Opinions Needed - Framing - Contractor Talk
Opinions Needed
Old 02-03-2019, 04:58 PM   #1
nickelec's Avatar
Trade: professional licensed electrician
Rewards Points: 342
Opinions Needed
So they just finished first floor addition on the back of my house we plan to go up 2 stories to meet the existing roof line
Due to city codes I needed to have a setback off the neighbors property line there for not being able to build as wide as the existing foot print (very frustrating)!! Any way my question is in regards to the roof line
I'm not sure what would look best do I
A. build the right side wall on the 2nd floor a bit higher to match existing roof line and have a bigger soffit on that one side or
B. just have the roof come off a different slope on that one side this creating a valley I've attached some pics so you can better visualize my situation
Sent from my SM-G965U using Tapatalk
nickelec is offline
Old 02-03-2019, 06:42 PM   #2
Rooster Cogburn's Avatar
Trade: Master carpenter
Rewards Points: 254
Re: Opinions Needed
Do you have any more pictures? That is not much to go on.
Rooster Cogburn is offline
Old 02-03-2019, 06:43 PM   #3
nickelec's Avatar
Rewards Points: 342
Re: Opinions Needed
Not really off that angle
nickelec is offline
Old 02-03-2019, 06:58 PM   #4
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 2,068
Re: Opinions Needed
Over hangs are usually included in setback requirements so I’m guessing you’re not going to get away with A.
Big Johnson is offline
Old 02-03-2019, 06:59 PM   #5
nickelec's Avatar
Rewards Points: 342
Re: Opinions Needed
Not included here I'm free to do either or I just cant picture what would look better
nickelec is offline
Old 02-03-2019, 07:25 PM   #6
B.Johnson's Avatar
Trade: Builder
Rewards Points: 1,932
Re: Opinions Needed
If I understand your question correctly, I would make all walls the same height and all roofs the same pitch. something like this:
Home Designer Series Software
B.Johnson is offline
Old 02-03-2019, 07:35 PM   #7
nickelec's Avatar
Rewards Points: 342
Re: Opinions Needed
So where the set back is the soffit would jog.in u wouldn't extend the soffit to meet the existing facia board
nickelec is offline
Old 02-03-2019, 07:40 PM   #8
Re: Opinions Needed
I would do it like BJ says. Then do an eyebrow eve to connect old roof to new or just dead end the new roof/eve into the old wall (my first choice). Leave old roof alone.
B.Johnson (02-03-2019)
Old 02-03-2019, 07:40 PM   #9
B.Johnson's Avatar
Trade: Builder
Re: Opinions Needed
Again, assuming I understand your situation...
I think that the left wall is straight, and the only offset is on the right wall. If that's the case, your ridges shouldn't line up because you have a shorter span on the new part. You will have a partial gable wall over the new roof. If all that is true, I'll draw you a better picture.
Old 02-03-2019, 07:42 PM   #10
nickelec's Avatar
Rewards Points: 342
Re: Opinions Needed
That's true correct left Wall is straight with the existing house right wall is set back
Somebody had mentioned having a large soffit on that right side I could put some lighting in or whatever but I couldn't Invision it with having to build a small knee wall on the attic to meet the roof rafters
nickelec is offline
Old 02-03-2019, 08:03 PM   #11
B.Johnson's Avatar
Trade: Builder
Re: Opinions Needed
You could do that, but I wouldn't care for the look.
Old 02-03-2019, 08:04 PM   #12
nickelec's Avatar
Rewards Points: 342
Re: Opinions Needed
Can you draw it the other way looking from the ground that's amazing ty I was searching Google for that image for a while
nickelec is offline
Old 02-03-2019, 08:11 PM   #13
nickelec's Avatar
Rewards Points: 342
Re: Opinions Needed
Or an image reflecting the wall height on the right being higher that's what I can't visualize
nickelec is offline
Old 02-03-2019, 08:39 PM   #14
B.Johnson's Avatar
Trade: Builder
Re: Opinions Needed
can you draw it the other way looking from the ground that's amazing ty i was searching google for that image for a while
sent from my sm-g965u using tapatalk
Old 02-03-2019, 08:40 PM   #15
nickelec's Avatar
Rewards Points: 342
Re: Opinions Needed
How about woth extended soffit
nickelec is offline
Old 02-03-2019, 08:54 PM   #16
B.Johnson's Avatar
Trade: Builder
Re: Opinions Needed
or an image reflecting the wall height on the right being higher that's what i can't visualize
Old 02-03-2019, 08:56 PM   #17
B.Johnson's Avatar
Trade: Builder
Re: Opinions Needed
Have a little patience, I'm watching the game, ordering truck parts, and doing architectural design all at the same time.
Old 02-03-2019, 08:58 PM   #18
nickelec's Avatar
Rewards Points: 342
Re: Opinions Needed
Lol ty I appreciate it games kind of slow
nickelec is offline
Old 02-03-2019, 09:12 PM   #19
B.Johnson's Avatar
Trade: Builder
Re: Opinions Needed
Obviously I don't know what your floor plan is but if I were going to have a large overhang like that then I would want a reason for it. As we like to say "For a little bit more..."
Old 02-03-2019, 09:14 PM   #20
B.Johnson's Avatar
Trade: Builder
Re: Opinions Needed
The deck probably won't work with your setback.
Get any and all Columbia Forest Products at Home Depot if needed TBFGhost Carpentry 15 01-02-2013 09:31 PM
Your opinions on buying and selling equipment cbscreative Business 7 03-10-2011 01:37 PM
Price for Fill / Garage Slab Prep -- Opinions? slr2974 Excavation & Site Work 9 06-17-2009 09:22 AM
