Question On Code For Framing A Window - Framing - Contractor Talk
Old 12-18-2015, 07:19 AM   #1
abacab's Avatar
Rewards Points: 390
I built a new house this year, and on the main floor I framed (what I think is proper) the windows with the jack studs under the header going all the way down to the floor, and the sill plate spaning between. Upstairs, I was in a hurry and not paying attention and I did it the way I was taught, the outside stud going from double top plate to the bottom plate, and the bottom sill plate goes all the way from the outside stud to the other stud, with the kickers filling in under the beam down to the sill plate, and kickers running from the sill plate to the bottom plate. Is this ok, or am I going to have to redo it? pretty hard at this point, maybe there is a work around?
Thanks
abacab is offline
Old 12-18-2015, 07:30 AM   #2
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,888
Re: Question On Code For Framing A Window
I don't follow how you did the main floor window, but your upstairs one sounds right.
Aztec Decks
Oshawa deck builder
heavy_d is offline
Old 12-18-2015, 07:43 AM   #3
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
Sounds like no cripple under the sill plate. I've run it both ways. King, continuous Jack, then cripple the sill next to the jack or I've King stud, then sandwiched the sill between the Jack.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 12-18-2015, 08:09 AM   #4
abacab's Avatar
Rewards Points: 390
I did the downstairs ones correct, according to what I understand is according to code after the change around 2008 or earlier, the upstairs I did the way everyone did 20 years ago. His wondering if I'm mistaken and the old way is still acceptable. Will postpictures later.
abacab is offline
Old 12-18-2015, 08:13 AM   #5
Framer87's Avatar
Trade: Framing
Rewards Points: 1,156
So you've cut your trimmer/cripple/jack stud holding the header, to let in the lower sill? That would fail here.
Framer87 is offline
The Following User Says Thank You to Framer87 For This Useful Post:
jlhaslip (12-18-2015)
Old 12-18-2015, 10:31 AM   #6
General Contractor
greg24k's Avatar
Rewards Points: 8,784
What is the old way and what is the new way. I been doing this almost 30 years and it's been done the same way then and now.
With that being said and you did on one floor one way and on the second floor another way and you come here and ask "right way or wrong way?" It sound like it's done the wrong way on one of the floors and most likely "I was in a hurry and not paying attention and I did it the way I was taught" this was the right way... than again it depends who taught you
greg24k is offline
The Following 7 Users Say Thank You to greg24k For This Useful Post:
builditguy (12-19-2015), Calidecks (12-18-2015), fourcornerhome (12-19-2015), jlhaslip (12-18-2015), ScipioAfricanus (12-18-2015), TNTRenovate (12-18-2015), wallmaxx (12-24-2015)
Old 12-18-2015, 01:33 PM   #7
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
I rather put header tight to top plates and block down to window r/o.
Aztec Decks
Oshawa deck builder
heavy_d is offline
The Following 3 Users Say Thank You to heavy_d For This Useful Post:
muskoka guy (12-19-2015), TNTRenovate (12-18-2015), wallmaxx (12-24-2015)
Old 12-18-2015, 02:02 PM   #8
diplomat
Golden view's Avatar
Rewards Points: 1,550
The wrong one you did isn't that bad. It's relying on the crush strength of the window sill, but all studs rely on crush strength of the plates. You're reducing the bending strength of the wall by only having one king stud on either side of the window.
If you're not close to the maximum header span for a single jack (trimmer) and single king on each side, I think it's fine.
Golden view is offline
Old 12-19-2015, 06:12 AM   #9
abacab's Avatar
Rewards Points: 390
I did not do it the way the picture shows above, I ran the sill plate all the way over to the side wall stud. This is the way everyone did it around here until about 10 years ago. If the bending of the wall is the only consideration, I should be able to throw an extra stud in on each side. When I look at advanced framing techniques, they only use one stud with no jack stud supporting the header, instead they rely on a special hanger that ties the header to the lone stud. I called the building inspector, but he was gone, so I'll try again Monday.
abacab is offline
Old 12-19-2015, 08:22 AM   #10
builditguy's Avatar
Rewards Points: 2,138
I didn't know there was an old way and a new way. I've always done it the same way, which is still code.
Can you post a picture of what you did? I'm sure there will be plenty of input.
builditguy is offline
Old 12-19-2015, 08:39 AM   #11
Mark122's Avatar
Rewards Points: 464
pictures?
you could be ok with whatever your "old" or "new" method is but i would not hold my breath hoping to pass the "Im adding advanced framing techniques" to the inspector. If one were to start to mixing conventional and advanced framing I could see a red tag and alot of re working your framing.
Mark122 is offline
Old 12-19-2015, 08:44 AM   #12
Tom M's Avatar
Rewards Points: 12,208
Well I replace lots of windows with rotten sills. I see king studs as stiffeners for the trimmers, unless the header bracket is used. Saying that the trimmer carries the weight and should maintain a continuous load path. You wouldn't want a supporting member susceptible to poor maintenance of windows and settling on decaying members.
Tom M is online now
The Following 2 Users Say Thank You to Tom M For This Useful Post:
greg24k (12-19-2015), jlhaslip (12-19-2015)
Old 12-19-2015, 02:44 PM   #13
General Contractor
greg24k's Avatar
Some framers put them at the top plate height, but when dealing with larger openings on a long and unobstructed wall, best practice to keep the header right above the door or window because you have a much better lateral support and it prevents wall movement each time the door closes, not to mention you want to have a solid surface above the door or window so all kinds of accessories like blinds, etc can be attached without trying to find studs.
Therefore to keep framing uniform, my rule of thumb was always to put headers above the door or window, of course when you dealing with transoms, or other custom window or door configurations, you raise the header up based on the situation.
greg24k is offline
The Following 4 Users Say Thank You to greg24k For This Useful Post:
CENTERLINE MV (12-19-2015), heavy_d (12-21-2015), muskoka guy (12-19-2015), ScipioAfricanus (12-22-2015)
Old 12-19-2015, 04:24 PM   #14
muskoka guy's Avatar
Trade: framer/builder
Rewards Points: 558
I prefer putting the headers at the top of the wall. This way if a load point lands on top of the header I don't have to add a bunch of blocking down to the header. Any openings over six feet I will double plate the top and bottom of the opening to stiffen the wall.
muskoka guy is offline
The Following User Says Thank You to muskoka guy For This Useful Post:
Old 12-22-2015, 07:18 AM   #15
abacab's Avatar
Rewards Points: 390
I can't insert a picture without a link, so I guess no picture. I think everyone understands how I framed it in now, and the building inspector approved it. I pointed it out to him, and he said it was fine.
P.s. why can't there be a facebook style upload for the forums?
abacab is offline
Old 12-22-2015, 07:22 AM   #16
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Try to wire a blind when the framer installs a double LVL tight to the top of the window.
I've never seen a header at top plate height but from a wiring standpoint I'd much rather deal with it.
Inner10 is offline
TNTRenovate (12-22-2015)
Old 12-22-2015, 08:21 AM   #17
General Contractor
greg24k's Avatar
Like I said before if there is something needs to be accounted for you make the necessary adjustments and leave the room so blinds can be wired, or anything else for that matter.
greg24k is offline
Stupid question? Anyone ever mix sodium bicarbonate with recycled glass? MasterBlaster Sandblasting 7 03-23-2013 06:14 PM
New construction Window bow/warp. Help typer0186 Windows, Siding and Doors 7 06-14-2012 09:38 AM
commercial fire code question CastleCo Framing 3 04-04-2011 08:32 PM
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
