Wood Post On Patio Over Footing Code ? - Framing - Contractor Talk
Old 07-27-2015, 06:50 PM   #1
jakejorgenson's Avatar
Trade: GC/Carpentry
Rewards Points: 107
I had an inspector call me on a 12x12 timber post that sits on a porch and on a back patio slab (with the footings directly under the slab where they sit) saying they need more clearance off the slab itself. He said it needs 1 inch of clearance off the slab. We've done timber work with metal base plates that are about 3/16" thick for years and never had this come up. It doesn't have a stone base or anything to trap the water. Anybody know where this code reference is and if this is legit? Thanks.
jakejorgenson is offline
Old 07-27-2015, 08:17 PM   #2
hdavis's Avatar
Rewards Points: 2,076
Re: Wood Post On Patio Over Footing Code ?
R317.1.4 Wood columns.
Wood columns shall be approved wood of natu
ral decay resistance or approved pressure
preservatively treated wood.
Exceptions:
1. Posts or columns which are either exposed
to the weather or located in basements
or cellars, supported by piers or metal pede
stals projecting 1 inch (25.4 mm) above the
floor or finished grade and 6 inches (152
mm) above exposed earth, and are separated
there from by an approved impervious moisture barrier.
http://publicecodes.cyberregs.com/ic...2_3_par232.htm
hdavis is online now
Old 07-28-2015, 03:57 PM   #3
Trade: GC/Carpentry
Rewards Points: 107
Thanks. We are going to cut it back and pack non-shrink grout under it at this point as a fix as that seems to be possible with this code.
Old 07-28-2015, 07:49 PM   #4
Windwash
Windwash's Avatar
Rewards Points: 150
I don't have a 1" standoff solution for a 12x12 post other than custom, but I doubt that the grout fix is going to pass either as it will wick moisture from the slab up into the timber post. The point of the standoff is to separate the post from moisture holding materials.
Usually, non-shrink grout is packed under steel posts or columns once the column is set to height and plumbed.
Windwash is offline
The Following User Says Thank You to Windwash For This Useful Post:
Tom M (07-28-2015)
Old 07-28-2015, 09:40 PM   #5
hdavis's Avatar
It'll work as long as he has a capillary break - a simple sheet of galvanized steel over the end is pretty traditional. Lots of options there.
Windwash (07-30-2015)
Timber Frame vs Post & Beam Dustincoc Framing 18 06-26-2014 08:32 PM
Post footing hole with water illectric Masonry 2 10-26-2011 09:18 PM
Wood post in concrete THEHANDYMAN Landscaping 7 01-23-2009 10:02 PM
