Wall Sheathing Parallel To Wall Studs - Page 2 - Framing - Contractor Talk
Old 09-05-2012, 11:57 AM   #21
bluehomes's Avatar
Trade: homebuilder/framer
Rewards Points: 25
Re: Wall Sheathing Parallel To Wall Studs
Thanks guys, I knew you'd come through!
I'll let you know how it all turns out
bluehomes is offline
Old 09-05-2012, 12:01 PM   #22
Kent Whitten's Avatar
Rewards Points: 2,040
Originally Posted by stokes771 View Post
Why would you install parallel to studs anyway?
Did you read anything above? For shear, on an 8' wall, you need continuous perimeter nailing. Horizontal has the 4' break mid stud, so vertical in this scenario is more structurally sound.
The strength axis only means that it is going to SPAN over the studding more rigidly. That's why one doesn't lay sheets parallel on floors and roofs. Walls you do not have a dead load, so you are fine. It does have a tendency to buckle more.
It doesn't mean that it is stronger in that direction. It is such a negligible difference. A piece of ply is the same strength whether vertically or horizontally. It's what you do with it once it is up that determines how it is going to perform.
Tall walls, it's a tossup, but I would rather block one edge than two.
SalmonFallsCabinetry.com
Kent Whitten is offline
The Following 3 Users Say Thank You to Kent Whitten For This Useful Post:
CHRenewal (09-05-2012), overanalyze (09-05-2012), wallmaxx (09-05-2012)
Old 09-05-2012, 12:01 PM   #23
bluehomes's Avatar
Rewards Points: 25
I'm from Alberta. All my sheets have strength axis stamped horizontally.
Isn't it easier when going up over 8ft to just run horizontally and start 4ft from the bottom up? That way none of your joints line up and it looks much cleaner.
Looking cleaner is a matter of opinion, if your sheets run up the entire perimiter is nailed off; laid horizontally you have a joint that runs the entire length of the wall that is only nailed every 16" unless you block.
The Following User Says Thank You to bluehomes For This Useful Post:
Old 09-05-2012, 12:02 PM   #24
bluehomes's Avatar
Rewards Points: 25
Whoops, slow typer
Old 09-05-2012, 12:15 PM   #25
Originally Posted by bluehomes
Whoops, slow typer
You calling me a slow typer?
The Following User Says Thank You to Kent Whitten For This Useful Post:
CanningCustom (09-09-2012)
Old 09-05-2012, 12:29 PM   #26
bluehomes's Avatar
Rewards Points: 25
Easy Duke, you beat me to the draw
Old 09-05-2012, 01:08 PM   #27
CAD Services
wallmaxx's Avatar
Trade: So done with this place...
Rewards Points: 144
Originally Posted by Scott78 View Post
There was a brand of osb that we used here in PEI that had the strength axis stamped on it. Cross ways to studs with joints broken. I can't remember the name of the osb manufacturer!
Strength axis only comes into play when plywood is DEFLECTED as in roof sheathing under load. NO ONE installs roof plywood parallel to the rafters for example.
But wall sheathing is all about SHEAR and that's why the nail count/pattern/type is calc'd by an engineer. The wall sheathing never deflects so there is NO requirement to run it horizontally.
I ran into a few "know-it-all" Canucks in BC who tried to explain how wrong I was to install wall sheathing vertically. (they had no clue what the meaning shear meant.)
Then after losing the argument, they would pull out some ???2000 building code requirement to allow air into all sheathed cavities so they said a 3/4" "air gap" was required between the first horizontal row and the next (on a typ. 8' wall)
So they, in effect, are NOT creating a solid nailing surface for REQUIRED shear panel nailing. And yes, all sheathing is for SHEAR.....6/12 pattern is the baseline and it goes up from there.
The guy is not knowledgeable in the area of discussion and needs some friendly educating.
wallmaxx is offline
Old 09-05-2012, 01:12 PM   #28
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,560
I'm not disagreeing with anyone,
But we have over 4 million in this province with massive residential construction.
There must be a reason why absolutely everyone does it the same way.
Evidenced by the inspector even failing the work
Airdrie AB Renovation Contractor | Kitchen Renovations | Basement Developments | Facebook
JT Wood Construction Serves Airdrie, Cochrane, Olds, Mountainview, Rockyview and Crossfield, Alberta.
JT Wood is offline
Old 09-05-2012, 01:18 PM   #29
CAD Services
wallmaxx's Avatar
Rewards Points: 144
It shows how so many people do something because......its the way they were taught, or the way they've been doing it or whatever..............instead of actually learning what they are actually doing.
If you build two identical walls and sheathe one vertically (all seams/edges nailed 6" o.c.) and one horizontally with no blocking for panel edge nailing in between the studs, under a seismic+load event, the horizontally sheathed wall will be less rigid in the plane of the wall because the plywood will be able to deflect in each stud bay along the un-nailed seam.
