Wall Sheathing Parallel To Wall Studs - Page 3 - Framing - Contractor Talk
Old 09-05-2012, 01:47 PM   #41
Kent Whitten's Avatar
Rewards Points: 2,040
Re: Wall Sheathing Parallel To Wall Studs
Btw, it takes a big man to stand up to the status quo. I heard it all the time when I moved back to Maine. I explained it, I showed them....still they lay it flat. Whatever.
They also strap ceilings here. Everyone. Does that make it the correct way to build when 95% of the us does not?
Be the leader in your area and educate.
SalmonFallsCabinetry.com
Kent Whitten is offline
The Following User Says Thank You to Kent Whitten For This Useful Post:
CanningCustom (09-09-2012)
Old 09-05-2012, 01:47 PM   #42
CAD Services
wallmaxx's Avatar
Trade: So done with this place...
Rewards Points: 144
Originally Posted by stokes771 View Post
Well you can call and tell the engineer he engineered them wrong then.
I don't need to talk to your engineer. You should want to learn everything about your trade and exceed the standard.
I'm not trying to bust your chops.
This topic kills me.
We framers are building structures that need to be the most sound and solid as possible. We can't allow the ignorance of an engineer who says you don't have to nail panel edges to lower our standards.
I used to be an "average" framer as an employee learning these things in Texas........then when I started my own business I wanted to be exceptional at framing. Once I moved to WA state, I found that they took codes and structure way more serious than I had become used to............I changed my entire outlook.
I built every structure like I wanted to live in it as my own. And I wanted it to last a hundred years too.
Just my 2
wallmaxx is offline
Old 09-05-2012, 01:49 PM   #43
stokes771's Avatar
Trade: Framing
Originally Posted by wallmaxx
Your first and second floor must have been mechanically attached by metal then? We often used Simpson strapping in addition to plywood to connect the two floors.
If wall panels were sent, then it was a Simpson-fest only.
If the walls were stick framed, we could frame two of more stories and then sheathe continuously upward. That would tie the first and second floors together.
In Ocean Shores we were faced with a 120 MPH wind load code plus a west coast seismic zone. It was metal and ply in some Frankensteinian compilation.
I frame all my houses with sheets overlapping from first to second floor. What I am asking is how you sheet a house with 9' walls, 16" floor, and another set of 9' walls for the 2nd storey. If you are saying all your 2 storey houses are balloon framed then we are talking about 2 different things.
And as far as seismic loads and 120mph winds go, that is not something we nerd time worry about in Alberta.
stokes771 is offline
Old 09-05-2012, 01:53 PM   #44
bluehomes's Avatar
Trade: homebuilder/framer
Rewards Points: 25
Originally Posted by JT Wood View Post
I'm not disagreeing with anyone,
But we have over 4 million in this province with massive residential construction.
There must be a reason why absolutely everyone does it the same way.
Evidenced by the inspector even failing the work
Did you ever hear the story of the woman who always cut the end off of her roast before she cooked it? When asked why she did it she replied that it was what her mother did so she had just followed suit. When her mother was asked why she cut the end off of the roast she replied that it was because her pan was too small for the roast to fit.
"There must be a reason why everyone does it" is not a reason. I haven't been able to find one publication refering specifically to wall sheathing that requires horizontal placement.
bluehomes is offline
Old 09-05-2012, 01:54 PM   #45
CAD Services
wallmaxx's Avatar
Rewards Points: 144
I'll CAD a section. BRB
and no to balloon framing. Too much work to fire block all the cavities spanning one floor to the next.
wallmaxx is offline
Old 09-05-2012, 01:57 PM   #46
bluehomes's Avatar
Rewards Points: 25
Framers here don't order material, at least not when framing for builders.
Honestly though, I would bet it would take weeks to get 9' osb.
I've never seen it anywhere.
I used to do courier work for lumber yards, and they definitely don't stock it
Weyerhaeurser in Edmonton was producing it but stopped because of low sales. Most producers still ship 9' to the U.S.
Old 09-05-2012, 02:08 PM   #47
bluehomes's Avatar
Rewards Points: 25
What did the builder say?
Builder says he doesn't care how its done as long as it passes.
If I felt I was wrong I would eat it and tear all the sheathing off but I'm not; and as Grandma use to say "Right is might!"
Old 09-05-2012, 02:30 PM   #48
CAD Services
wallmaxx's Avatar
Rewards Points: 144
My first choice would be to order 10' plywood. And if all my future homes were going to be 9/9 I'd get the lumber yard man to start to stock it.
Then it depends if you sheathe after framing or as panels. That will dictate where the sheathing seams will break.
