What Is Stronger - Framing - Contractor Talk
What Is Stronger
Old 07-06-2020, 09:26 PM   #1
nickelec's Avatar
Trade: professional licensed electrician
Rewards Points: 540
What Is Stronger
What is stronger a cantilevered joist over a post and beam or the same floor with a recessed beam and joist hangers
Sent from my SM-G986U using Tapatalk
nickelec is offline
Old 07-06-2020, 09:34 PM   #2
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 634
Re: What Is Stronger
Love.
Love is stronger.
Andy.
ScipioAfricanus is offline
The Following 3 Users Say Thank You to ScipioAfricanus For This Useful Post:
Bull Trout (07-09-2020), greg24k (07-08-2020), TheConstruct (07-06-2020)
Old 07-06-2020, 09:34 PM   #3
nickelec's Avatar
Rewards Points: 540
Love is obviously the strongest. Thanks
nickelec is offline
The Following User Says Thank You to nickelec For This Useful Post:
Mordekyle (07-08-2020)
Old 07-06-2020, 09:35 PM   #4
Eater of sins.
Rewards Points: 634
I THINK I understand what you are asking and the drop beam would present fewer possible troubles.
Andy.
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
hdavis (07-07-2020)
Old 07-06-2020, 09:37 PM   #5
nickelec's Avatar
Rewards Points: 540
Im asking because a friend and I were having a conversation about some works he's doing on his house, he has a beam in the basement holding up his first floor and was looking to gain more head room so I suggested to recess the beam and use joist hangers I just wasn't sure if it was as strong as the original set up
nickelec is offline
Old 07-06-2020, 09:39 PM   #6
META's Avatar
Trade: General and Trades
Rewards Points: 8,186
Support closest to load tends to be the strongest, as a basic principle.
META is online now
The Following User Says Thank You to META For This Useful Post:
Calidecks (07-07-2020)
Old 07-06-2020, 09:40 PM   #7
META's Avatar
Bearing fully on a beam is better than just hangers, but flush beams are common build techniques these days.
META is online now
The Following 3 Users Say Thank You to META For This Useful Post:
nickelec (07-06-2020), Seven-Delta-FortyOne (07-07-2020), wallmaxx (07-08-2020)
Old 07-06-2020, 09:42 PM   #8
nickelec's Avatar
Rewards Points: 540
Yes I have seen that on Many job sites
nickelec is offline
Old 07-06-2020, 09:44 PM   #9
rrk's Avatar
Rewards Points: 34
I am not the brightest but how can you cantilever a joist from a recessed beam with joist hangers. The joist has to go over the beam for it to be cantilevered, no?
Your terminology may be incorrect
rrk is online now
Old 07-06-2020, 09:45 PM   #10
nickelec's Avatar
Rewards Points: 540
Yes I was asking about two different scenarios
nickelec is offline
Old 07-06-2020, 09:47 PM   #11
Fire up the BBQ
griz's Avatar
Rewards Points: 2
Marry a rich girl and hire a CT guy to do yout work...
griz is online now
Old 07-06-2020, 09:52 PM   #12
nickelec's Avatar
Rewards Points: 540
He's got a contractor we were just brainstorming
nickelec is offline
Old 07-07-2020, 05:30 AM   #13
Tom M's Avatar
Rewards Points: 660
A flush beam shrinks equally that is all I can see
Tom M is online now
Old 07-07-2020, 07:45 AM   #14
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 17,647
Not sure if he was using the word cantilever correctly. The joist are currently sitting on the beam for full support. In order to gain headspace in the room he wants to take the joists and cut them so he can put them in the same line as the beam using hangers. Thereby gaining the width of the joist in new headroom because they are now in the same plane as the beam instead of being supported by the beam.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
rrk (07-07-2020)
Old 07-07-2020, 08:05 AM   #15
nickelec's Avatar
Rewards Points: 540
Correct
nickelec is offline
Old 07-07-2020, 09:15 AM   #16
Designer/Contractor
Rio's Avatar
Rewards Points: 1,650
In that scenario think it's six of one, half dozen of the other.
Rio is online now
Old 07-07-2020, 10:01 AM   #17
rrk's Avatar
Rewards Points: 34
He wasn't
A cantilevered joist would be unsupported at 1 end
rrk is online now
Old 07-07-2020, 10:20 AM   #18
LRG WoodCrafting
Leo G's Avatar
I've seen floor joist run like that. You have a staggered pattern where they just stop. Usually they have some cross bracing at the end. But it's not a usual thing to do.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 07-07-2020, 12:03 PM   #19
hdavis's Avatar
Rewards Points: 4,446
Drop beam is less susceptible to problems due to rot and fire. Which is stronger is more of an academic question, unless you get into shear discussions.
Drop beams fail more gracefully, generally speaking.
hdavis is online now
Calidecks (07-07-2020), wallmaxx (07-08-2020)
Old 07-08-2020, 08:57 AM   #20
Design Build
wallmaxx's Avatar
Trade: well....that was unpleasant
Rewards Points: 4,202
hDavis nailed it.
Shear is the weaker of the 2 scenarios. Always choose to work WITH gravity for best results.
Life - Liberty - Pursuit of Happiness
Freedom is a God-given right
2A is my personal guarantee
wallmaxx is offline
