for years, but when I started working for myself I decided to leave them down. I don't even think about it anymore. Guard doesn't get in the way at all.
Bearded Wonder is offline
The Following User Says Thank You to Bearded Wonder For This Useful Post:
kiteman (06-30-2013)
Old 06-29-2013, 10:07 AM   #355
Superior Firepower
skyhook's Avatar
Trade: GC HVAC/R Lic. since 1985
Rewards Points: 3,880
Unless you're cutting an angle. How often do you cut an angle or tilt the table?
Not advocating the removal of guards. Some people (like my nephew) should not handle a skil saw at all. They're the ones I worry about.
bttt,
ykyafw your model 77 has a skyhook.
skyhook is offline
Old 06-29-2013, 10:41 AM   #356
Nail-Bender
Brutus's Avatar
Rewards Points: 2,020
bttt,
Sounds like you need one of these, my friend.
Amazon link
Originally Posted by 2ndGen
If you haven't bled while working once in your life, you haven't worked!
Brutus is offline
The Following User Says Thank You to Brutus For This Useful Post:
skyhook (06-29-2013)
Old 06-29-2013, 11:29 AM   #357
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,728
What is that thing on the side?
NKLHD
knucklehead is offline
Old 06-29-2013, 11:43 AM   #358
Nail-Bender
Brutus's Avatar
guard lifter.
Brutus is offline
Old 06-29-2013, 11:58 AM   #359
Dirtywhiteboy's Avatar
Rewards Points: 4,736
Amazon link
guard lifter.
OSHA approved guard lifter
Dirtywhiteboy is online now
Brutus (06-29-2013)
Old 06-29-2013, 01:38 PM   #360
Palisade Point Const.
TempestV's Avatar
Rewards Points: 1,632
I have 2 saws with that setup, and they are the first two I always reach for. I haven't had to pin a guard since I got those things.
TempestV is offline
Need a Framer in East TN TBALL Framing 0 01-18-2010 08:13 PM
NC Framer JCI New Member Introductions 1 04-02-2009 07:33 PM
Framer from Kansas city MO Nailerconstruct New Member Introductions 8 01-13-2009 06:23 PM
Paslode Framer nail bender Tools & Equipment 4 11-09-2008 11:49 AM
My Framer Needs a WELDER genecarp Framing 3 08-31-2008 12:28 PM
