Turret Framing - Framing - Contractor Talk
Turret Framing
Old 02-09-2016, 12:58 AM   #1
Gen. Contractor
Ninjaframer's Avatar
Trade: Residential Light commercial
Rewards Points: 2,610
Turret Framing
I have to frame a pinnacle roof thats intersected by my main roof. Im not sure how to transfer any kind of mark to the main roof for the sleeper. If the pinnacle was above the roof it would be easy but where the main roof cuts it in half im not seeing an easy way to frame the part that goes up onto the main pitch. Ive thought about setting a dummy plate up high enough that it clears my main span and then plumbing down onto the main roof to get the line for the sleeper but that would be a pita considering it would be about 40' up in the air. Any ideas would be appreciated!
"slow makes smooth, smooth makes fast"
Ninjaframer is offline
Old 02-09-2016, 06:09 PM   #2
Joseph A. Capece
CENTERLINE MV's Avatar
Trade: Builder - General
Rewards Points: 1,432
Re: Turret Framing
How good are you with Google sketchup? I've solved many framing dilemmas being able to play with it in 3D.
Follow us on FACEBOOK
www.centerlinebuilders.net
Martha's Vineyard General Contractors - Builders -
Commercial/Residential - Additions - Renovations
CENTERLINE MV is offline
The Following 2 Users Say Thank You to CENTERLINE MV For This Useful Post:
digiconsoo (02-09-2016), Ninjaframer (02-09-2016)
Old 02-09-2016, 06:26 PM   #3
hdavis's Avatar
Rewards Points: 348
Re: Turret Framing
The way I understand it, it's a plane (roof) intersecting a cone (turret roof). If that's correct, it's a conic section - I think it will be a part of an ellipse. I don't have time to walk you through it right now, but here is the background math:
http://hotmath.com/hotmath_help/topi...equations.html
This can be laid out like any ellipse if you have enough space, or it can be calculated.
hdavis is online now
Old 02-09-2016, 07:02 PM   #4
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 2
Re: Turret Framing
Is that roof all stick framed?
Typically, we would get a few girders that go beside the cone, and then we could build a complete cone, and then lay the main roof on that. Looks really cool inside as well.
Warren is online now
Old 02-09-2016, 07:57 PM   #5
Gen. Contractor
Re: Turret Framing
Exactly- it becomes an elipse. Ill look into the formula for drawing the elipse on my main plain- thats exactly what i was asking for.
Old 02-09-2016, 08:02 PM   #6
Gen. Contractor
Re: Turret Framing
Its all truss other than the pinnacle. Theres a girder that cuts off the back of the circle. the problem with doing the pinnacle first is #1 id have tio add a ton of framing, beams etc to support that back side and #2 there is a girder that keeps me from completing the circle/ plate in the back. im torn between doing it like this and just framing as much of the radius plate as i can till i hit the girder OR building the front half and then trying to figure out how to get a sleeper on my main roof.
Ill see if i have a truss layout at home and post it.
Thanks!
Old 02-09-2016, 08:06 PM   #7
Gen. Contractor
Re: Turret Framing
Heres the roof layout
Old 02-09-2016, 08:13 PM   #8
Gen. Contractor
Re: Turret Framing
Thats some complex math for my 8th grade educated mind id have to be walked through it- when you have time id love to learn.
Old 02-09-2016, 08:14 PM   #9
Geometrist
Warren's Avatar
Rewards Points: 2
Re: Turret Framing
This might not be the most scientific way, but if you can draw the circle on the subfloor, you can laser up and drill a few holes through the roof at varying points.
The Following 7 Users Say Thank You to Warren For This Useful Post:
CENTERLINE MV (02-09-2016), digiconsoo (02-09-2016), hammer7896 (02-09-2016), Jaws (02-12-2016), Ninjaframer (02-09-2016), Rio (02-13-2016), wallmaxx (02-13-2016)
Old 02-09-2016, 08:18 PM   #10
Gen. Contractor
Re: Turret Framing
Thats freakin Genius!
Realy- thats a damn good idea. Ive been wanting a reason to get one of those little 5 point laser thingys anyway.
Old 02-09-2016, 08:26 PM   #11
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
Re: Turret Framing
Do a mock up of the plane on the ground, build your cone and crane it up?
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
Old 02-09-2016, 08:29 PM   #12
Gen. Contractor
Re: Turret Framing
I planned on building as much of the cone/ pinnacle on the ground as i can. The walls it sits on are 24' tall. We framed them on the ground today and well lift them up when the crane comes friday.
Old 02-09-2016, 09:44 PM   #13
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
Re: Turret Framing
We did one years ago and the truss company had some trusses made for us for some of it if I remember correctly.
I remember we had 3 men on it for almost 2 days with some trial and error work involved.
Sorry, can't help much with this as we didn't run into this but twice in 20 years fo framing.
Have fun. My advice is to have two guys that are the best on the crew try to figure it out, while the rest of the crew finish the rest off.
Interesting project.
Framer53 is offline
Old 02-10-2016, 12:39 AM   #14
hdavis's Avatar
Rewards Points: 348
Re: Turret Framing
It doesn't get more scientific than that.
Old 02-12-2016, 09:30 AM   #15
Gen. Contractor
Re: Turret Framing
Crane comes today- hope it all fits
Turret framing-image_1455287360533.jpg   Turret framing-image_1455287391219.jpg
The Following 11 Users Say Thank You to Ninjaframer For This Useful Post:
asevereid (02-14-2016), Calidecks (02-12-2016), Framer87 (02-12-2016), hdavis (02-12-2016), Jaws (02-12-2016), overanalyze (02-13-2016), Resta (02-13-2016), Rio (02-13-2016), Texas Wax (02-12-2016), Warren (02-12-2016), Xtrememtnbiker (02-12-2016)
Old 02-12-2016, 10:29 PM   #16
Gen. Contractor
Re: Turret Framing
Mission accomplished
Turret framing-image_1455334102067.jpg   Turret framing-image_1455334092432.jpg   Turret framing-image_1455334234411.jpg
The Following 6 Users Say Thank You to Ninjaframer For This Useful Post:
asevereid (02-14-2016), Jaws (02-12-2016), MultiCon (02-13-2016), overanalyze (02-13-2016), Resta (02-13-2016), Warren (02-12-2016)
Old 02-12-2016, 11:12 PM   #17
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
Re: Turret Framing
You are a magic man, see my upcoming post about how i will use this technique.
Awesome!!
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 02-13-2016, 12:43 AM   #18
hdavis's Avatar
Rewards Points: 348
Re: Turret Framing
Looks Good.
Old 02-13-2016, 06:49 PM   #19
Forming and Framing
FramingPro's Avatar
Re: Turret Framing
Actually, i have been trying to figure this out... how would i be able to use this technique on a octagonal turret? Check out my new post.. You will see what i am up to.
Old 02-13-2016, 07:04 PM   #20
Geometrist
Warren's Avatar
Rewards Points: 2
Re: Turret Framing
Nick:
I use this on octagons all the time. You can use a circle that represents all of the 8 outside points. Knowing the radius, allows you to figure out the sides with math. http://www.pagetutor.com/octagon_layout/
Framing Costs Per Sq. Ft. clexteriors Framing 20 09-26-2014 08:04 PM
Traditional Framing a threat to National Security Dustincoc Framing 43 08-19-2013 10:41 AM
Framing shop drawings mikecocozza Commercial Construction 21 09-28-2012 11:22 PM
Steel Framing Fasteners Orca Construction 12 05-23-2009 07:25 AM
Commercial wood framing mckellarman Commercial Construction 2 05-06-2009 05:11 PM
