Step Riser Height - Page 3 - Framing - Contractor Talk
Step Riser Height
Old 03-21-2016, 03:04 PM   #41
GC/carpenter
Calidecks's Avatar
Rewards Points: 8,696
Re: Step Riser Height
They also have to fix the deck framing along that whole front a wall, that's also out of square. They've got a lot to do before I step another foot on that project.
Calidecks is offline
Old 03-21-2016, 03:27 PM   #42
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 2,078
Just bid to fix it!
illbuildit.dd is offline
Old 03-21-2016, 03:44 PM   #43
GC/carpenter
Calidecks's Avatar
Originally Posted by illbuildit.dd View Post
Just bid to fix it!
It's a brand new home it's the builders fix. I'm contracted by the HO which is the way I like it. Either way I'm not going to hammer one nail until it's right.
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
hdavis (03-21-2016), illbuildit.dd (03-26-2016)
Old 03-21-2016, 04:45 PM   #44
XJCraver's Avatar
Trade: Building Official
Originally Posted by Californiadecks View Post
The code says no less than 4" rise and no more than 7.75" riser. I could have anything in between if I wanted.
Does the Cali. code add that 4" minimum dimension? It's not in the ('09) IRC:
R311.7.4 Stair treads and risers. Stair treads and risers shall meet the requirements of this section. For the purposes of this section all dimensions and dimensioned surfaces shall be exclusive of carpets, rugs or runners.
R311.7.4.1 Riser height. The maximum riser height shall be 73/4 inches (196 mm). The riser shall be measured vertically between leading edges of the adjacent treads. The greatest riser height within any flight of stairs shall not exceed the smallest by more than 3/8 inch (9.5 mm).
R311.7.4.2 Tread depth. The minimum tread depth shall be 10 inches (254 mm). The tread depth shall be measured horizontally between the vertical planes of the foremost projection of adjacent treads and at a right angle to the tread's leading edge. The greatest tread depth within any flight of stairs shall not exceed the smallest by more than 3/8 inch (9.5 mm). Consistently shaped winders at the walkline shall be allowed within the same flight of stairs as rectangular treads and do not have to be within 3/8 inch (9.5 mm) of the rectangular tread depth.
Winder treads shall have a minimum tread depth of 10 inches (254 mm) measured between the vertical planes of the foremost projection of adjacent treads at the intersections with the walkline. Winder treads shall have a minimum tread depth of 6 inches (152mm) at any point within the clear width of the stair. Within any flight of stairs, the largest winder tread depth at the walkline shall not exceed the smallest winder tread by more than 3/8 inch (9.5 mm).
R311.7.4.3 Profile. The radius of curvature at the nosing shall be no greater than 9/16 inch (14 mm). A nosing not less than 3/4 inch (19 mm) but not more than 11/4 inches (32 mm) shall be provided on stairways with solid risers. The greatest nosing projection shall not exceed the smallest nosing projection by more than 3/8 inch (9.5 mm) between two stories, including the nosing at the level of floors and landings. Beveling of nosings shall not exceed 1/2 inch (12.7 mm). Risers shall be vertical or sloped under the tread above from the underside of the nosing above at an angle not more than 30 degrees (0.51 rad) from the vertical. Open risers are permitted, provided that the opening between treads does not permit the passage of a 4-inch diameter (102 mm) sphere.
Exceptions:1. A nosing is not required where the tread depth is a minimum of 11 inches (279 mm).2. The opening between adjacent treads is not limited on stairs with a total rise of 30 inches (762 mm) or less.
XJCraver is offline
Old 03-21-2016, 08:22 PM   #45
aikenback's Avatar
Trade: all Carpentry, (framing mainly)
Rewards Points: 35
7.25 is a good riser height most of the time, and is very common
aikenback is offline
The Following User Says Thank You to aikenback For This Useful Post:
Calidecks (03-21-2016)
Old 03-21-2016, 08:25 PM   #46
GC/carpenter
Calidecks's Avatar
Yep my cali inspector gives me the paper at every california state inspection, which states 4" minimum, which I never had a muni that didn't go by the state codes.
Old 03-21-2016, 08:27 PM   #47
GC/carpenter
Calidecks's Avatar
Here it is.
Old 03-26-2016, 01:00 AM   #48
Lettusbee's Avatar
Rewards Points: 1,478
The stairs on my deck are 10 risers at 5-7/8" with 11" treads, and they are very comfortable to use.
