Sheathing Cuts For Valley - Framing - Contractor Talk
Old 10-14-2018, 12:18 PM   #1
Lazy Millennial
Youngin''s Avatar
Rewards Points: 864
It's been an awfully long time since I've been on a roof, nevermind framing one and I'm looking to improve a little in how I approach cutting sheathing.
I've got this 7/12 roof to work with and going into the valley I measured the long and short points. It worked ok but it wasn't perfect. I know there is a better way and I'll be ordering a certain book everyone likes but tomorrow I need to sheath a gable valley set that runs perpendicular to the main roof down from other side of the valley to meet the sheathing I cut to valley last week. Is there any mathematical way to figure that out? Something better than trying to cut long and short points? If I could get one measurent then determine the measurent down the other side of the 8 ft sheet using a ratio of some sort that would be great and take the guess work out. Is there a feature in BuildCalc that would work for determining that?
I've been playing with hanging doors and installing shelving too long...
Originally Posted by mnld View Post
Home Depot... you can glue it, we can help!
Youngin' is online now
Old 10-14-2018, 01:00 PM   #2
tjbnwi's Avatar
Rewards Points: 5,830
Re: Sheathing Cuts For Valley
Sheathing angle is found using the Hip/Valley function in BuldCalc. It will figure both regular and irregular hip/valleys.
tjbnwi is online now
Old 10-14-2018, 04:27 PM   #3
Caleb1989's Avatar
Rewards Points: 394
So all the rafters are already in place? You will probably spent more time scratching your head than installing sheets. Just measure up the roof 4 then measure across to get long point. No big deal.
-Caleb
John 3:16
Caleb1989 is offline
The Following 5 Users Say Thank You to Caleb1989 For This Useful Post:
BlueRidgeGreen (10-14-2018), Jay hole (10-14-2018), Justin Rhoades (10-14-2018), Rio (10-14-2018), Xtrememtnbiker (10-14-2018)
Old 10-14-2018, 04:52 PM   #4
Joe Wood's Avatar
Rewards Points: 914
I've forgotten almost everything I learned about roof framing and just use this site now :-)
https://www.blocklayer.com/roof/roofeng.aspx
Joe Wood is online now
The Following 2 Users Say Thank You to Joe Wood For This Useful Post:
Fouthgeneration (10-16-2018), mrcat (10-14-2018)
Old 10-14-2018, 06:10 PM   #5
BlueRidgeGreen's Avatar
Trade: Craftsman
Rewards Points: 526
-Caleb
John 3:16
I prefer to leave the advanced mathematics for other things.
Just too quick to field measure it.
BlueRidgeGreen is offline
The Following 5 Users Say Thank You to BlueRidgeGreen For This Useful Post:
Calidecks (10-15-2018), cedarboarder (10-15-2018), Justin Rhoades (10-14-2018), Rio (10-14-2018), Xtrememtnbiker (10-14-2018)
Old 10-14-2018, 06:24 PM   #6
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 5,730
Start at 50:00
Big Johnson is online now
Old 10-15-2018, 06:33 PM   #7
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 1,168
A long long time ago there was a little book that came with a square that had all the measurements in it for the valley sheathing based on pitch. Just about everything can be figured mathematically but some times it's just as easy and just as fast to just measure.
dave_dj1 is offline
Old 10-15-2018, 07:15 PM   #8
Adamthebuilder's Avatar
Trade: Builder
Rewards Points: 350
It has been awhile, but in the table on the framing square, there is a column which gives you the other dimension to hold with the 12” side to give the you angle. I can’t remember which one. In my framing days, I had the difference in dimensions between the short and long points on a sheet of plywood, for each roof pitch. It would probably take me a few test cuts to get it right.
Adamthebuilder is online now
Old 10-15-2018, 10:26 PM   #9
Gen. Contractor
Ninjaframer's Avatar
Trade: Residential Light commercial
Rewards Points: 2,610
Here's some tables I made a long time ago.
"slow makes smooth, smooth makes fast"
Ninjaframer is offline
The Following 2 Users Say Thank You to Ninjaframer For This Useful Post:
Calidecks (10-15-2018), mrcat (10-16-2018)
Old 10-15-2018, 10:28 PM   #10
Gen. Contractor
Cl is cut length- as in length of diagonal cut for a given pitch. I just measure top or bottom length, use knife to make a notch and then measure the diagonal length for the given pitch- perfect valley angle every time.
The Following User Says Thank You to Ninjaframer For This Useful Post:
Old 10-15-2018, 10:30 PM   #11
Gen. Contractor
A table I made long ago. Cl is cut length- as in length of diagonal cut across sheet for a given pitch.
The Following 5 Users Say Thank You to Ninjaframer For This Useful Post:
asevereid (10-15-2018), Calidecks (10-15-2018), griz (10-15-2018), SouthonBeach (10-16-2018), Xtrememtnbiker (10-15-2018)
Old 10-15-2018, 10:36 PM   #12
Fire up the BBQ
griz's Avatar
Rewards Points: 2,988
hey, good to see you posting again...
griz is online now
Old 10-16-2018, 01:56 PM   #13
Lazy Millennial
Youngin''s Avatar
Rewards Points: 864
Thank you very much for the education all. It was nice to see different methods to making things work. Got the valley figured. It turned out good.
What kind of sheathing would this be? atticstobasemen General Discussion 8 09-30-2011 07:47 AM
Hardie lap siding w/o sheathing synthad1 Windows, Siding and Doors 18 09-15-2011 07:56 PM
Opinions ---- OSB sheathing question enforcer Windows, Siding and Doors 10 06-28-2011 07:33 AM
Sheathing miter-cut jig stick UpNorth Framing 7 06-26-2011 10:11 PM
Frost on underside of roof sheathing ApexCS Remodeling 5 01-15-2009 01:55 PM