We always are directed by engineering to mechanically connect the floors. This is by spec'd strapping or some form of hold down system. This is in addition to the sheathing. I will try and find a wall section I did that had continuous all-thread from the slab to the top of the 5th floor with self tightening connectors at the top.
wallmaxx is offline
The Following User Says Thank You to wallmaxx For This Useful Post:
overanalyze (09-05-2012)
Old 09-05-2012, 08:40 PM   #49
Nail-Bender
Brutus's Avatar
Rewards Points: 2,020
We still strap ceilings, too......
Originally Posted by 2ndGen
If you haven't bled while working once in your life, you haven't worked!
Brutus is offline
Old 09-05-2012, 09:48 PM   #50
Dirtywhiteboy's Avatar
Rewards Points: 10,110
I have done it every way and the wall gets locked up no matter what you do. Latly we've been putting 2 sheets of 3/4 ply on the corner only, locks up the whole wall
Dirtywhiteboy is offline
Old 09-05-2012, 09:52 PM   #51
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 702
Have always done it vertical or parallel. We always sheath from mud sill to top plate across floor systems. We will run horizontal if it's a garage door wall. Then we run from top down across all the headers and block edges.
overanalyze is offline
Old 09-06-2012, 03:24 AM   #52
I know..... I know... Crazy isn't it? I've seen one home that actually shimmed the strapping so the ceiling was flat. That's about the only reason I can see for doing it. Mostly it is because "that's the way I was taught"
I do have a confession....I strapped my shop ceiling I have my reasons.
Old 09-06-2012, 04:35 AM   #53
Nail-Bender
Brutus's Avatar
I actually kind of like it.... We'll leave all non bearing interior walls out, so we can strap straight through. Then once the roof is on, and shingled, we have 2 or 3 days worth of inside work if it rains.
Brutus is offline
Old 09-06-2012, 04:48 AM   #54
Big Shoe's Avatar
Rewards Points: 1,910
I've seen it done both ways in my 40 yrs out there. My home is vertical on second floor with 9' sheets.
When I replaced some siding after the Hurricanes a few yrs ago no one carried 9' material. You would have to order a train car load to get it.
Paper or mesh?
Expect the Unexpected
Big Shoe is offline
Old 09-06-2012, 05:58 AM   #55
kubie's Avatar
Trade: general contractor
Rewards Points: 278
We have to have a vertical sheet within 12' from a corner and 1 every (think its 24') then we are allowed to run the sheets horizontally.
we normally sheet the entire wall vertically and not worry about where we need blocking, ect. Continuous wall sheeting method.
Inspectors here are picky about it. Garages need to be at least 27" wide on each side of the garage door.
kubie is offline
Old 09-07-2012, 10:16 AM   #56
CAD Services
wallmaxx's Avatar
Rewards Points: 144
here is a detail sheet I made a few years back.
Wall sheathing parallel to wall studs-screen-shot-2012-09-07-11.15.32-am.png
wallmaxx is offline
Old 09-07-2012, 10:40 AM   #57
3 Jacks 2 Nines
bwiab's Avatar
Trade: Wannabe Homebuilder
Rewards Points: 290
Nice detail wallmaxx. Am I reading it wrong? I see hold downs at grade and then at the 2nd floor, but nothing above. Doesn't look continuous to the 5th. What am I missing? How often do the HDs occur?
bwiab is offline
Old 09-07-2012, 10:50 AM   #58
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,084
That's the norm here too Brutus.
I hate going into a reto job and there is no strapping to fish my wires through.
Inner10 is offline
hdavis (09-12-2012)
Old 09-07-2012, 12:13 PM   #59
CAD Services
wallmaxx's Avatar
Rewards Points: 144
Yeah. This is a typical 2 story one..........I don't know if I can find the plans for the Ocean Shores condo project.
wallmaxx is offline
Old 09-07-2012, 12:26 PM   #60
Tom M's Avatar
Rewards Points: 3,496
The amount of hold downs is related to the amount bracing needed or lack of bracing provided in a wall from sheathing. Another trigger is the size of an eave and the uplift force it can see in a high wind area, then the hold down goes through the building down to the foundation.
Big window openings at the corner of a building is an area. A better example would be big garage door openings in detached structures.
Tom M is offline
Bathroom Design Help - dark floor and wall tile the same? sbcontracting Architecture & Design 23 10-02-2013 12:14 PM
Marble Wall / Floor Grout Maintenance ? We Fix Houses Tiling 4 08-14-2012 12:00 PM
Hanging Cabinets with metal studs mike d. Carpentry 44 06-24-2012 01:00 PM
Gutter Hangers in Stucco Wall go_hercules Construction 8 05-23-2012 12:37 AM
dry wall with metal studs nelzar13 Drywall 7 02-20-2008 03:53 PM
