Window And Door Header Question - Page 4 - Framing - Contractor Talk
Old 09-11-2010, 07:44 AM   #61
davinci's Avatar
Trade: roofing
Re: Window And Door Header Question
It seems most guys use 2 x 10's and sandwich a 1/2" plywood in between. Then they nail a 2 x 4 to the bottom. Does this sound accurate to you guys?
Also,is it necessary to nail a 2 x 4 to the bottom? Whats th reason.
Thanks everyone
davinci is offline
Old 09-11-2010, 07:59 AM   #62
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
Originally Posted by davinci View Post
It seems most guys use 2 x 10's and sandwich a 1/2" plywood in between. Then they nail a 2 x 4 to the bottom. Does this sound accurate to you guys? Yes
Also,is it necessary to nail a 2 x 4 to the bottom? Whats th reason. No, space filler
Thanks everyone
Understand now?
Framer53 is offline
Old 09-11-2010, 08:02 AM   #63
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Thanks everyone
The 2x4 on the bottom of a 2x10 header sets the proper height of modern day door openings, for the most part 83" on a 6/8 door height. (Depending on the width of a given 2x10, could leave up to 83 3/8".)
Many entry doors require a RO of 82.5", but it's a good idea to put 1/2" plywood under the sill pan for a carpet shim.
loneframer is offline
Old 09-11-2010, 08:13 AM   #64
davinci's Avatar
Trade: roofing
are 2 x 10's used as headers even for a small window,lets say 24 inch wide?
for doors,i guess the plate is usually a 2 x 6?
remember,i am a roofer,but this stuff is interesting and you guys are top notch!
davinci is offline
Old 09-11-2010, 08:20 AM   #65
KemoSabe
loneframer's Avatar
A small opening doesn't require such a header, but for continuity of height, it generally is the case. I've had situations with limited room for header on 2' width that were designed with the top plate removed, leaving only the double plate above a 2x4 header. I've also had situations where their was no header in the wall, just the two plates and the box was doubled in the floor system above with the joists hung from that.
Old 09-11-2010, 08:53 AM   #66
davinci's Avatar
Trade: roofing
thanks loneframer
for a patio door or entry door,the plate at the bottom(under the sill),is that usually a 2x6 ?
davinci is offline
Old 09-11-2010, 08:58 AM   #67
KemoSabe
loneframer's Avatar
thanks loneframer
It depends on the wall thickness. However, the bottom plate almost always gets cut out during a door installation. I have done stepover door sills onto waterproof decks with parapet walls, although I prefer to step down onto the deck without raising the floor height with sleepers. It depends on the design of the building.
Old 09-11-2010, 09:15 AM   #68
welterweight's Avatar
Trade: sales
typically a bottom plate of a patio door or entry do will be a 2 x 6 .
this is especially common with 2 x 4 framing.
welterweight is offline
Old 09-11-2010, 09:31 AM   #69
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
Originally Posted by Cjeff View Post
For me it is mostly 2x6 on new work, 2x4 on garages and renovations.
I nail the 2-2x10 together, with a 2x6 (or 2x4) flat on the bottom. The bottom is 3 inches shorter, 1.5 on each side. So the trimmers (or jacks) go right under the 2x10 header, and the 2x6 (or 2x4) goes in-between the jacks. The gap goes to the inside.
Why? Because it is how I was taught and faster for me then other methods.
Another guy I worked for separated his 2x10's insulated with fiberglass between them, then put on the bottom 2x6.
For doors I usually nail the 2x10 tight together and put the jacks right under it, and when the bottom plate gets cut out for the door, I nail that cut out up under the header. Gap to the inside for insulation.
As I said, spacing the header plys with plywood will get your inspection failed around here.
Also, headers right above the opening, not under the top plate.
"Industry without art is brutality"
shanekw1 is offline
The Following User Says Thank You to shanekw1 For This Useful Post:
jlhaslip (09-11-2010)
Old 09-11-2010, 11:34 AM   #70
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 196
As per Shane...
Gap to the inside for insulation, so the Inspector can see it.
Use styrofoam on them to raise the R-value. Typically 2 x 6 framing here. R-22 in the walls is the target.
If you leave the gap to the outside, the Inspector can't confirm that it is insulated.
jlhaslip is offline
Old 09-12-2010, 03:07 PM   #71
Cjeff's Avatar
Trade: Renovations
Why? I have seen it both ways.
Header at top with cripples below, or header at bottom with cripples above (I do the latter)
Cjeff is offline
Old 09-12-2010, 03:12 PM   #72
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
what are those long vertical pieces of wood in between the walls called?they are spaced about 14 3/8'' inches apart,should the drywall be nailed to them?
Tom Struble is offline
Old 09-12-2010, 03:23 PM   #73
KemoSabe
loneframer's Avatar
Tomstrubles and yes, drywall should be nailed to them.
The Following User Says Thank You to loneframer For This Useful Post:
Tom Struble (09-12-2010)
Old 09-12-2010, 03:38 PM   #74
Trade: siding
Rewards Points: 20
whew...wait i think mine is screwed
Old 09-12-2010, 03:47 PM   #75
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
That part was not a code requirement, just the way I do it.
shanekw1 is offline
Cjeff (09-12-2010)
Old 09-12-2010, 05:46 PM   #76
Cjeff's Avatar
Trade: Renovations
Glued and screwed, but that's a whole nother topic!
Cjeff is offline
Old 09-12-2010, 06:30 PM   #77
Ashcon's Avatar
Trade: Renovation contractor, finish carpenter
Not to add fuel to the fire but since I started back in 1990 I have never framed a house with 2 x 4 always 2 x 6.
The builder I worked for always used a three ply header, pluse plywood fillers. It was typical for us to use the form material from the footings for the headers.
This was usually 2 x8 or 2 x 10 material, I as the low man had to pull all the nails scrape the concrete from the forms and stack everything ready for cutting.
We would install headers at the prescribed height just above the window or door heights.
Over the years on my own and after one too many customer that wanted to change the window height I decided to install all of my headers under the plate and build down to the proper height. I also lost the plywood and would fill with rigid foam to the interior. I found that the sandwich always stood proud of the studs.
I subbed the framing on my last major project and the framers used a spaced header just above the windows. I had my spray foam guy fill the cavity with foam.
Hope this helps Chad
Ashcon is offline
Old 09-12-2010, 06:35 PM   #78
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 38
Our codes allow us to put the header on the jacks or all the way up with crips under. I prefer it at the proper height with crips above. Like Rizz said it just feels stiffer for the door. Picture a long garage door header all the way up with long crips and a 16" long plate under that. Seems more stable with the header right there where the door is. Many times on the interior walls I will put the header all the way up to allow for people to decide later if its a 6'8 door, 7'0 door, or maybe even an arch. Much easier to adjust if the header is up. When in doubt, Push it up!
Easy Gibson
Warren is offline
Old 09-12-2010, 06:37 PM   #79
Geometrist
Warren's Avatar
Rewards Points: 38
We like to use 3/8 plywood as a spacer. We all know how the 2x10 and 2x12 likes to cup and swell. I have yet to hear the drywallers or the finish carpenters complain because the jambs were proud of the drywall.
Easy Gibson
Warren is offline
Old 09-12-2010, 07:28 PM   #80
Cjeff's Avatar
Trade: Renovations
One drywaller I worked with would not fasten to the header, just the 2x6 across the bottom of it. That way if the header shrunk or twisted there were no drywall screws to pop.
Cjeff is offline
