Shed-style Roof Fascia Vertical Or Perpendicular To Top Surface? - Framing - Contractor Talk
Old 07-08-2019, 07:45 PM   #1
Rszimm's Avatar
Trade: GC / Framing
Rewards Points: 34
We don't get a whole lot of shed style roofs out here in Tucson. Generally everything is single-story santa-fe style parapet walls, balloon framing.
So for a shed style roof (I-Joists for members, LVL (or LSL) for fascia) is it more common to make the top and bottom fascia vertical or a right angle to the top surface. Slope is 1-1/2":12". It'll be standing seam metal with matching wrapped steel fascia. Is this a purely aesthetic call or is there something functional.
I would imagine vertical would be better for drainage at least at the top as the fascia wouldn't be in direct contact with downward rain, but a fully metal wrapped fascia probably makes that point moot.
I'm inclined to frame it perpendicular to the roof as I think that'll look better and a 14" LVL will fully cover the end of a 14" I-Joist.
Rszimm is offline
Old 07-08-2019, 07:48 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,350
Re: Shed-style Roof Fascia Vertical Or Perpendicular To Top Surface?
1 vote for vertical...
(vertical level....)
griz is online now
The Following 4 Users Say Thank You to griz For This Useful Post:
hdavis (07-08-2019), Rio (07-13-2019), ScipioAfricanus (07-08-2019), TheConstruct (07-08-2019)
Old 07-08-2019, 08:00 PM   #3
TheConstruct's Avatar
Rewards Points: 1,014
I vote plumb too, it looks right to me. Leaving the end of the rafter square to me always looks like someone didn't know how to figure out the cut. Will you do gutters?
TheConstruct is online now
Old 07-08-2019, 08:54 PM   #4
Rszimm's Avatar
Trade: GC / Framing
Rewards Points: 34
Probably will have gutters running into a rainwater cistern.
Rszimm is offline
Old 07-08-2019, 09:19 PM   #5
hdavis's Avatar
Rewards Points: 3,144
Plumb. Gutters go on easier that way, and aesthetically it looks better.
hdavis is online now
Old 07-09-2019, 06:34 AM   #6
Adamthebuilder's Avatar
Trade: Builder
Rewards Points: 228
Plumb. That low of a pitch would almost look like someone cut the rafters wrong, and no body realized it until the gutter guy shows up.
Adamthebuilder is offline
The Following User Says Thank You to Adamthebuilder For This Useful Post:
hdavis (07-09-2019)
Old 07-10-2019, 09:42 AM   #7
Rszimm's Avatar
Trade: GC / Framing
Rewards Points: 34
Well it appears there is consensus. So you guys really don't look the square look like this: https://i.imgur.com/QI7BiHg.jpg?1
Rszimm is offline
Old 07-10-2019, 02:19 PM   #8
Fire up the BBQ
griz's Avatar
No....
griz is online now
Old 07-13-2019, 05:01 PM   #9
Dirtywhiteboy's Avatar
Rewards Points: 10,154
Originally Posted by griz View Post
No....
No ,, because the gutters hang vertical- level
Dirtywhiteboy is online now
Old 07-13-2019, 05:53 PM   #10
Designer/Contractor
Rio's Avatar
Rewards Points: 1,916
The fascia is usually larger then the joists, I would think about upsizing the LVL
Rio is offline
Old 07-13-2019, 08:01 PM   #11
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,220
Job I just did, not fond of the wide fascia , but what the builder wanted. Made from steel coil with 2- 1" ribs rolled in to help control oil canning.
Shed-style roof fascia vertical or perpendicular to top surface?-20190708_110552-2496-.jpg   Shed-style roof fascia vertical or perpendicular to top surface?-20190708_110715-2497-.jpg
Randy Bush is offline
The Following 4 Users Say Thank You to Randy Bush For This Useful Post:
B.Johnson (07-14-2019), hdavis (07-13-2019), Rio (07-13-2019), TheConstruct (07-13-2019)
Old 07-13-2019, 08:24 PM   #12
Rszimm's Avatar
Trade: GC / Framing
Rewards Points: 34
That's pretty great looking. It really doesn't look like 16" installed. I would have sworn it was around 12" from the 2nd photo.
shouldn't that fascia wrap have another tab at the bottom to wrap around the bottom of the fascia?
Rszimm is offline
Old 07-13-2019, 10:38 PM   #13
Randy Bush's Avatar
The upper part is only 12 . The 16 in on the bench goes on the beam over the patios.
Sent from my SAMSUNG-SM-J327A using Tapatalk
Old 07-13-2019, 11:52 PM   #14
Designer/Contractor
Rio's Avatar
What is the gauge of the steel if I may ask?
Rio is offline
Old 07-14-2019, 12:11 AM   #15
We like to cut the TJI down on the over hang and use smaller fascia if the plans will allow it.
Shed-style roof fascia vertical or perpendicular to top surface?-img_20170909_131553779.jpg   Shed-style roof fascia vertical or perpendicular to top surface?-img_20170909_164213234.jpg   Shed-style roof fascia vertical or perpendicular to top surface?-img_20171001_153750380.jpg
Rio (07-14-2019)
Old 07-14-2019, 08:12 AM   #16
Randy Bush's Avatar
It looks like it is 30 ga ,EDCO Entex .
The Following User Says Thank You to Randy Bush For This Useful Post:
Rio (07-14-2019)
Old 07-14-2019, 10:11 AM   #17
Rszimm's Avatar
Trade: GC / Framing
Rewards Points: 34
That looks great. I guess I’d have to run some numbers to see if I can go to a 4’ overhang using that technique. The TJI design guide limits you to 2’ that way.
Rszimm is offline
Old 07-14-2019, 02:44 PM   #18
That looks great. I guess Id have to run some numbers to see if I can go to a 4 overhang using that technique. The TJI design guide limits you to 2 that way.
That shop has a 3 foot over hang. After the sofit and standing seam roof it looked good.
Shed-style roof fascia vertical or perpendicular to top surface?-1564.jpg   Shed-style roof fascia vertical or perpendicular to top surface?-1742.jpg   Shed-style roof fascia vertical or perpendicular to top surface?-img_20171021_162604064.jpg   Shed-style roof fascia vertical or perpendicular to top surface?-2100.jpg
Rio (07-21-2019)
