Sill Plate On Outer Walls? - Framing - Contractor Talk
Old 04-11-2012, 12:18 PM   #1
sout101's Avatar
Rewards Points: 75
I guys wonder if somebody can help me out abit?
Im going to be building a timber garage for a friend and i have got a lad to concrete the pad for me, i have always been taught whilst working in NZ anyway that the sill should hang about 10mm over the pad on the external walls im not saying this is correct it is just how i was taught.
The concreter has disagreed saying that all the company's he works for ask for the pad to be 100mm bigger than the building which seems strange to me. Just wondering what the normal practice for you guys is? Maybe we are both wrong.
I would look in my books but as im currently moving i have only just packed them up.
Thanks
Chris
sout101 is offline
Old 04-11-2012, 01:36 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 262
Re: Sill Plate On Outer Walls?
I was taught to make the plate flush with the foundation wall. Once sheathing and siding are applied, you actually wind up with an overhang.
But building practices vary around the world, and what's considered proper here could (and obviously does) conflict with the way things are typically done in other areas.
Tinstaafl is offline
Old 04-11-2012, 01:47 PM   #3
Framing Contractor
FullerFramer's Avatar
Trade: Framing
Rewards Points: 576
Yes usually wall should end up being flush. You definetly don't want the wall to be in from the edge of the slab, you will eventually have rot problems. Of course don't just go off the concrete either, chalk some lines and read the plans and adjust accordingly.
FullerFramer is offline
Old 04-11-2012, 02:48 PM   #4
sout101's Avatar
Rewards Points: 75
Cheers guys. As i said i was taught to aim for around 10mm overhang and so have just stuck to this. Like you say though i never just go off the slab so it isnt always 10mm it depends how good the slab is.
Good job i checked his measurements before he poured it as 100mm too big would have been disastrous i have never known anybody do this, though he does slabs for a company who install log cabins and he says that is what they ask for.
This is my first timber frame in the UK and so want it to be spot on as im hoping to pick up more timber frame work from it as there isnt anybody in my area doing it.
Once again cheers guys
sout101 is offline
Old 04-11-2012, 08:10 PM   #5
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,728
What is 10mm?
NKLHD
knucklehead is offline
The Following User Says Thank You to knucklehead For This Useful Post:
CanningCustom (04-12-2012)
Old 04-12-2012, 02:04 AM   #6
sout101's Avatar
Rewards Points: 75
0.39" google informs me
sout101 is offline
Old 04-12-2012, 02:30 AM   #7
Dirtywhiteboy's Avatar
Rewards Points: 12,684
Originally Posted by knucklehead View Post
What is 10mm?
Come on we learned this in school 10mm=1cm 1"=2.56cm so you talkin a RCH less than 3/8" ,,,I would round it off to 3/8"
Dirtywhiteboy is offline
The Following 2 Users Say Thank You to Dirtywhiteboy For This Useful Post:
Brutus (04-12-2012), CanningCustom (04-12-2012)
Old 04-12-2012, 05:55 AM   #8
sout101's Avatar
Rewards Points: 75
Sorry guys as you can tell i dont work in inches
sout101 is offline
Old 04-12-2012, 06:15 AM   #9
JesseCocozza's Avatar
Rewards Points: 810
Agreed. Flush to slab. My only difference
Is here, we use a sill flashing/termite shield. It gets sealed to the concrete and has a 45 degree downward break. Then the framing goes flush to the edge of the slab / flashing break. This helps prevent the sub terranean termites.
JesseCocozza is offline
Old 04-12-2012, 09:44 AM   #10
sout101's Avatar
Rewards Points: 75
Cheers Jesse is that just in Florida that you do that to avoid termites??
sout101 is offline
Old 04-12-2012, 09:59 AM   #11
Rewards Points: 810
I don't have much building experience outside of Florida do I can't really say for sure.
Old 04-12-2012, 11:17 AM   #12
Gen. Contractor
Ninjaframer's Avatar
Trade: Residential Light commercial
Rewards Points: 2,610
We don't do it in Utah and I didn't do that in las Vegas or Texas. All I've ever done is either use sill seal or a bead of glue under the plate. (sill seal sucks)
"slow makes smooth, smooth makes fast"
Ninjaframer is offline
Old 04-12-2012, 11:49 AM   #13
sout101's Avatar
Rewards Points: 75
Great cheers guys just curious or as some may say just nosey ha. I really need to get out of the UK and learn some more framing overseas.
sout101 is offline
Old 04-12-2012, 01:41 PM   #14
We do it here also sometimes.... But not so much anymore, we just keep the slap up from the dirt and a rock border all the way around the house.
Old 04-12-2012, 09:54 PM   #15
john5mt's Avatar
Rewards Points: 1,500
We do flush here. No termite sheild...though it doesnt sound like an awful idea.
Remodelling Fool
Helena Siding Windows
https://helenasiding.com/
john5mt is offline
Old 04-12-2012, 10:05 PM   #16
Splinter hands's Avatar
Sill seal is awesome to install on windy days, all kinds of fun, whatever do you mean?
Splinter hands is offline
Old 04-12-2012, 10:10 PM   #17
Thanks
Chris
I'm with you on ending up with a overhang, no way would I have the pad 100MM bigger, just makes no sense to me but call up your building official and just ask he will be able to tell you your codes there for something like that in 2 sec.
I thought millimeters was only used in Canada anymore? Dang Canadians pushing their measurements, its becoming an epidemic.
Old 04-13-2012, 03:07 AM   #18
Jonno's Avatar
Rewards Points: 27
Most countries use the metric system.
Jonno is offline
Old 04-13-2012, 03:33 AM   #19
But the United States of America uses the imperial system where we have a bakers dozen and a RCH ,,,Jonno where are you at and do you have RCH there
Old 04-13-2012, 07:03 AM   #20
sout101's Avatar
Rewards Points: 75
I thought Canada used imperial also?
sout101 is offline
Comparing concrete block to precast concrete like Superior Walls ryanjm Masonry 12 10-02-2010 01:09 AM
Covering block walls? barefootbuilder Remodeling 6 03-15-2010 01:28 AM
Beveled bearing plate for I-Joist roof PlumbBob^2Pants Framing 42 02-04-2010 07:08 PM
Why Build ICF monsterconstruc Green Building 32 09-28-2008 10:48 PM
Bridging for above grade Concrete Walls ETHICS05 Construction 1 11-21-2005 12:43 PM
