Senco SN4 - Framing - Contractor Talk
Senco SN4
Old 07-14-2015, 05:51 PM   #1
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
Senco SN4
Look what I found hidden in my shed, my first framing nail gun. Bought it at a yard sale for $50 probably 20 years ago
Senco SN4-imageuploadedbycontractortalk1436914079.631117.jpgSenco SN4-imageuploadedbycontractortalk1436914230.324081.jpg
festerized is offline
Old 07-15-2015, 09:03 AM   #2
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,386
Re: Senco SN4
I used that same gun a long time ago. It was so clunky, heavy, and slow. But my boss swore it worked better so I had to use it.
KennMacMoragh is offline
Old 07-15-2015, 09:30 AM   #3
David Festa
festerized's Avatar
Re: Senco SN4
its a heavy gun but it sinks the nails pretty good. the rounded tip was an issue because it would slide down the stud, beats hand nailing!
Old 07-15-2015, 10:23 AM   #4
tccoggs's Avatar
Rewards Points: 874
Re: Senco SN4
those old sencos were built to last. Will probably still work after another 20 years in the shed.
The round nose is because these were mainly for factory use, probably as pallet nailers, not really framing nailers. Still have an SN70 in the collection that is similar to this one, but more powerful.
tccoggs is offline
Old 07-15-2015, 10:38 AM   #5
Railman's Avatar
Trade: Railing
Rewards Points: 1,189
Re: Senco SN4
I hated that gun. When they 1st came out, I shot a nail into my shin while walking across the floor. What happened fairly often was the wire trip would get bent when letting the gun down to the floor. If it hit a little hard, it would bend the trip wire and easily hang up in the ready to fire mode. Once that happened, just a bump on the trigger would make it fire.
I do know that they fixed the problem later by beefing up the wire somehow.
I much preferred the previous model that was equally powerful, at about 2/3 the weight, but they wore out the bore in the main body casting at the poppet (valving above piston) fairly fast. Once they grooved in, the poppet would hang. There wasn't an easy fix to remedy the miss-fires.
Railman is online now
The Following User Says Thank You to Railman For This Useful Post:
Metro M & L (07-15-2015)
Senco Fusion ? MF Custom Tools & Equipment 63 12-31-2015 07:09 PM
Hitachi Vs Senco & Bostitch finakat Tools & Equipment 40 03-04-2014 09:44 AM
Senco SFN II 11678 Contractor Swap 0 03-18-2013 09:41 AM
Senco SNC65 parts lead robspin Framing 2 02-12-2013 02:37 PM
Bosch or Senco cordless finish nailer? SuperiorHIP Tools & Equipment 12 09-14-2011 10:06 AM
