Rim Joist, Band Joist - Framing - Contractor Talk
Unread 07-11-2019, 11:04 PM   #1
Designer/Contractor
Rio's Avatar
Rewards Points: 1,916
Reviewing my framing nomenclature......... a rim joist runs perpendicular to the field joists while a band joist runs parallel. Agree or disagree?
Rio is online now
Unread 07-11-2019, 11:12 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,350
Re: Rim Joist, Band Joist
yea i think so....
but seems like you are being too technical.
most everyone on a job site will call it a rim joist.
have not heard the term "band joist" in a number of years.
had an architect make a note in an addendum once clarifying the two terms.
he basically said they are one in the same for intents and purposes.
PS- my knowledge of framing terms and methods is from sacramento north. may be a regional thing.
griz is online now
The Following 4 Users Say Thank You to griz For This Useful Post:
BlueRidgeGreen (07-11-2019), cedarboarder (07-12-2019), rrk (07-12-2019), TimNJ (07-12-2019)
Unread 07-11-2019, 11:16 PM   #3
BlueRidgeGreen's Avatar
Trade: Craftsman
Rewards Points: 3,584
Ditto.
"Timid men prefer the calm of despotism to the tempestuous sea of liberty". Thomas Jefferson
BlueRidgeGreen is online now
Unread 07-12-2019, 01:02 AM   #4
Designer/Contractor
Rio's Avatar
I always thought they were the same myself but the other day was doing some stuff using TJI's and it showed up on the diagram from Boise Cascade.
Rio is online now
Unread 07-12-2019, 08:16 AM   #5
General Contractor
greg24k's Avatar
Rewards Points: 8,110
The function of the Rim joist like you described that exactly what its for...
You also have the term for End joist which located on each end of the floor structure, they run in the same direction the rest of the joists do...
Rim joists + End Joists = Band Joist
greg24k is online now
Unread 07-12-2019, 09:05 AM   #6
hdavis's Avatar
Rewards Points: 3,130
Originally Posted by greg24k View Post
the function of the rim joist like you described that exactly what its for...
You also have the term for end joist which located on each end of the floor structure, they run in the same direction the rest of the joists do...
Rim joists + end joists = band joist
x2.
hdavis is online now
greg24k (07-12-2019)
Unread 07-12-2019, 04:16 PM   #7
META's Avatar
Trade: General and Trades
Rewards Points: 3,388
We just call it all rim joist. I dislike today's OSB rimboard, but such is the engineered framing these days.
META is online now
The Following User Says Thank You to META For This Useful Post:
Seven-Delta-FortyOne (07-12-2019)
Unread 07-12-2019, 05:10 PM   #8
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,096
You could always request the rim boards to be LVL instead, I thinks its around 3 times the price. I dont like the osb either but I guess it works.... and swells. 1-1/8 rimjoist expands to almost 1-1/2, I cut the I-joists 1-3/8 short on each side instead of 1-1/8.
The biggest drawback to osb is when doing a deck but I always drop the ledger low enough to catch the sill, double top plates and/or lower wall framing. Size the ledger up if necessary and let the excess meat hang low.
Big Johnson is offline
Unread 07-12-2019, 05:11 PM   #9
Designer/Contractor
Rio's Avatar
There's a good amount of difference structurally between a band joist and a rim joist with the band joist running parallel with the field joists so in that respect it makes sense to differentiate between them, might help bring attention to that for designing.
Rio is online now
Unread 07-12-2019, 05:13 PM   #10
Designer/Contractor
Rio's Avatar
Don't think OSB rims would fly out here when working with engineered lumber, there's a big shear transfer at the perimeters usually.
Rio is online now
Unread 07-12-2019, 05:20 PM   #11
It’s all we use. Although I have seen I-joist used for the band (parallel) joist.
https://lpcorp.com/products/framing/rim-board
The Following 3 Users Say Thank You to Big Johnson For This Useful Post:
greg24k (07-12-2019), META (07-12-2019), Rio (07-12-2019)
Unread 07-12-2019, 05:22 PM   #12
Designer/Contractor
Rio's Avatar
Was thinking more of floors and walls in houses but that's really interesting, seems a little sketchy?
Rio is online now
Unread 07-12-2019, 08:50 PM   #13
Jay hole's Avatar
Trade: General contractor
Rewards Points: 1,651
What do you use for rim board?
Jay hole is offline
Unread 07-12-2019, 09:15 PM   #14
META's Avatar
We've been framing like Big J's picture for years up here. Yeah, lateral issues would be a concern in other areas. In fact, the TJI install calls for blocking or rim joist on reverse ledger (0 barrier) framing. However, it's still kind of goofy because the OSB subfloor is spanning over joists and directly to sill plate, which is anchored to the foundation wall. That situation would have less lateral movement than typical rim joist box framing.
Either way, the band joist is often just that 1 1/8" OSB; crush blocking where applicable. For rim joist, a couple .131 nails going through OSB rim into laminated/engineered top & bottom cord I-joist, is weak, but it's standard.
META is online now
Rio (07-13-2019)
Unread 07-12-2019, 09:33 PM   #15
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 2,256
Never heard of there being a difference.
Just universally called it rim board, or rim joists, or band joists, (rarely). Never really heard it called end joists out here.
Kind of like barge rafter vs fly rafter.
Not to be confused with a verge rafter. Which is a different thing.
Get Off My Lawn.
"There are no big projects. There are only small machines". - R. G. LeTourneau
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
Calidecks (07-13-2019), greg24k (07-13-2019)
Unread 07-13-2019, 12:47 AM   #16
Designer/Contractor
Rio's Avatar
A LVL or something along those lines, maybe a Timberstrand LSL, versalam rim, different manufacturers have different names.
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
Jay hole (07-13-2019)
Unread 07-13-2019, 12:58 AM   #17
back doors to hell put in
Irishslave's Avatar
Rewards Points: 2,796
I've done that. A little expensive though.
Television is fake...The internet is real
Irishslave is online now
Unread 07-13-2019, 03:55 AM   #18
General Contractor
greg24k's Avatar
It's all technical terms... for as long as I been around was always called a rim joist. Some old-school architects will use different wording when defining framing members on their plans.
If you look in the code-book, they will define it as Band joist, Rim joist or Header joist.
The Following 2 Users Say Thank You to greg24k For This Useful Post:
Seven-Delta-FortyOne (07-13-2019), TimNJ (07-13-2019)
Unread 07-13-2019, 07:54 AM   #19
Designer/Contractor
Rio's Avatar
Here's a png showing the two conditions along with the big ole honking connectors required now to make a guardrail post code compliant.
Rio is online now
Unread 07-13-2019, 11:03 AM   #20
General Contractor
greg24k's Avatar
NJ most jurisdictions around me amended this type of post connections...Did 2 decks last year and 3 decks this year and none of the towns requested that. 2x blocking with ledger locks into the post it works and that post is not going anywhere.
Not sure about down the shore requirements, maybe in coastal areas they ask for it, I'm sure a few guys here from South Jersey will comment on Yes or No.
hdavis (07-13-2019), Rio (07-13-2019)
