Rafter To TJI Connection - Framing - Contractor Talk
Old 07-19-2014, 08:30 AM   #1
haverhillstreet's Avatar
Trade: carpenter
Rewards Points: 64
Hi: I'm going to be framing a 26'x42' garage and will be using 2x10 rafters running parallel with 26' TJI joists. The rafters will need to sit on top of the joists. Can anyone offer me the correct way to structurally frame this and tie the two together, or direct me to a site that shows the proper detail for making the connection? I've found other rafter to joist type connections but can't seem to find this one.
thanks, Dave
haverhillstreet is offline
Old 07-19-2014, 08:55 AM   #2
TRMolnar's Avatar
Rewards Points: 398
Re: Rafter To TJI Connection
Why wouldn't the rafters sit directly on the top plate of the wall?
TRMolnar is offline
The Following User Says Thank You to TRMolnar For This Useful Post:
CrpntrFrk (07-19-2014)
Old 07-19-2014, 09:18 AM   #3
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
I wonder why they will not be on the top plate also. But you want to handle it kinda like a floor. TJIs with rim board. Set the rafters on top and make a plywood gusset connecting the two. I would also use a 2x4 rat run on top of the TJIs and notch the rafters at the heel for the 2x4.
Sorry to be negative but this sounds unstable and a whole lot of work to make it stable.
CrpntrFrk is offline
Old 07-19-2014, 11:30 AM   #4
Trade: carpenter
Rewards Points: 64
The TGI's would need to be 14-16" tall to span the 26'. They need to meet a minimum dead/live load for 'minimum attic storage'. If the rafters and TJI both sat on the top plate of the wall I'd have to cut out the part of the TJI sticking above the roof plane which would affect it's structural integrity. The TJI manufacturers only show this detail using TJI's as both rafter and joist. I thought it might be easier/better/faster? to have the 2x10 rafter sit on top of the TJI joist but I can't find any detail info.
Old 07-19-2014, 11:45 AM   #5
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
weyerhaeuser has want you are looking for search there site
pappagor is offline
Old 07-19-2014, 11:56 AM   #6
Shane O's Avatar
Rewards Points: 176
Sheath your floor.
Use a 2x6 or 2x4 nailed around the perimeter. Birds mouth your rafters to sit on 2x6.
Use a tji trimmer joist that is 1 1/8" to cap your ends of the tji and install squash blocks beside the joists.
Over that span I'd still use tji blocking at center of span.
Shane O is offline
The Following 5 Users Say Thank You to Shane O For This Useful Post:
fourcornerhome (07-19-2014), JT Wood (07-19-2014), overanalyze (07-23-2014), ScipioAfricanus (07-19-2014), slowsol (07-19-2014)
Old 07-19-2014, 01:19 PM   #7
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
what do the plans say ?
do you even have plans
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
Old 07-19-2014, 01:26 PM   #8
Trade: carpenter
Rewards Points: 64
Pappagor: Thanks, I'll look at the Weyerhaeuser site.
Shane: That all sounds good. I'm also worried about uplift with this detail, so will probably gusset rafter to joist as Crpntrfrk said.
Old 07-19-2014, 01:42 PM   #9
Shane O's Avatar
Rewards Points: 176
Use a hurricane tie or twist strap from tji to wall and from rafter to trimmer joist. Or an a35 clip from rafter to 2x6.
Also if you set your trimmer joist flush to framing you can sheath up the trimmer joist and that act as a strong connection from floor to walls.
Shane O is offline
Old 07-19-2014, 02:35 PM   #10
owattabuilder's Avatar
Trade: general
Rewards Points: 278
I would follow Shane O's advice. That sounds like the way I would do it.
owattabuilder is offline
The Following User Says Thank You to owattabuilder For This Useful Post:
Old 07-19-2014, 05:42 PM   #11
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Just did a floor/roof detail like this.
Frame as a floor, using rim board. Deck as a floor to tie everything together. Install a bearing plate of 2x4 or 2x6 and birdsmouth the rafter. Wall sheathing should carry across the rim board and tie to the bearing plate to unify the structure. Use a hurricane clip at every rafter to resist uplift. Install clips to exterior to catch full meat of rafter and tie into the sheathed structure.
loneframer is offline
Old 07-19-2014, 06:16 PM   #12
Trade: carpenter
Rewards Points: 64
loneframer: Did you use squash blocks on either side of the TJI's under the bearing plate or did you feel like the rim board with sheathing was enough to support the rafters?
Old 07-19-2014, 07:50 PM   #13
Shane O's Avatar
Rewards Points: 176
Squash blocks are required at all bearing surfaces. There will be a installation guide delivered with your joists. It will show you how to install as well as typical details for bearing.
Shane O is offline
The Following User Says Thank You to Shane O For This Useful Post:
Old 07-19-2014, 10:08 PM   #14
CrpntrFrk's Avatar
Shane O and Lone worded it better but what they have typed out was exactly what I was suggesting.
Old 07-19-2014, 10:33 PM   #15
Trade: general
Rewards Points: 278
The rim should be good for about 3000 lb / lf load on it it would be the same as the edge of a conventional floor and no blocks required unless the loads are over that.
Old 07-19-2014, 10:58 PM   #16
Shane O's Avatar
Rewards Points: 176
I agree with this post.
Shane O is offline
Old 07-19-2014, 11:44 PM   #17
Designer/Contractor
Rio's Avatar
Rewards Points: 62
LVL or Microllam rim.............
Rio is offline
Old 07-19-2014, 11:59 PM   #18
diplomat
Golden view's Avatar
Rewards Points: 1,550
Why all the recommendations to birdsmouth over a 2x6? If the rrs align with the cjs, it's not doing anything, except maybe distributing a little load to the rim joist. I'd be fairly concerned though about the rafter-cj connection to resist outward thrust. Check the code tables, you could need 10-20 16D nails here depending on slope and snow load.
Golden view is offline
Old 07-20-2014, 05:02 AM   #19
Matt0034's Avatar
Rewards Points: 344
http://www.buildgp.com/DocumentViewe...elementid=4372. Go to page 7, it shows the connection you need, you'll have to sheath before you put rafters on though. You can bevel cut the top of the I joist, just not past the inside of exterior wall.
Sent from my iPod touch using Tapatalk
Matt0034 is offline
Old 07-20-2014, 06:40 AM   #20
Trade: carpenter
Rewards Points: 64
The site from Matt0034 was the best I've seen for detailed info.
Knowing my building inspector, he'll want squash blocks irregardless .
I wasn't planning on sheathing the entire attic floor, but it looks like I'll have to in order to achieve the proper rating.
Thanks for all your input. I'm a 'finish'guy, not a framer, and have not done this particular detail before. The way the codes constantly change I wanted to get it right.
Dormer Shed Roof, Barrel Roof, CutIn Dormer, Eyebrow Dormer sbebuilders Framing 33 04-18-2013 05:29 PM
Common Rafter Length - SpreadSheet Texas Wax Framing 11 12-25-2012 01:01 AM
weird water heater tank connection?... BuenaHomes Plumbing 28 10-02-2012 04:33 PM
cutting multiple precise plumb slots in rafter peakecg Finish Carpentry 15 08-17-2012 11:08 AM
CAT3 for high speed credit card connection KennMacMoragh Low Voltage 13 06-03-2011 12:19 PM