If you don't nail every edge of the sheet of plywood into wall framing, you are creating a less-shear capable wall panel. Fact.
wallmaxx is offline
Old 09-05-2012, 01:24 PM   #30
CAD Services
wallmaxx's Avatar
Rewards Points: 144
Originally Posted by hdavis View Post
Look on page 3. The wall sheathing in the picture is all vertically installed.
wallmaxx is offline
Old 09-05-2012, 01:26 PM   #31
JT Wood's Avatar
Trade: carpenter
90% of new homes here have 9' walls as well.
I understand 9' osb is available but I have never seen it anywhere
I always lap the sheathing from the upper floor walls past the floor system onto the walls on the main floor walls. Thats got to be better than a hinge joint.
I don't really have a strong opinion either way. But when literally everyone around, including the inspector expects it one way who wants to have that fight.
We live in tornado country, and it's not like houses are falling down
But what do I know, I like sidewinders
JT Wood is offline
The Following User Says Thank You to JT Wood For This Useful Post:
Old 09-05-2012, 01:28 PM   #32
CAD Services
wallmaxx's Avatar
Rewards Points: 144
Page 19
Support all panel edges means to install 2x or greater framing members into the wall so that the plywood can nailed on all edges. Blocking.
wallmaxx is offline
Old 09-05-2012, 01:28 PM   #33
stokes771's Avatar
Trade: Framing
I'm not saying running sheets parallel is wrong or you can't do it. I just see no benefit in doing it unless the wall you are framing is actually a shear wall, and you are required to block every seam.
I've done quite a few shear walls and never once had to actually block and nail the seams. Every one of them, the engineer either asked for thicker sheeting or more/stronger nails.
When I frame houses, I run my sheets right from the mudsill to the top of the last wall. Running 4' sheets the whole way up with one rip at the top. Unless you start with a cut to get below your bottom plate of your first wall, and then run 8' up from there, none of your seams are going to land on your top plate anyways. Not to mention 9' walls, which is basically every house I have framed in the last 5 years.
stokes771 is offline
Old 09-05-2012, 01:32 PM   #34
CAD Services
wallmaxx's Avatar
Rewards Points: 144
Wormdrives have their place, but for rafter cutting, I like light. Makita MG with the all time LED is my current fave. But I don't cut for a living anymore.
On 9' walls, I would order 9' ply or I'd be installing a row of blocking at 8' or 1'.
wallmaxx is offline
Old 09-05-2012, 01:34 PM   #35
stokes771's Avatar
Trade: Framing
And then in a 2 storey you would put a rip in to sheet the floor system and sheet it back up the same way? From bottom to top plate?
Old 09-05-2012, 01:35 PM   #36
CAD Services
wallmaxx's Avatar
Rewards Points: 144
Then they weren't shear walls. A shear wall is a defined specific component of a house and is inspected. In WA state, not blocking and nailing according to the specified Shear Wall schedule was an instant red tag FAIL.
wallmaxx is offline
Old 09-05-2012, 01:37 PM   #37
Well, there's a perfectly good statement. Why do you suppose that they make 9' osb?
Old 09-05-2012, 01:39 PM   #38
stokes771's Avatar
Trade: Framing
Well you can call and tell the engineer he engineered them wrong then.
Old 09-05-2012, 01:40 PM   #39
CAD Services
wallmaxx's Avatar
Rewards Points: 144
Your first and second floor must have been mechanically attached by metal then? We often used Simpson strapping in addition to plywood to connect the two floors.
If wall panels were sent, then it was a Simpson-fest only.
If the walls were stick framed, we could frame two of more stories and then sheathe continuously upward. That would tie the first and second floors together.
In Ocean Shores we were faced with a 120 MPH wind load code plus a west coast seismic zone. It was metal and ply in some Frankensteinian compilation.
wallmaxx is offline
Old 09-05-2012, 01:46 PM   #40
JT Wood's Avatar
Trade: carpenter
Framers here don't order material, at least not when framing for builders.
Honestly though, I would bet it would take weeks to get 9' osb.
I've never seen it anywhere.
I used to do courier work for lumber yards, and they definitely don't stock it
JT Wood is offline
Bathroom Design Help - dark floor and wall tile the same? sbcontracting Architecture & Design 23 10-02-2013 12:14 PM
Marble Wall / Floor Grout Maintenance ? We Fix Houses Tiling 4 08-14-2012 12:00 PM
Hanging Cabinets with metal studs mike d. Carpentry 44 06-24-2012 01:00 PM
Gutter Hangers in Stucco Wall go_hercules Construction 8 05-23-2012 12:37 AM
dry wall with metal studs nelzar13 Drywall 7 02-20-2008 03:53 PM
