Rafter To TJI Connection - Page 2 - Framing - Contractor Talk
Old 07-20-2014, 07:52 AM   #21
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Re: Rafter To TJI Connection
All the I joist companies we deal with will engineer their products for specific situations. In most cases, rim board negates the need for squash blocks.
I prefer using a bearing plate, but wouldn't say it's necessary, especially when using some form of metal connector.
loneframer is offline
Old 07-20-2014, 07:55 AM   #22
Joseph A. Capece
CENTERLINE MV's Avatar
Trade: Builder - General
Rewards Points: 1,432
Originally Posted by loneframer View Post
Just did a floor/roof detail like this.
Frame as a floor, using rim board. Deck as a floor to tie everything together. Install a bearing plate of 2x4 or 2x6 and birdsmouth the rafter. Wall sheathing should carry across the rim board and tie to the bearing plate to unify the structure. Use a hurricane clip at every rafter to resist uplift. Install clips to exterior to catch full meat of rafter and tie into the sheathed structure.
That is exactly how I did it for this project I framed over the winter:
It's a Green building so I installed a rim (sub fascia?) to the ends of the rafters. We installed false rafter tails after nailbase insulation. (My buddy that I built this for is featured on this months issue of JLC).
Follow us on FACEBOOK
www.centerlinebuilders.net
Martha's Vineyard General Contractors - Builders -
Commercial/Residential - Additions - Renovations
CENTERLINE MV is offline
Old 07-22-2014, 08:14 PM   #23
RocketScott's Avatar
Trade: Framing
Rewards Points: 118
Ever think about getting attic trusses?
Without seeing a plan I can't understand completely. If it's a straight gable to gable roof I think attic trusses with a microlam bottom cord would be less expensive and faster than building the floor, sheeting, and cutting the roof. Lots of variables though.
I did a detached garage a couple of years ago that we changed from a huge ridge beam and rafters to trusses. It saved the homeowner about 3k. He was pretty stoked about that.
RocketScott is offline
Old 07-22-2014, 11:52 PM   #24
kiteman's Avatar
Rewards Points: 16
Originally Posted by Rio
LVL or Microllam rim.............
That's just plain unnecessary.
I actually liked the method using the top mount hangers the best.
An old framer once told me "For years I thought I was the best damn carpenter in California. Come to find out I'm just competent."
kiteman is offline
Old 07-23-2014, 12:32 AM   #25
Designer/Contractor
Rio's Avatar
Rewards Points: 62
One shouldn't mix sawn lumber with engineered lumber in one plane. the rule is engineered lumber to engineered lumber or sawn to sawn. If one uses a sawn lumber rim with TJI's one is asking for problems. Look at the catalogs.
Rio is offline
Old 07-23-2014, 12:45 AM   #26
kiteman's Avatar
Rewards Points: 16
I don't think anyone is advocating using sawn lumber for rim. I think we're talking about engineered rim board.
kiteman is offline
The Following User Says Thank You to kiteman For This Useful Post:
Rio (07-23-2014)
Old 07-23-2014, 06:20 AM   #27
haverhillstreet's Avatar
Trade: carpenter
Rewards Points: 64
That is correct.
Regarding using trusses: I think it's all what you're used to. I was told the material cost would be a lot more for the trusses( I don't care as much about labor time), I have a set of stairs going up in a particular spot, and my 'help' situation will be sporadic. I could of had it all spec'd out for trusses but I didn't want to bother.
haverhillstreet is offline
Dormer Shed Roof, Barrel Roof, CutIn Dormer, Eyebrow Dormer sbebuilders Framing 33 04-18-2013 05:29 PM
Common Rafter Length - SpreadSheet Texas Wax Framing 11 12-25-2012 01:01 AM
weird water heater tank connection?... BuenaHomes Plumbing 28 10-02-2012 04:33 PM
cutting multiple precise plumb slots in rafter peakecg Finish Carpentry 15 08-17-2012 11:08 AM
CAT3 for high speed credit card connection KennMacMoragh Low Voltage 13 06-03-2011 12:19 PM
