Parade Model - Page 2 - Framing - Contractor Talk
Parade Model
Old 02-27-2014, 08:10 PM   #21
FRAMERBEN's Avatar
Trade: Framer/Remodeler
Rewards Points: 170
Re: Parade Model
What's the R-19 insulation for?
FRAMERBEN is offline
Old 02-27-2014, 11:55 PM   #22
ObuckiO's Avatar
Trade: Framing
Rewards Points: 327
Re: Parade Model
That's a good one to take a guess at. At first I assumed it was sill seal, however your question reminded me of a builder who wanted corners & wall ties built in a way that framers would have to insulate them or they would be covered up without any. He wanted a full stud instead of 3 blocks in all wall ties, but we rarely ever had to insulate any corners, as he thought.
I'm just taking a stab at this one... But, it could just be a good back rest for lunches.
ObuckiO is offline
Old 02-28-2014, 12:29 AM   #23
Texas Wax's Avatar
Rewards Points: 2,150
Re: Parade Model
Might be for where the joists fall on the block wall. To insulate between jiost and rim that can't be done after.
Always had a spud of insulation with the deck load, when framing up north in SE Wisconsin, just in case ect - general practice
Texas Wax is offline
Old 02-28-2014, 01:01 AM   #24
ObuckiO's Avatar
Trade: Framing
Rewards Points: 327
Re: Parade Model
That seems like the best bet, after looking at the layout.
ObuckiO is offline
Old 02-28-2014, 07:35 PM   #25
SAcarpenter's Avatar
Trade: residential/remodeling carpenter
Rewards Points: 938
Re: Parade Model
They just send it out in case we have a weird corner or something. We rarely use it as i try to layout to avoid having to insulate. My feeling is that sometime before the building is dried in that insulation will see moisture. As for the box sills, we started laying out all first bays at 2' to maximize the room the spray foam guys get. A lot of builders started to go to spraying the rimboards
You can rest when you're dead
SAcarpenter is offline
Old 02-28-2014, 07:40 PM   #26
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 366
Re: Parade Model
I always have a few sheets of 2" foam sent out for the partition cavities. I take them home and rip them on the table saw to 3 1/2". By using foam instead of fiberglas, moisture is not an issue.
Easy Gibson
Warren is online now
The Following User Says Thank You to Warren For This Useful Post:
jlsconstruction (03-11-2014)
Old 02-28-2014, 08:06 PM   #27
Rewards Points: 938
Re: Parade Model
Couple pics from today. We were off site wednesday and thursday and started late today because of the cold. The seven-ply micro has been a pain from day one. This plan has been engineered for months now yet the lumber guy didnt search for the bolts until i asked for them on monday. Finally got all of them at 2 this afternoon. At least we got the deck on and lines snapped before the snow this weekend
Old 02-28-2014, 08:29 PM   #28
Geometrist
Warren's Avatar
Rewards Points: 366
Re: Parade Model
Seven ply micro?
That seems pointless. I have never seen more than a 4 ply. Why not go with steel at that point? Cheaper, less labor, and lighter.
Easy Gibson
Old 02-28-2014, 08:44 PM   #29
Rewards Points: 938
Re: Parade Model
Thats been the general consensus around here too. Thats the first time ive done one over 4-ply
Old 02-28-2014, 09:36 PM   #30
ObuckiO's Avatar
Trade: Framing
Rewards Points: 327
Re: Parade Model
Originally Posted by Warren View Post
Seven ply micro?
The pic in my avatar was an old 3 story house on Ohio State's campus,(caught fire)... Where my head is at, a 10' ridge connected and on the other side of ridge, a 1''X 8" steel scissor type truss(maybe 800lbs) made up both sides of them common rafters(Huge capital "A'' shape).
After taking 8 guys to get it set(by rope, too many wires for crane), we had to bolt two 8" micro's on each side. Talking about a headache and overkill...
I think it took us around 5 hrs with all the obstacles.
Last edited by ObuckiO; 02-28-2014 at 09:46 PM. Reason: Edited: I thought I had pictures, but it was on an older phone I still have somewhere.
ObuckiO is offline
Old 02-28-2014, 10:01 PM   #31
ObuckiO's Avatar
Trade: Framing
Rewards Points: 327
Re: Parade Model
Originally Posted by SAcarpenter View Post
Thats been the general consensus around here too. Thats the first time I've done one over 4-ply
We're expecting 6-12" snow Sun-Mon.
With you getting the deck on, that's about as good as it gets, for them conditions. I hope it don't put too much damage on your cranking.
ObuckiO is offline
Old 02-28-2014, 11:24 PM   #32
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
Re: Parade Model
Attachment 108751
Attachment 108752
ATTACH]108753[/ATTACH]
Looks good
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 03-03-2014, 08:15 PM   #33
Framing Contractor
FullerFramer's Avatar
Trade: Framing
Rewards Points: 576
Re: Parade Model
Are the joist lagged through the steel beam flange from below?
FullerFramer is offline
Old 03-03-2014, 08:44 PM   #34
Resident Pain
CanningCustom's Avatar
Rewards Points: 1,730
Re: Parade Model
Probably calls for strapping either side of the steel. I haven't done it like that in about 12yrs
CanningCustom is offline
Old 03-03-2014, 08:44 PM   #35
kyle_dmr's Avatar
Rewards Points: 998
Re: Parade Model
Toronto thing. Senator homes down in Woodstock did it for their models.
kyle_dmr is offline
The Following User Says Thank You to kyle_dmr For This Useful Post:
CanningCustom (03-03-2014)
Old 03-03-2014, 08:50 PM   #36
Resident Pain
Re: Parade Model
That is where I did 12yrs ago lol
Old 03-04-2014, 08:23 PM   #37
Rewards Points: 938
Re: Parade Model
The joists just float on the beam. We temp brace the beams in place until we are done with the house then they are just held in place by the weight from above.
Heres a few progress pics from the past couple days. We were off a few days because of the so we're not to far yet.
The Following User Says Thank You to SAcarpenter For This Useful Post:
FullerFramer (03-04-2014)
Old 03-04-2014, 08:25 PM   #38
Rewards Points: 938
Re: Parade Model
Couple more
Old 03-04-2014, 09:31 PM   #39
kiteman's Avatar
Rewards Points: 16
Re: Parade Model
Is that 1/2" AC for soffit? What's the fascia?
It's been a while since I built a bay like that. Only way to go!
An old framer once told me "For years I thought I was the best damn carpenter in California. Come to find out I'm just competent."
kiteman is offline
Old 03-04-2014, 10:18 PM   #40
Rewards Points: 938
Re: Parade Model
3/8" rough sawn fir w/ 1x8 & 2x8 Real Trim. Its basically #1 pine rough sawn on one face and primed. Ihave a video of me lifting that wall but i dont know how to upload videos. Thats one of a few tall walls we have to build. More pics tomorrow
Adding Sketchup model to photo rrk Architecture & Design 9 11-25-2013 12:06 PM
1999 hitachi 5" angle grinder model no.? sepindustries Tools & Equipment 10 06-15-2013 09:11 AM
Settings for Milwaukee model 4910 paint sprayer Camyankee Tools & Equipment 0 08-14-2012 09:20 PM
Model home leak, why would you do this eXpatRioteX General Discussion 30 03-02-2010 07:28 PM
Park Model Haulers Needed For TX/LA Border Lei Louang Help Wanted or Looking For Work 0 11-04-2008 01:32 AM