Lettusbee is offline
The Following 2 Users Say Thank You to Lettusbee For This Useful Post:
Calidecks (03-26-2016), illbuildit.dd (03-26-2016)
Old 03-26-2016, 01:05 AM   #49
GC/carpenter
Calidecks's Avatar
The let-in area for the steps was 42" on one side and 45" on the other. So with that said they will have to use the 7.25" risers. When I did the takeoff I didn't check both sides. I figured hell they framed the whole house you'd think I wouldn't have to check their work. Oh well they are fixing it now, gives me some time to get caught up.
Old 03-26-2016, 04:58 AM   #50
mtb's Avatar
Trade: Framing/Carpentry
Rewards Points: 294
I don't like anything less than 7 personally, feels like a waste of time climbing short steps.
But for older folks less is better. I always start at 7" and find the closest number that gives me the overall rise, favoring steeper up to 7 1/2".
Obviously sometimes there are other considerations and you just have to do what works.
mtb is offline
Old 03-26-2016, 07:50 AM   #51
General Contractor
greg24k's Avatar
Rewards Points: 8,650
Our max rise is 8 1/4"
greg24k is offline
Old 03-26-2016, 08:03 AM   #52
Joasis's Avatar
Rewards Points: 1,742
And...you can talk an inspector out of the limits on riser height if the stair is not a primary egress. Lol.
And sometimes not. We were red tagged on a stair during framing inspection by a clown that didn't get the big picture. The bottom tread was 8 inches, and due to get laminate flooring, next tread was 7-1/2 and on up, landing tread was floor level above....and I pointed out that floor thickness would be 1/2 inch +, and he still wrote the red tag. My framer cut the stringers to make this clown happy, and then shimmed them back.
BTW, I shoot for 7-3/4 x 11 just because most people are taller now, and shorter steps are just not comfortable to most people now.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
The Following 2 Users Say Thank You to Joasis For This Useful Post:
Calidecks (03-26-2016), Railman (03-26-2016)
Old 03-26-2016, 08:39 AM   #53
General Contractor
greg24k's Avatar
Just keep it in mind fellas, for those who don't know the way interpretation of code compliance work to meet the stair variation within 3/8" ... You have to take the tallest rise and subtract the lowest rise and that should be within 3/8.Same goes for the width.
Here is an example.
greg24k is offline
Old 03-26-2016, 02:08 PM   #54
Tom M's Avatar
Rewards Points: 11,138
Personally I find the "stride" method Greg post in #21 to be very true to comfort.
A short step and stair is clumsy but when a short step has a wider tread you adapt easily in stride.
Tom M is offline
The Following 2 Users Say Thank You to Tom M For This Useful Post:
Calidecks (03-26-2016), greg24k (03-26-2016)
Old 03-27-2016, 08:05 AM   #55
CITY DECKS INC's Avatar
Trade: DECK BUILDER. RESIDENTIAL. COMMERCIAL
Rewards Points: 4,608
How the hell can one SCREW up 3" in that short of span..is that gangster looking dude with you... Haha
CITY DECKS INC is offline
Old 03-27-2016, 12:20 PM   #56
GC/carpenter
Calidecks's Avatar
That's the GC's framer
Old 03-28-2016, 07:09 PM   #57
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,728
Yes it is,
You are the crowned king of the month. Tell me how you feel about it,
NKLHD
knucklehead is offline
Old 04-15-2016, 09:38 PM   #58
carpentaro's Avatar
Trade: all around
Rewards Points: 68
Total run+rise should ~17-18", hence the 7/11 starting point.
Minimum IIRC is 4-3/8", anything over that is a "legal" step, may not walk right, but is legal. Not sure what the tallest legal step is, but I wouldn't go anywhere over 8-1/2". No more than 3/8" variance in a flight.
The customer is always right, and it is only a few steps.
carpentaro is offline
Old 04-15-2016, 09:39 PM   #59
GC/carpenter
Calidecks's Avatar
Actually here in Cali it's 4" minimum.
Old 04-15-2016, 09:41 PM   #60
GC/carpenter
Calidecks's Avatar
Here it is.
Again
Raising Ceiling Height in Balloon Frame House toleary Framing 16 01-06-2016 10:53 AM
addressing difference in flooring height AustinDB Flooring 21 10-24-2015 04:30 PM
First time ZackyBundles Drywall Picture Post 155 02-07-2013 08:11 PM
Ply on Slab ....yeah I know InterCounty Flooring 1 02-05-2013 10:34 PM
