Reinforcing Trim And King Stud, 2" Drain Pipe Through? - Framing - Contractor Talk
Old 04-22-2015, 07:33 PM   #1
tipitop's Avatar
Trade: carpenter
Rewards Points: 3,859
Recently work at a project where will trim and king stud of header be drilled for a 2 drain pipe. How to enforce 2X4 because will have only like 7/8 at each side. House is from 19 century and studs are real 4. As I see right now best way is buy some L steel profile ( thicker gauge better ) around 4 long and 3/4 wide at last at one side of L and screw with GRK or lag screws.
tipitop is offline
Old 04-22-2015, 07:52 PM   #2
tipitop's Avatar
Trade: carpenter
Re: Reinforcing Trim And King Stud, 2" Drain Pipe Through?
I guess will use some of this
http://www.strongtie.com/ftp/fliers/f-reprprotect09.pdf
tipitop is offline
Old 04-22-2015, 07:54 PM   #3
Dan_Watson's Avatar
Rewards Points: 2,720
Exactly what I was going to recommend.
Dan_Watson is offline
Old 04-22-2015, 08:28 PM   #4
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 836
How will those work with true 2" x 4" lumber?
dsconstructs is offline
Old 04-22-2015, 08:32 PM   #5
Dan_Watson's Avatar
Use the triple 3x and add a 1/2 spacer.
Old 04-22-2015, 08:44 PM   #6
Box Builder
Morning Wood's Avatar
Rewards Points: 9,990
is that going to pass inspection even with those strong tie products?
Morning Wood is online now
Old 04-22-2015, 08:55 PM   #7
tipitop's Avatar
Trade: carpenter
I'm not concerned with special solution for real 2"X4". It is easy for me to fill in or chisel off what need. I just need a solution for standard 2X4 that can pass inspection.
Of course it is a bearing and exterior wall. To be worse it is balloon framing and stud is 18’ long and cut will be 3’ from bottom.
tipitop is offline
Old 04-22-2015, 08:56 PM   #8
Dan_Watson's Avatar
Happens here all the time.
Old 04-22-2015, 09:35 PM   #9
Renaissance Man
superseal's Avatar
Rewards Points: 5,828
I would suggest talking to the plumber and re-routing if possible. A solution can usually be found without sacrificing jacks and kings.
supersealconstruction.com
superseal is offline
