Subfloor Replacement - Framing - Contractor Talk
Old 04-23-2014, 09:37 PM   #1
mbryan's Avatar
Trade: water restoration
Rewards Points: 552
Working on a job right now that had T&G over 3/4 ply on 1/2 the main level and double 3/4 ply on the other. Removed all the T&G and the top layer of ply from the other half.
Now the floor has some spongy spots. My opinion is that it needs to be replaced but curious as to if it would work to overlay the existing ply with 3/4 t&g OSB. My fear with that option is squeaks developing where the ply compresses. If it would work to overlay it would be quite a bit less work too...
Opinions?
mbryan is offline
Old 04-23-2014, 09:49 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,342
Re: Subfloor Replacement
How would you do it in your Mom's house?
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
marcsmith (04-23-2014), wallmaxx (04-27-2014)
Old 04-23-2014, 10:25 PM   #3
hdavis's Avatar
Rewards Points: 3,070
If that's rot, it has to be replaced.
hdavis is online now
The Following 3 Users Say Thank You to hdavis For This Useful Post:
CarpenterSFO (04-24-2014), shanekw1 (04-23-2014), wallmaxx (04-27-2014)
Old 04-23-2014, 10:27 PM   #4
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
I'd find out why it has 'some' spongy spots and go from there.
"Industry without art is brutality"
shanekw1 is offline
The Following 2 Users Say Thank You to shanekw1 For This Useful Post:
CarpenterSFO (04-24-2014), wallmaxx (04-27-2014)
Old 04-24-2014, 09:36 PM   #5
mbryan's Avatar
Rewards Points: 552
Do it for free and ask for lunch...
Yes, was wet for somewhere around a month.
Felt it needed replaced but feel the adjuster will feel otherwise so I just wanted some other perspective before discussing it.
mbryan is offline
Old 04-24-2014, 11:00 PM   #6
hdavis's Avatar
Grab a screwdriver, and if you can stick it through, I don't see how an adjuster could argue.
Old 05-10-2014, 03:17 PM   #7
astromco's Avatar
Trade: Framing
Rewards Points: 6
What is spongy? The old existing ply or the structural joist? If it is rotted joist joist definitely replace. If it is rotted sub floor, just cut that area out if you are just going to lay new 3/4 over the top. Personally I would rip all the old out and replace with new but if the adjuster won't allow the funding then you need to document, document, document and take a lot of pics to CYA going forward. As far as you concern of floor squeaks you need to use an abundant amount of glue. Higher end floor glue. Spending more money on glue up front is cheaper than coming back to fix floor squeaks. Do not use any nails! Only screw to attach new sub floor. I would screw down existing sub floor as well prior to overlaying the new.
astromco is offline
