Rise For A 4:12 Pitch Roof - Framing - Contractor Talk
Old 07-05-2010, 09:54 AM   #1
topdog's Avatar
Trade: G.C. Framing,Carpenter
I am building a portch roof and it has been a long time . can someone tell me what the rise from the bottom cord to the peek it on a 4:12 pich the span is 23 foot acrost the botttom cord . thanks
topdog is offline
Old 07-05-2010, 10:22 AM   #2
randybelk@comca's Avatar
Trade: CONTRACTOR
Rewards Points: 25
Re: Rise For A 4:12 Pitch Roof
4" per foot. uh lets see... 23' divided by 2= 11.5'. 11.5' X 4 would be 46"
randybelk@comca is offline
Old 07-05-2010, 10:40 AM   #3
Pompass Ass
bwalley's Avatar
Rewards Points: 1,000
It depends on what type of porch roof, if it is a shed type roof, it will have 92" of rise.
bwalley is offline
Old 07-05-2010, 10:55 AM   #4
AustinDB's Avatar
Rewards Points: 1,534
set it up as a ratio proportion...
4 / 12 = x / 23 (cross multiply and divide...)
(4*23) / 12 = 7.6666 = 7' 8"
it's up to you to figure out where to measure up from based on your construction methods.
AustinDB is offline
Old 07-05-2010, 03:02 PM   #5
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
From the "bottom cord" to the "peak"?
If that means from the plate line to the top of ridge you will have to add the vertical distance of the truss at the plate line to the rise.
Gus Dering is offline
Old 07-05-2010, 04:29 PM   #6
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
Not for nothing but why is it important at this point?
Framer53 is offline
Old 07-05-2010, 05:39 PM   #7
Resident Pain
CanningCustom's Avatar
Rewards Points: 1,730
um you are forgetting about the undetermined heal height so with out that missing variable the true height can not be found.
CanningCustom is offline
Old 07-05-2010, 05:51 PM   #8
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
I guess I still don't understand why the question.. He already has the trusses, unless I misunderstand.
Framer53 is offline
Old 07-05-2010, 06:08 PM   #9
AustinDB's Avatar
good point w/ the 'chord' terminology and description...does a truss certification sheet have total height from the plate? I 'assumed' he was building this out of stick...hence Canning's response. May be the OP is stick building the roof and unfamiliar with the terms, or mabye not
AustinDB is offline
Old 07-05-2010, 06:22 PM   #10
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
I did a beachfront home that had trusses through one section. The shop drawings had all the dimensions on them. The only problem was, they were 6" taller than the shop drawings. Had to lower the entire section 6" by cutting the wall studs, after the trusses were set and the walls were sheathed. I won't ever set another truss in a home with height restrictions without checking them first.
loneframer is offline
The Following 2 Users Say Thank You to loneframer For This Useful Post:
AustinDB (07-06-2010), mudpad (07-05-2010)
Old 07-05-2010, 07:38 PM   #11
Project Superintendent
mudpad's Avatar
Rewards Points: 2,000
I am dealing with overhang issues at the gables on my metal truss project. The shops say they work, but reality is they don't. Truss manufacturer is picking up the cost of the fix, but what a pain in the ass.
Steve
mudpad is offline
Need a "flat" roof Guru... Bill Z Roofing 33 01-01-2013 08:19 PM
flatroof to pitched. Insulating above old roof Red Adobe Insulation 2 07-14-2009 10:30 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Need help designing Roof for addition jaymay75 Framing 21 06-17-2006 09:47 PM
