Roof Framing For 12' X 16' Shed - Framing - Contractor Talk
Old 05-28-2013, 12:43 PM   #1
d83g25's Avatar
I am building a 12' x 16' shed and I'm trying to figure out the best way to frame the roof. I'm going to frame a gable roof with 2x6 rafters on 6/12 pitch. The walls are 2x4x10' and I wanted to put the ceiling joists at 8' and then let rafters sit on exterior walls. I want to avoid putting a large ridge beam and would like to just use a 2x8x16' ridge board. I would like to have a 12 inch projection on both sides. Can anyone please give me some insight on this project? If I would of known before hand I would have only framed the exterior walls at 8' instead of 10'. If go with the original plan can I still put a ledger board around the inside framing and frame my celing joists and attach the rafters to my double 2x4 top plate or is there going to be to much outward force on my exterior walls?
d83g25 is offline
Old 05-28-2013, 12:49 PM   #2
Creter's Avatar
Rewards Points: 1,966
Re: Roof Framing For 12' X 16' Shed
Go to your locale lumber yard and order trusses.
Creter is offline
Old 05-28-2013, 01:34 PM   #3
C2projects's Avatar
Trade: General Contracting
Rewards Points: 1,084
If you dont want trusses. What I've done in the past is if you frame your end walls vaulted to the pitch you want you will have your ridge line. You will need to calculate your side walls to plane properly with your pitch. But I would just do a lean to roof on a shed. Or get trusses....
Note to self... Read entire post before commenting. This will limit the chances of you looking like a [email protected]$$
Proper Prior Planning Prevents Piss Poor Performance
C2projects is offline
Old 05-28-2013, 02:05 PM   #4
kiteman's Avatar
Rewards Points: 16
I think what you have planned should work fine. Make sure you attach the ledger properly and use the appropriate hangers and hold-downs.
An old framer once told me "For years I thought I was the best damn carpenter in California. Come to find out I'm just competent."
kiteman is offline
The Following 2 Users Say Thank You to kiteman For This Useful Post:
cranbrook2 (05-28-2013), fourcornerhome (05-28-2013)
Old 05-28-2013, 02:50 PM   #5
CarpenterSFO's Avatar
Rewards Points: 2,044
Hire a carpenter. He or she will know how to frame a shed.
- Bob
CarpenterSFO is offline
The Following 4 Users Say Thank You to CarpenterSFO For This Useful Post:
C2projects (05-29-2013), Deckhead (05-28-2013), jhark123 (05-28-2013)
Old 05-28-2013, 03:25 PM   #6
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 7,484
How would you suppose "normal" conventional framing is? If you know... The answers are plain.
Deckhead is offline
Old 05-28-2013, 03:36 PM   #7
deter's Avatar
Trade: Project Managment & hack-of-all-trades
Rewards Points: 44
Is this the shed you've framed thus far?
deter is offline
The Following 6 Users Say Thank You to deter For This Useful Post:
C2projects (05-28-2013), CarpenterSFO (05-28-2013), fourcornerhome (05-28-2013), jhark123 (05-28-2013), kiteman (05-28-2013)
Old 05-28-2013, 09:24 PM   #8
sawzall king's Avatar
Trade: framing
Rewards Points: 250
lloks good but needs a door?
sawzall king is offline
Old 05-28-2013, 09:42 PM   #9
extreme birdhouse builder
cranbrook2's Avatar
Trade: framing ,trim ,roofing,fences and decks .
Rewards Points: 288
I think this is the same shed and it is a beauty
http://www.youtube.com/watch?v=O8XhE17_z8Y
cranbrook2 is offline
Old 05-28-2013, 10:26 PM   #10
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
In before the lock
jlsconstruction is offline
Old 05-28-2013, 11:25 PM   #11
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 478
Here is a little teaser for you.
Andy.
ScipioAfricanus is online now
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
knucklehead (05-29-2013)
Old 05-28-2013, 11:40 PM   #12
stacker of sticks
Rewards Points: 590
Andy.
It's missing double top plate
Old 05-29-2013, 05:52 AM   #13
d83g25's Avatar
Thanks but I' building this by myself.
d83g25 is offline
Old 05-29-2013, 05:57 AM   #14
d83g25's Avatar
Why don't you keep your comments to yourself? If you don't have anything useful to say then why bother responding to the post. Do you have that much free time A$$h0le
d83g25 is offline
Old 05-29-2013, 05:59 AM   #15
d83g25's Avatar
The last message was for BOB CRAM
CARPENTERSFO
d83g25 is offline
Old 05-29-2013, 07:11 AM   #16
Okiecontractor's Avatar
Rewards Points: 2,002
You guys crack me up.
Yeah I can do that... I learned how from the DIY channel.
DJ
Okiecontractor is offline
Old 05-29-2013, 07:12 AM   #17
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,728
why drop the ceiling?
NKLHD
knucklehead is offline
Old 05-29-2013, 07:16 AM   #18
Brian Peters's Avatar
Trade: remodeling and some new construction
Rewards Points: 972
Just frame like usual and if you want an 8' ceiling put joists in at 8'. Maybe I'm not reading this right but I don't see a problem...
Brian Peters is offline
Old 05-29-2013, 07:30 AM   #19
General Contractor
greg24k's Avatar
Rewards Points: 8,776
Why you need a ceiling in the shed?
greg24k is offline
Old 05-29-2013, 08:18 AM   #20
CARPENTERSFO
I don't think you're a carpenter. You framed 4 walls, then started to wonder about how to put a roof on? And then, if you "would have known beforehand", you would have made the walls 8 feet? What the heck does that mean? That sure looks like DIY to me. If I'm wrong, go ahead and tell us about it.
- Bob
flat roof wide open and building flooded madrina Roofing 43 05-29-2013 08:11 AM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
